Plumbing drain question | FerrariChat
Discussion in 'Other Off Topic Forum' started by Mera, Dec 25, 2007.
  1. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    In my one bathroom that I use personally on a daily basis I have found something unusual in the sink drain. I have a problem in this drain that I have never seen before. A few years ago my brother and I did some work in that sink. I can't remember exactly what we did but we probably put in a new brass piece. The brass part just under a bathroom sink with the lift lever and stopper thing. I think (looking at it) that we must have reused the original PVC pipes as they do not look new. My house is about 17 years old. Most of the bath room drains were all rotted away from the original owner probably using drain cleaner as they had a daughter with long hair. I had to auger out most of the drains when I moved in.
    I noticed lately that if I ran a faucet in this sink full blast the water did not drain out as fast as it used to and would back up into the sink some. So I pulled out the plunger thing and found (to my surprise) it was all covered with a thick black slime. The inside of the brass pipe is also all full of this thick black slime. I also see it is in the openings in this brass tube for the overflow from the sink. I have never seen something like this before. I have seen this black slim in most any drain pipes I have worked on thru the years and I used to own an apartment building but never to this degree. Any suggestions? Bleach? That enzyme stuff?
    Any suggestions? Anyone else ever experience this?
    Thanks for any advice. :)
    Rodney Dickman
    1990 348 TS
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It's probably an organic brew of soap, toothpaste and human DNA. I've found it in drains many times (mostly bathrooms). Typically if you disassemble and clean out the trap (bound to be some hairy gremlins in there) and run very hot water down when it's back together it won't be a problem again for a few years.
    Most products that you pour down the drain are a waste of money.
  3. UroTrash
    Jan 20, 2004
    40,197
    Purgatory
    Clifford Gunboat
    Congrats. It takes a lot to gross out a urologist; you succeeded.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    LOL!
  5. Lee in Texas
    Lee in Texas Formula Junior
    Oct 21, 2006
    685
    near Austin, TX
    Lee
    I'm a plumber. I've seen that goo before. Mostly in the homes of people who wash their hair over the sink and use goo in their hair. I have no idea if you put goo in your hair, I'm just sayin'...
    I'd just clean the pipes under the sink with a bottle brush or replace them. You can buy a new P-trap at a home improvement store. Be sure you get the right size. If your house is old, it may use 1 1/4" pipe. Most new houses use 1 1/2" pipe. After that, just watch what goes down the drain.
    some free tips: do not use any chemicals in your toilet tank. This means the bleach tablets and blue dye tablets. The chemicals will attack the rubber and plastic parts in your tank, eventually causing a leak.
    Be careful what you put down your garbage disposal. No potato peels, grape stems,....well, only put plate scrapings in it. And, if you mess up a pot of macaroni, don't try stuffing it all down the disposal. You shoulda seen that house. It was like a macaroni cannon when my buddy disconnected the pipe. Personally I hate the damn things. I'd remove mine but I'm always having people over and I don't want someone to try stuffing garbage down my drain.
    If you do need to call a plumber, have your house ready for him. If it's a kitchen sink problem, clean out the cabinet below. Same thing with the bathroom. Many plumbers charge by the hour. Do you want you pay $99/hr for a guy to pull stuff out of your cabinet and then put it all back? If it's a clogged drain, locate your cleanout. That's the pipe cap sticking out of the ground outside. That's where his auger will go to unclog your drain. Again, $99/hr to poke around your yard looking for a cleanout that's partially buried can get expensive.
  6. Whisky
    Whisky Three Time F1 World Champ
    30,674
    In the flight path to Offutt
    The original Fernando
    My wife dumps pure Clorox down her bathroom sink - says 'it dissolves hair'.
    I don't think I'm buyin' that because I have to take her sink apart underneath
    and clean it out once a year anyway...
    The other thing that ticks me off is when they dump boiling water down the
    disposal - like pasta water. I tell em 'that can't be good for the rubber seals
    in the disposal', but they don't listen to me.....
  7. ski_bum
    ski_bum Formula 3
    Dec 26, 2002
    1,492
    San Diego
    Michael
    I had a plastic bottle of lotion that was low. Trying to be green, I rinsed out the bottle with a lot of water (probably not so green) and threw the bottle into the recycle bin. A few weeks later that sink was clogged bigtime. I ended up cutting into the wall and pipes to get leverage for the snake. Pulled up a big wad of goop, hair, and other detritus. 99% sure it was the lotion.
    Going on a slight rant.....why the beep do they sell large pump bottles of lotion, soap, or other liquids, and the end of the pickup tube is 1/2" from the bottom of the bottle?!?!!?!??!?!
  8. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    I cleaned everthing the best I could with an old tooth brush and some Tilex. The overflow passage area is still mostly plugged. Not sure if I can find a way to clean that passage out.
    This sink is just used for general use. I am thinking it may be from using Listerine? No one washes their hair in this sink.
    Rodney
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    How about the trap under the sink?
    Usually any real stoppage is there (it builds up slowly over time). The only real way to clean it is to remove it and dump the crap out of it (could date to before you lived there).
    Here's another thought.
    Is this sink on an outside wall or does the drain line pass through an uninsulated space? Does the faucet have a small leak (running all the time)? If so it is possible to have a buildup of ice in the drain that can cause it to back up (it's been pretty cold lately).
  10. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    The bathroom is in an interior area of the hosue. All the build up was above the water line in the trap. The trap is perfectly clean as far as I can tell. The faucet does not drip.
    Rodney
  11. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Nice info there! It does make sense to make the job more direct for the plumber when he arrives. I had soem septic problems about a year ago. After digging up the tank cover and exposing the sewage (ugh!) I took my kids out to show them the massive crap and toilet paper mat floating at the top of the septic tank. After that episode they have cut way down on the TP usage (based on how much we have to buy), and no problems since. $200 to pump a 1200 gallon septic tank is a bargain IMHO.
    BT
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    MMMMMMMMMM! Yum!
    Just when I was beginning to get hungry for lunch. LOL
  13. HUTCH91TR
    HUTCH91TR F1 Rookie
    Nov 7, 2003
    2,894
    Charlotte, NC
    Hutch
    You could try dumping some muriatic acid down the drain and that should clear the pipes up just fine! Muriatic acid will not harm plastic (PVC pipes), but will damage most other surfaces, so be careful when using it!! Also, after dumping it down the drain, flush it thoroughly with water, then add in some baking soda & water mixture and flush with that (to neutralize the acid). Muriatic acid is readily available at any pool supply store or Wal-Mart.
  14. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It's not a good idea to put caustic chemicals in a slow drain. It generally doesn't work the way the "Liquid Plummer" commercial shows. Once it finds the quickest path through the clog it just goes down the drain. You still have 80% of the crap in the pipe.
    If you put the acid in and it doesn't drain out you have a nasty corrosive problem to deal with. If any of the pipes are brass or iron it won't do them any good. Plumbers get real testy when they have to deal with chemicals in a drain.
    If you put acid in and then put in bleach while the acid is still there you will make CHLORINE GAS this can be fatal for anyone standing over the sink.
    More than one person has been found slumped over a sink or toilet after this. Not a good way to die.
  15. HUTCH91TR
    HUTCH91TR F1 Rookie
    Nov 7, 2003
    2,894
    Charlotte, NC
    Hutch
    Your points are all valid, but it isn't such a bad idea to try a little muriatic acid and see the results. It might work pretty well, and would certainly be cheaper than a plumber. And if it doesn't drain, then add in some baking soda (sodium bicarbonate) to neutralize the acid. Then call a plumber, and grab your ankles :eek: !!!!
  16. Lee in Texas
    Oct 21, 2006
    685
    near Austin, TX
    Lee
    I've used Muriatic acid before in commercial buildings. Without adding anything else, it puts off some noxious fumes. As in burn your throat and take away your breath. I don't like the idea of using chemicals to unclog a drain in a house. Better to use an auger or clean, maybe replace the p-trap. 99% of clogged drains are hair or some slimy goo in the p-trap.
    Yeah, it puts food on my table so I can't get away from any bias issues, BUT I think it's always a good idea to have a licensed, bonded professional do work like this. If you mess up your plumbing, you pay to fix it. If a professional messes it up, he pays to fix it.
    I can only speak for Texas, but here, all plumbing work must have a Master Plumber involved. Either doing the work or ultimately responsible for a Tradesman/Journeyman's work. Any ad or business card for a reputable plumber will have the Master Plumber's license number and possibly his name on it.
    Oh yeah- that Liquid Plumr commercial. It shows a clog at a p-trap. You could drive to the store and plunk down a few bucks for that stuff, or you could just remove the p-trap and clean it for free.
  17. mwarrior
    mwarrior Formula Junior
    370
    Ontario and Texas
    Gagan P
    I'm a little late on this one, but heres the things I've tried which have seemed to work.
    Muriatic acid has been suggested, and does work well. Just remember, its acid so be careful when using it (hence the reason it comes in a plastic bag as thick as vapor barrier), and it should get pretty much anything that you see.
    Another thing I've tried (safe for septic systems too as we used to be on septic before having a pumping station installed to pump the sewage to the street), is the "Drain Conditioner" I believe its called. Comes in a clear bottle, and green liquid. You pour hot water down your drains for about a minute (so they warm up), then pour I think 6 ounces of this stuff down, and leave it for 6hours (dont use any drains).
    I was kind of skeptical when using it, but the slow drains that didnt work with drain opener worked fine with this. Its supposed to eat all the grime and stuff in the drains (its got enzymes that react to it all I guess), but for a trip to Home Depot, it was worth it.
    The black stuff could be anything from toothpaste + dirt/dust combo to oils from regular use (not a plumber or anything, just guessing). For under $20-25, the muriatic acid and drain conditioner is a good bet, and much cheaper than calling a plumber if it turns out its something easy to do.
  18. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Do you use shave cream and shave in this sink?
