PLS HELP!!! I LEFT MY KEY IN THE TRUNK!!! | FerrariChat
Discussion in 'California/Portofino/Roma' started by pmb458, Sep 18, 2011.
  1. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    I am so stupid. I was mounting my GoPro on my rear bumper so I can record some beautiful exhaust notes on my 09 California. I only have one key! Previous owner lost the 2nd key. I closed the trunk and left my key in there. Now I see all the amber lightS up except on the front driver's seat. WHAT SHOULD I DO?!?! Can my local dealer get it open? Or I have to special order one from Modena Ferrari!??!?! OH MY GOD!!!!!!!!!!!!!!!!!!!
    I DON'T HAVE THE KEY CARD ALSO!!!!!!
    HELP!!!!!
  2. TheMayor
    104,751
    Vegas baby
    The dealer can open it. If you're a member (and you should be!) call AAA and see if they can send over a locksmith to unlock it.
    One thing they can do is jimmy the doorlock and then you can open the trunk manually from inside.
    Otherwise, I think you're screwed until you can call the dealer tomorrow.
    Don't panic. Stuff happens. It only costs money to make it right.
  3. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    Thanks bdelp!!!! I guess I am waiting on the dealership tomorrow asap!!!!! Yes my car is still under warranty. Hope they will get it open asap!!!
  4. TheMayor
    104,751
    Vegas baby
    #4 TheMayor, Sep 18, 2011
    Don't worry. These things happen. This may not be a warranty issue but I'm sure they have a way to open it without much trouble.
    Let us know how it came out! I'm sure others would be really curious.
    You might want to invest in a new spare key. They aren't cheap but.... there you go! :)
    As to previous owners "losing" their keys --- I always wonder if they just wanted to keep it as a keepsake.
  5. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    Will do, I was busy mounting GoPro on the rear bumper to record some launch control exhaust notes. Anyway I'll post how dealer open the door and the video.
  6. TheMayor
    104,751
    Vegas baby
    Post the video of the sounds too! Good luck in getting if fixed.
  7. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    man, dealer said they cannot do anything except ordering a new key. ( on it's way )
    They said I could either break the window or break the lock.
  8. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    #8 cheesey, Sep 19, 2011
    can a recent vintage Ferrari door be opened by "jimmying" ? Is there a before or after date by which one can or cannot open a door with a "slim jim" ( break in )
    the reason for asking, is a few years back keys ( all 3 sets by wife ) were locked in. The locksmith made comments that some cars were difficult or impossible to break into without doing damage within the door. The manufacturers had made efforts to make the cars more theft proof.
    can current Ferraris be unlocked with a normal key... just to gain access ( to recover locked keys )... a normal key without electronics and programming should have nominal cost.
  9. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    Did you try the suggestion in another thread to climb through the rear seats into the trunk?
  10. deppi0
    deppi0 Formula 3
    Jun 30, 2010
    1,246
    London, UK
    Edmondo
    I think his car is locked so no access to the rear seats am I right?
  11. nfg2507
    nfg2507 Karting
    Sep 26, 2010
    215
    LA
    Peter
    Unfortunate situation :/ How long does it take to get the new key?
  12. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,482
    Austin, Texas
    Michael C
    Some Ferraris have an emergency pull cord inside the gas filler door but of course the car needs to be unlocked to access it.
  13. BigTex
    79,321
    Houston, Texas
    Bubba
    They don't 'jimmy' the door much anymore, last locksmith I called put an air bladder into the top of the door frame/roof juncture, and pumped it up the reach in a pop the door handle.
    He was quick at it too!!
  14. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,385
    ESP
    Bas
    I woulnd't be to sure on that one...
    We had the same happen with a 2010 Audi A4 last year, and I suggested breaking the window and unlock it.
    Turns out the car has a 'deadlock' system and if the window gets broken to fix the problem would cost the best part of 5K...
  15. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    Dealer told me approximately a month, probably a little more?
  16. forgeahead
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    ay ay ay.
    I would think a locksmith could pick the lock. That totally blows. I know you're kicking yourself, but I would never take delivery of a car without both keys. If not available, then the replacement is paid by the seller. I am sure that key is going to cost a couple of pennies!
  17. cockrill
    cockrill Formula 3
    1,086
    Columbia, MO
    Jeremy Cockrill
    I recommend calling some locksmiths and ask if they can pick the lock. Most won't do it as it takes forever and requires a lot of skill, but you may find one that will do it. I would NOT let anyone try to "jimmy" the lock open -- a wire may get snagged and pulled loose. (Locksmiths have books showing the internal structures of car doors to help them avoid wires, but I doubt that they have the California in their books...)
    Good luck!
  18. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    I'm a bit confused... Every contemporary Ferrari I've seen has fail safes for this situation, as long as you still have access to the cockpit. There are pull cords for the fuel fuller cap, the hood, and the trunk - often times, you'll need to release one in order to get to another, but it can be done. Check the driver's side foot well for a pull cord and pull it; if it releases the fuel filler cap, check inside there for another pull cord, and it if releases the hood, check there. If it released the trunk, problem solved.
  19. Garymyman
    Garymyman Formula Junior
    Sep 15, 2008
    302
    New Orleans
    Gray
    The last time I called pop-a-lock the guy had the door open before I had finished saying "Thanks for coming so quickly."
  20. BigTex
    79,321
    Houston, Texas
    Bubba
    There's a locksmith here in Texas that posts on 308 Section key threads.
    He has the Ferrari Code books too, maybe not on California though??
    Sorry I cannot recall his log in name ...
    Your key codes are in your books?
    Are they in the trunk?
  21. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    Thanks everyone! Decided not to break anything, will let her rest. Waiting for my new key to arrive as soon as possible. Dealer told me approximately 3 weeks.
  22. Xeron
    Xeron Formula Junior
    Jan 25, 2010
    404
    Vegas
    You're telling me a locksmith can't crack the manual lock on the door or the trunk? That seems really odd.
  23. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    what is the current procedure to introduce a new key ( programable ) to a Ferrari ?
    it used to be that ALL programable keys needed to be present during a programing session, as any previously good keys not present would be disabled
  24. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Is the car locked or just the trunk?
    I thought the Cali had a pass thru from the back seat to the trunk. So if you can get into the car you should be able to get the key. Good luck.
  25. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    The pass through must be opened from within the trunk.
    Rick
