Please Help | FerrariChat
Please Help
Discussion in 'Mondial' started by mondialqves, Dec 27, 2015.
  1. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I've been reading the discussions since long time but now I have a problem on my QV so I ask for your help for first time:
    If I turn on the lights these happens: the Parking light comes on instead of the headlight indicator. Also, the fuse for the dashboard's lights and the license plates lights burns. So, I have no license plates lights, side lights or front fog lights.
    I have checked all the bulbs and rear license plates lights and are OK. I have checked disconnecting all and still keeps burning the fuse.
    Day flashing is not working too.
    Can anyone help please?
    Many thanks in advance
  2. Russ Gould
    Russ Gould Formula 3
    1,073
    sounds like you need a new fuse box
  3. Roc
    Roc Karting
    Nov 19, 2013
    189
    Las Vegas, NV
    Rocco LaBriola
  4. moysiuan
    moysiuan F1 Rookie
    3,628
    Canada
    Try taking out the various relays and white wire connectors on the fuse box, swap out the relays for the things that are not functioning for another relay (there are three relays of the same type in the fuse box that can be swapped to work for different lights (low beam high beam and flash), and a different one for external lights (just remove and see if other things function better), in my Swiss 3.2 check your owners manual for your relay map for a QV), clean things up with electrical contact cleaner and look at the connectors for signs of blackening and such. Reinstall the bits using Deoxit contact enhancer on the relays and connector pins, and see how it goes. Worth inspecting carefully and cleaning before going for a new fuse box.
  5. davem
    davem F1 Veteran
    8,211
    Stepford, Connecticut
    dave m
    Very common. Check all affected wiring for bad ground. Start with the license plate lights
  6. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Thank you. I will check today and let you know
  7. Steve Magnusson
    25,040
    I believe that these two things might be naturally related -- i.e., the wiring architecture on models of the same era is such that if that fuse is blown (or removed), it (wrongly) causes the the parking light indicator bulb to illuminate when the stalk knob is turned "on". (Unfortunately, with the demise of ferraridatabase, I can't double-check that.)
    What might be more important here is that the +12V wires going to the rear license plate bulbs are not shorted/melted to the exhaust system -- have you checked this?
  8. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Results: have changed the relays, clean them with contact cleaner, same with the white wires connectors in the fuse box. no sign of any blackening at all. Have cleaned the ground connections in the front to the chasis too. Disconnected front fog lights and rear licence plate lights are also disconnected from the connection in the boot. no signs at all of melting. Have cleaned too the fog switch......and still burning the fuse...
    Dont know what else to do...
  9. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    Suggest to take apart your stalk switch and make sure that the wires are soldered (top and bottom) and nothing is shorting
  10. ronfrohock
    ronfrohock F1 Rookie
    3,919
    MA
    Ron Frohock
    I was thinking the same thing.......
    I know Verell fixes them if need be.
  11. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I will try today and let you know
  12. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Stalk switch is in perfect condition on both sides....I have disconnected, as i said, the rear license plates lights, may be they need to be connected to test?
    Please advise any other ideas
  13. jfrazar
    jfrazar Karting
    BANNED Rossa Subscribed
    Jun 26, 2004
    223
    Savannah, GA
    Joe Frazar
    STOP!!!!!!! Before you do more damage.
    You need to find the short first. I have fixed quite a few messed up Mondial Lighting systems and honestly this can be a rather confusing system. Do you have a wiring diagram? A multimeter, test light, probe tester.
    Some items in the system are switched on the ground circuit and others on the power side.
    Don't just start pulling relays ect. - they typically don't cause fuses to blow.
  14. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I do have multimeter, test light and probe tester. Do not have the wiring diagram, where can I get it?
    I remain waiting for your advise
  15. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Is this valid?
    Wiring Diagrams Mondial QV Euro Version | How a Car Works
  16. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
  17. porphy
    porphy Formula 3
    1,203
    LouisvilleKY/Switzld
    Randall Gatz
    Need to find the short.
  18. Jeka
    Jeka Formula 3
    1,176
    Rotterdam
    Johan
  19. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    What do you mean by the "short"?
  20. Jeka
    Jeka Formula 3
    1,176
    Rotterdam
    Johan
    There is a short circuit somewhere causing a high current resulting in a bown fuse. I will look into the schematics this evening to see if I can give some instructions.
  21. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Thank you very much! I appreciate it very much!
  22. Jeka
    Jeka Formula 3
    1,176
    Rotterdam
    Johan
    Can you tell me the number of the fuse which burns? Does the fuse also burns if you switch off all the lights? If you have no license plate lights then you probably don't have stop lights as well.
  23. FamilyCar
    FamilyCar Formula Junior
    655
    Seattle, Wa
    Peter Goodall
    #23 FamilyCar, Dec 30, 2015
    My car has the same general problem, although it does not blow fuses. I can tell you what I know, although the fuse issues is somewhat different so all I can offer is some insight on what I've found. My car is also a 3.2, but I think the systems are quite similar.
    What those lights have in common is that they are all fed from the same connection on the fuse panel. On my car, the female connection in the white plastic block had melted down. See photo. I repaired that, and it worked for a few days before it quit again. I took the fuse panel apart and determined that the track on the PC board had burned up between the fuse and the spade connection when power started going through it again--both areas were weak so fixing one just caused the next to fail.
    The connection in question is located on connector J, terminal 3. It is the lower of the two horizontal connections on the driver's side of the fuse panel. There aren't too many connections on this block--there are two wires, a pink one and a larger pink and white one. First, you could disconnect it and see if power is coning from the board by checking it at the spade connection. On the attached photo, the pen is pointing at it. If there is power there, the problem is in the wiring going to all the lights. On my car, the initial fix was that the wiring on the block side was cooked at the point of connection to the terminal block.
    With the more recent failure, I have determined that the problem is on the board. That can be verified by connecting a power source to the wiring connection on the block and seeing if the lights turn on. I suppose if there were a bad short this could cause problems, but if the source is fuse protected you should be OK.
    A few other notes: There are multiple grounds on these wiring paths so they wouldn't all go down together, or at least it is unlikely. The park indicator light has hot to both sides, so that when both circuits are energized it goes off.
    I hope this helps.
  24. FamilyCar
    655
    Seattle, Wa
    Peter Goodall
    oops, wrong photos. FYI that's Plaza Botero in Medellin, Colombia, where we just were. Here is the fuse panel
  25. FamilyCar
    655
    Seattle, Wa
    Peter Goodall
