Pista Exhaust Upgrade | Page 17 | FerrariChat
Discussion in '458 Italia/488/F8' started by dustman, Aug 13, 2019.
  1. SECRET
    SECRET Formula Junior
    935
    @Pazzo009 While you have the parts outside of the car, would you mind measuring the outer diameter (OD) of the downpipe outlet?
  2. Pazzo009
    Pazzo009 Formula Junior
    354
    Northern Atlanta Area
    Marc C
  3. SECRET
    935
    Thanks @Pazzo009! That's actually the downpipe inlet (turbo-side). Would you mind measuring the other end of the downpipe (the outlet)
  4. Pazzo009
    354
    Marc C
    I'll try to on Monday
  5. MrFloppi
    MrFloppi Karting
    Mar 15, 2014
    210
    200 cell cats? Looking forward to your experience regarding CEL light with the cats. You don’t have a ECU tune, right?
    Gesendet von iPhone mit Tapatalk
  6. Pazzo009
    354
    Marc C
    Yes, 200 cell... No tune.
    I should be okay...I'm adding mini cats (bung extensions) just for good measure. It worked on my F12
  7. MANDALAY
    MANDALAY F1 World Champ
    Owner Rossa Subscribed Silver Subscribed
    May 23, 2013
    11,082
    AUSTRALIA
    ANGELO
    Curious you gonna use the Kline remote for the valves or pin them open ?
  8. Pazzo009
    354
    Marc C
    Kline's "button" doesn't work with this system I was told. Therefore I am installing the Capristo controller. I want the capability to make it quiet if needed. The fluctuation or modulation is annoying. I prefer it to be linear.
    SECRET, MANDALAY and Shadowfax like this.
  9. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    I'm with you on this. For the sake of a few extra dollars fitting a controller it doesn't make any sense at all compromising a car of this value. I find when pushing my Pista hard it just feels better with the valves working. And if ever you need a bit of the noise toned down its so nice to have options. I reckon driving with a valve-less system would drive you nuts after a while, especially on a long run. Even on my past 488 it was so nice being able to shut it up here and there. After a while in the seat it can get very annoying with the valves open all the time.
    LARRYH and Pazzo009 like this.
  10. MrFloppi
    MrFloppi Karting
    Mar 15, 2014
    210
    Are those mini cats / bung extensions also from Kline, or which company makes them?
  11. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    100% agree with this. A controller is dirt cheap all things considered, and just clamping the valves open really feels like compromising the car. With a controller you add something extra to the cars personallity without losing anything. If one just pins them open, you lose the refinement and some performance. I mean, the Cspristo controller is cheaper than tyres, so why cut corners right?
  12. unogib
    unogib Formula Junior
    Jun 26, 2006
    403
    Hope this helps.
  13. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    Yes I'm not sure why anyone would on a car like this - makes zero sense to me. I can understand the saving of money but pegging the valves permanently open diminishes Ferraris engineering, which is what you pay for on a car like this. So basically you are robbing yourself by removing that. The valves are basically open all the time anyway when the car is being properly driven and it's really only during traffic, freeway cruising and very low rpm driving that having the valves held open provides anything positive - the rest is all negative with them permanently pegged.
    Caeruleus11 and Il Co-Pilota like this.
  14. Gh21631
    Gh21631 F1 Veteran
    8,336
    East
    Please clarify; the Kline system comes with a controller, are you saying it doesn't work?
  15. Pazzo009
    354
    Marc C
    I ordered the system through Vivid Racing. (They are pleasure to work with) Right before it shipped I was told that the "Kline button" doesn't work with the Pista and the system is intended to work with the standard pneumatic valves in place. However to manipulate that, the Capristo valve controller can be installed to either make it operate normal, closed, or open.
  16. Gh21631
    Gh21631 F1 Veteran
    8,336
    East
    Intersting, I was told directly by Kline that it does work. I guess we will find out soon enough. Good luck with your install.
    Pazzo009 likes this.
  17. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Fully closed? The Capristo? They are usually Auto and Fully open.
  18. Pazzo009
    354
    Marc C
    You might be right... I could be mistaken. I had it on my F12 and I thought I had that functionality, but I never used it and kept it on full open
  19. Lagunae92
    Lagunae92 Formula 3
    2,042
    SoCal
    I had a fully closed option until the dealer reversed the polarity so that it functioned properly. lol
    Il Co-Pilota, Pazzo009 and Jo Sta7 like this.
  20. MANDALAY
    May 23, 2013
    11,082
    AUSTRALIA
    ANGELO
    Yep the ones I saw installed had kline remotes and working fine
  21. MrFloppi
    MrFloppi Karting
    Mar 15, 2014
    210
    Any updates on the 200 cell cats and a possibility of CEL and the manufacture of the mini cats?
  22. Pazzo009
    354
    Marc C
  23. mdrums
    mdrums Formula 3
    Jun 11, 2006
    2,220
    Tampa FL
    Pazzo009 your Pista is going to sound awesome!
    Caeruleus11, Lagunae92 and Pazzo009 like this.
  24. Jo Sta7
    Jo Sta7 F1 Rookie
    4,917
    Scottsdale/Pittsburgh
    Jon
    The Kline system is so much nicer looking than the stock system.
    Caeruleus11 and Lagunae92 like this.
  25. Gh21631
    Gh21631 F1 Veteran
    8,336
    East
    Mnfr exhaust systems seem to be an afterthought sometimes.
    Caeruleus11 and Jo Sta7 like this.
