Pilot Dies From Hand-Propping Propeller Accident | FerrariChat
Discussion in 'Aviation Chat' started by toggie, Jan 31, 2012.
  1. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Pilot Dies From Hand-Propping Propeller Accident.
    First of all, condolences to his family.
    This seems to happen every couple of years or so, somewhere in the country.
    I've seen it done well at my flight school but I've never personally hand-propped a plane.
    Obviously something only a well-trained pilot ought to do.
    Here's the news article:
    http://www.nbcsandiego.com/news/local/Pilot-Struck-by-Airplane-Propeller-Gillespie-Field-138340604.html
    Pilot Dies From Propeller Strike.
    A pilot died Monday after he was struck in the head by a moving airplane propeller, according to officials.
    The single-engine plane pilot was struck in the head after he got out of his aircraft in the ramp area of Gillespie Field in El Cajon east of San Diego.
    Gordon Woodard, 41, was taken to the hospital with critical injuries where he died later, according to airport spokesperson Ian Gregor.
    Woodard realized the engine had stalled after pulling it out of the hangar.
    "We believe he got out of the plane to manually start the propeller," said Gregor in a statement. "When the propeller engaged, it struck him in the head."
    In the aviation industry, starting the engine manually is called "hot propping," and is generally considered very dangerous.
    "If the aircraft is not able to start, whether it's here or it's somewhere else across country, we have a policy," said Tom Hannawa of the American Aviation Academy. "No touching of the propeller to start, no hand-propping to start the engine. it's a very dangerous practice."
    A helicopter instructor along with a student witnessed the accident according to Hannawa.
    "They were very traumatized," Hannawa said. "We're going to let them have as much time as they need to recover because it was a very traumatic experience for them."
    Pilot Mark Hanten's hangar is next to the space used by Woodard.
    "It just gives us pause to be a little more cautious when we fly," Hanten said.
    Several pilots told NBCSanDiego they would never try to move the propeller by hand.
    "Hopefully other people will learn from this mistake and it won't happen to somebody else," Hanten said.
    The Federal Aviation Administration and National Transportation Safety Board will investigate this accident, Gregor said.
  2. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,015
    Shoreline,Washington
    Robert Parks
    I can not count the times that I have hand propped an airplane. That was the only way that you could start them. There were/are techniques and procedures to which you adhered and you simply did them. I don't know how he got his head in the path of the blade other than falling forward which you could probably do if you were attempting a hand prop start from the back side which is dangerous. I have hand propped everything you can think of including WW1 rotary's and an AT-6 (done on a $15.00 bet). Old procedures have slipped past us with all the fancy modern stuff and I recognize that. Very sorry for the guy's family.
  3. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,152
    Seattle Area
    Dave
    First off, sincere condolences to his family....
    So help me understand WHY he would have done this? I must assume the plane
    has electric start.... so if it won't start with the key, why would you take this risk
    and not just park it and charge the batteries. Not to mention, back in my "poor days"
    when I couldn't afford new batteries until the very end of them, I learned the hard
    way that a totally flat battery will just stall the car out anyway, so push starting
    was not a good option... is that effectively what he might have been doing?
    Just seems to me in the world of planes, ANYTHING significant not working on the
    ground - stalling coming out of the hangar, or a totally flat battery - just seems
    utter common sense - STAY ON THE GROUND AND FIX IT.
    Help me understand....
    Jedi
  4. Jason Crandall
    Jason Crandall F1 Veteran
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    I have no idea why someone would do this. The cons really outweigh the pros.
  5. Bob Parks
    Nov 29, 2003
    8,015
    Robert Parks
    Many seaplane pilots have to crank the prop from the back side while standing on the float but you have to maintain balance and a backward movement when you're flipping the prop. I was told early on when I was a snot nosed kid that you don't even TOUCH a hot prop even when the switches are off.
  6. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,652
    The fabulous PNW
    Han Solo
    I learned how on an Aeronca Champ when I was 12 years old. (These do not have electric starters)
    I am sure it's a bit trickier on the larger stuff.
  7. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Propping a plane is dangerous, but Bob and Spasso are living proof that it can be done and you can live to tell about it. I learned it from an "old timer" and there are things you can do to make it a lot safer. With the technology around today there aren't many times that you need to do it anymore. While an airplane can be propped and started, modern electronics and charging systems need a proper battery to work, so even if you start it, you can easily find yourself without any electricty on the airplane when you get halfway to where you are going... (don't ask me how I know)...
  8. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    ^^ agree with the above.
    In fact, during flight training, the instructors go out of their way to emphasize the potential danger of turning the prop and general prop/plane safety issues.
    The discussion typically includes:
    - how the ignition key controls the circuit to the magneto p-leads and that a failure in that circuit means the magnetos are active (the exact opposite of what a novice might think).
    - when you get out of the plane, take the keys with you (or place them where they are visible on top of the panel).
    - always shut down an engine by starving it for fuel (mixture full off). This adds a level of safety in that the engine typically must turn-over a few times to get the fuel fully flowing again.
    - if you must turn a prop, e.g. to attach the nose wheel pull handle, turn the prop slowly, for a short distance, in the opposite direction of the direction it turns when the engine is running (on a Cessna 172 or 182, this is clockwise when standing in front of the plane).
    - never place part of your body within the arc of the prop, even if the engine is off. Stay clear, either to the front or back, or well to the side of it, when walking around the plane or doing the preflight inspection.
  9. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Just a speculative question - but did he have the plane tied down when he hand propped it?
  10. Bob Parks
    Nov 29, 2003
    8,015
    Robert Parks
    I have been thinking about that, too. If the plane was tied down , was it tied at the tail? All three points? I have seen several disastrous incidents where an airplane was tied down with one wing rope and with an advanced throttle. On one pull it started and somehow missed the idiot in front of it and proceeded to turn itself into a super big control line model, flying around in a circle. Sadly, we had to run a truck into it to stop it before it broke loose and killed somebody. The process of hand propping an airplane when you are alone is simply all bad but if it has to be done, the tiedown should be at the tail. If you can get the airplane is started , it should be brought to a slow warm idle and then remove the rope. I had to do it a couple of times when we were moving a lot of airplanes out of the path of a hurricane but it is a dumb thing to do if you can get assistance.
    One of the mistakes that some folks make is not getting close enough to the prop before swinging it. We used to call for switches off and wait for a positive reply. If the airplane had been primed , swing the prop thru several blades and position it on a compression stroke of a cylinder that allows you to comfortably get a good pull on the blade...not too high and NEVER TOO LOW but something near a 245 deg angle.
    Call for brakes, throttle cracked, and LEFT MAG. That one is retarded several degrees past TDC and if it fires quickly the piston is on the downward part of the power stroke and less likely to pop backwards.Wait for the pilot to repeat your instructions. Then address the prop with both hands, fingers barely around the trailing edge of the blade. Put your right leg forward under the nose and aggressively swing the blade at the same time that you swing your right leg back. Follow through with your arms in a direction that swings your body away from the prop disc. NEVER turn your back to a spinning propeller.
    I guess that I am reliving the many times that I have cranked Stearmans and other big ol' clunks. The worst prop blade to hand crank is a steel Macauly on a Stearman...very sharp trailing edge.
  11. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I read a truly heart-stopping story about hand propping by yourself in the old flying magazine section called "I learned about flying from that" -
    The guy kind of slipped on some ice and fell forward onto the spinner with the engine running. He was not hit but all he could do was shuffle backward a little at a time and hope that he had it tied down at the tail. In his panic, he really couldn't remember.
    Finally, he got back far enough that the plane ran out of rope (it was tied at the tail after all) and he got away from it.
    Time to shut it down and call it a day after that one, I would think.
    EDIT to add: The reason I wondered was the original description - it sounded like he just pushed it out of his hanger and tried to prop it right outside the door. Where I would doubt if there were tiedowns handy.
  12. Jedi
    Jedi Moderator
    Mar 18, 2008
    32,152
    Seattle Area
    Dave
    I'm still not understanding the WHY of it. If the plane has electric start, and for some
    reason that's not starting the plane, and no hurricane is forcing planes to be started
    without keys, WHY WOULD ANYONE DO THIS? Why wouldn't he have fixed whatever
    wasn't working FIRST, so the plane would start from a key?
    I'm sorry if it's a dumb question, but I just don't get it. :confused:
    Jedi
  13. Bob Parks
    Nov 29, 2003
    8,015
    Robert Parks
    I got to thinking about the nastiest airplanes to crank up and first in my mind is the Ryan P-22, a Kinner with and impulse mag and a light weight wooden prop. You had to be really aggressive when pulling the prop because when that impulse mag kicked in it real took off. Kick-back was another dangerous part of the PT-22's personality.
  14. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I hate to admit it, but I have been stuck at an unmanned field with a bad alternator and had to charge the battery enough to crank the plane, then turn everything electrical off and just fly on the mags to get back to civilization.
    At night. A nice, clear, moonlit night with plenty of well-lit towns and roads to follow.
    But still ---
  15. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Yep, I suspect it was done just to save time.
    If the airport he was at had fuel services, they usually have the ability to jump start a plane if you run the battery down trying to start it yourself.
    On a Cessna, there is a plug cover on the side of the engine cowling where the jumper cable plugs into.
    The line guy comes out, plugs in the jumper cable, you sit at the controls and start the engine, then the line guy CAREFULLY walks up the side of the plane and reaches forward and unplugs the jumper cable. His hand is only about 18 inches behind the spinning prop at that moment.
    Once everyone is totally clear of the plane, you yell thanks to the line guy out the window, wave, and go taxi to take-off.
    This assumes you have a working alternator to fully recharge the battery once the engine gets going.
    I've seen two scenarios in running down a good battery, a stubborn cold start in the winter time and a hot start where the pilot floods the engine.
  16. Bob Parks
    Nov 29, 2003
    8,015
    Robert Parks
    This conversation triggered another incident that I had forgotten over the years. I was propping a Stearman that had an instructor and student aboard. After priming and pulling it through and getting a blade in a good position I yelled contact and brakes. As I stepped up to the prop and was in the process of reaching out for the blade, the engine kicked off and started. The contortions and ballet that I went through trying to miss the prop must have been comical but somehow there was no contact with the prop. The airplane had a booster magneto that the instructor started energizing before I had swung the propeller--not afterward as he was supposed to do. The charge in the cylinder and the position of the piston was just right to crank up the engine. After two years in the service without getting hurt too bad, it would have ironic to get it when i was a civilian cranking up an airplane with an idiot aboard.
  17. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Here's another hand-propping incident story I found online.
    This February 2010 accident report is provided by the National Transportation Safety Board. Published as an educational tool, it is intended to help pilots learn from the misfortunes of others.
    Aircraft: Bellanca 7ECA, Luscombe. Injuries: None. Location: Canon, Ga. Aircraft damage: Substantial.
    What reportedly happened: The pilot of the Bellanca was sitting in the cockpit of his airplane with the engine running. He heard an engine rev and looked to the left to see an unoccupied Luscombe taxiing toward him.
    The Bellanca pilot applied full throttle but wasn’t able to get out of the path of the runaway airplane. The propeller of the Luscombe hit the Bellanca’s left wing. The Bellanca sustained substantial damage. There was minor damage to the Luscombe’s propeller and engine cowling.
    The pilot of the Luscombe was a private pilot with 881 hours, including 238 in the Luscombe. He told investigators that he had chocked the wheels of his airplane and then hand-propped it to start the engine. The engine started at a high power setting, and the airplane jumped the chocks.
    Review of the FAA Airplane Flying Handbook (FAA-H-8083-3A) revealed, “An engine should not be hand propped unless two people, both familiar with the airplane and hand propping techniques, are available to perform the procedure. The person pulling the propeller blades through directs all activity and is in charge of the procedure. The other person, thoroughly familiar with the controls, must be seated in the airplane with the brakes set. The procedure should never be attempted alone.”
    Probable cause: The Luscombe pilot’s improper engine starting procedures.
  18. donv
    donv Two Time F1 World Champ
    25,752
    Portland, Oregon
    Don
    Well, there are several possibilities. First of all, the article doesn't say what kind of airplane it is. Perhaps it didn't have an electrical system, in which case hand propping is the only way to start it?
    Perhaps the battery was dead?
    Perhaps the starter was broken or intermittent?
    I've hand-propped quite a few airplanes in my younger days. It's not a big deal, depending on the airplane.
    One thing I have never done, however, is hand propped without someone manning the brakes and throttle.
  19. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Yup - I was taught that you never did this without a qualified person in the pilots seat, and also you really should have the plane tied down. At the very least - one or the other.
    You know - these accidents crop up with a really discouraging regularity. It would seem that this should be one of the most avoidable of flying mishaps...and yet it still happens.
  20. klatu
    klatu Formula Junior
    Apr 13, 2009
    277
    San Diego
    Rob Mckinney
    I was 15 when I was taking my first lessons. Lived in a small town in NE, and we had a muni ap. No radio, no tower, just the young boy pumping the fuel. In 53 there were many planes that had no electrical system, cubs, airknockers and so on. I was the young boy pumping the fuel and propping the planes as part of my job, as I was working for my lessons. We had one guy that had a Mooney Mite. Very small plane. He would never let me prop his plane. He would stand on the port side in front of the wing with his hand in the cockpit on the throttle and his left hand on the prop. It is a low wing with a canopy, his arm was in the cockpit to keep him from falling into the prop.
    The hardest one I ever did, was a Navion with a 440 engine, man I had to pull that thing maybe 4 times before it fired.
    My home base is Gillespee, I will find out exactly what happened, and report, you know how busybody small airports are.
    Klatu
  21. UncleRay
    UncleRay Karting
    Dec 28, 2009
    203
    Hastings, Minn.
    Condolences to the family........nasty business when not done correctly. I rode the front seat of an older biplane back in the early '70's (a Great Lakes IIRC) with radial engine and my buddy did the proping chores. He knew what he was doing, instructions to me were very specific and he did it very well. Flew out of Lake Elmo, Minn. and did touch and goes at various strips around the area.....Open cockpit experience....very memorable.
  22. Tcar
    Tcar F1 Rookie
    I'll bet these accidents were pretty common during WWI when propping was the only way to start many planes.
  23. Bob Parks
    Nov 29, 2003
    8,015
    Robert Parks
    Those who operated airplanes without electric starters were thoroughly trained and adhered to their instructions. Hand propping was an integral part of flying and part of your training. There were no impulse mags or light wooden props. Props were slower and heavier and they were respected for the danger that they possessed.I don't remember anyone getting hurt or killed when I was a kid and hand propping many many airplanes.
  24. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Yes, hand-propping is mostly a lost art these days. Kind of like kick-starting a motorcycle.
  25. Bob Parks
    Nov 29, 2003
    8,015
    Robert Parks
    Looking back at the steps used to check if your calls were accomplished. Pushing back on the airplane at the prop hub to ascertain that the brakes were applied after calling " Brakes and Contact." Sometimes when you weren't sure if the switches were off you deftly moved a blade to see if it moved on its own...even a little bit from a hot charge in one of the cylinders. You never wrapped your fingers around the trailing edge of the blade in case of a kick-back that could break a finger (s) or pull you into the prop when it kicked off. I have a friend who broke four of the five fingers on one hand when the prop kicked back when he was reaching out to give it another crank.
