News
PIA A320 crash into residential neighborhood in Karachi
Discussion in 'AviatorChat.com' started by TheMayor, May 22, 2020.
  1. TheMayor
    TheMayor Seven Time F1 World Champ
    76,176
    Vegas baby
  2. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    6,653
    Shoreline,Washington
    Robert Parks
    Juan Browne, a pilot for AA , has posted on YouTube a well done analysis of the PIA 320 crash with in-flight photos that show heavy damage to the underside of both engine nacelles from a "rescued" wheels up landing on the first attempt. The RAT is also deployed, indicating loss of systems. The engines quit before the go around was completed and post crash photos shows a lack of rotational blade damage to the intake compressors. Big screw up.
    Tcar, Ney and donv like this.
  3. tazandjan
    Owner Lifetime Rossa
    31,781
    Third world airlines are really scary.
    kylec likes this.
  4. donv
    donv F1 World Champ
    Rossa Subscribed Owner
    Jan 5, 2002
    19,196
    Portland, Oregon
    Don
    Apparently, there is a lot of important stuff at the bottom of the nacelle, including the high pressure fuel pump.
  5. RWP137
    RWP137 Formula 3
    1,298
    AZ
    Rick
    So, are they going to ground all of the A320’s like they did the MAX?
  6. GrigioGuy
    GrigioGuy Splenda Daddy
    Global Moderator Owner
    Nov 26, 2001
    23,714
    E ' ' '/ F
    Yes, I have one
    Big difference between "hidden design flaw" and "flew the plane into the ground, broke the engines, and lifted off again"
    afterburner, tritone, jcurry and 3 others like this.
  7. Bob Parks
    Nov 29, 2003
    6,653
    Robert Parks
    I'm not familiar with CFM56 layout but most engines do have system drives on the bottom of the engine. I would imagine that there could have been some engine case deformation also.
  8. tazandjan
    31,781
    Guys must have been deaf not to hear that gear warning horn.
    But then one F-105 pilot I knew said "That horn was making so much noise I could not hear myself think" as he landed gear up.
  9. Bob Parks
    Nov 29, 2003
    6,653
    Robert Parks
    Listening to the video while the pilot was announcing his first approach you can hear the landing gear warning horn beeping in the background.
    BigTex and furmano like this.
  10. tazandjan
    31,781
    I only heard it once in my career and it was in an F-111F. I was expecting it, since the AC had done everything backwards (flaps and slats down first), and merely told him "You might want to put the gear down" when the horn went off.
  11. RWP137
    RWP137 Formula 3
    1,298
    AZ
    Rick
    Cause of the 3 accidents was pilot error. Contributing factors were different.
    My opinion of course...
    Jaguar36 likes this.
  12. tazandjan
    31,781
    Especially since the fault had occurred on one of the crash aircraft before and they were able to figure it out. Too bad maintenance did not fix the issue.
  13. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    12,682
    Do we know the definite reason for the aborted first landing attempt? Was it an issue prior to the engines contacting the ground or was the landing aborted because of the engines touching the ground? Would the landing gear alarm sound if the lever was put into the down position and the gear failed to deploy somehow? They should be able to open via gravity alone and rear gears lock by rolling the plane both ways (front locks via air resistance pushing it back).
  14. Bob Parks
    Nov 29, 2003
    6,653
    Robert Parks
    The video clearly shows heavy damage to the undersides both engine nacelles and the RAT deployed after the first attempt to land. Audio of the pilot while making that approach clearly has the sounds of the landing gear warning horn beeping indicating that the gear was not down or that there was a malfunction. To me, that would indicate a go around. I'm not a professional airline pilot so those are my personal impressions.
  15. tazandjan
    31,781
    With the handle down and the gear still up, you should still get the gear warning horn as well as red lights in the indicators. Often it takes quite a bit of time to get the gear down using alternate/back-up extension, and even longer to get a down and locked indication.
    BMW.SauberF1Team likes this.
  16. Bob Parks
    Nov 29, 2003
    6,653
    Robert Parks
    I just looked at another link and it had an illustration of the accessory drive gear boxes on the lower sides of the CFM-56 and from what I can discern, if there were a ground strike of any force, it would wreck the gear boxes and disable hydraulics, electrical, fuel, and anything else that they drove. That is why the RAT was automatically deployed. Again, my impressions.
  17. Tcar
    Tcar F1 Rookie
    Also, if you look at the video of the plane going down short of the runway on it's second attempt with engines out, the gear is clearly down.
  18. tazandjan
    31,781
    Always good to get the gear down for the second landing.
    afterburner and wrxmike like this.
  19. Gatorrari
    Gatorrari F1 World Champ
    13,423
    Georgia
    Jim Pernikoff
    There is already an animation out:
  20. donv
    donv F1 World Champ
    Jan 5, 2002
    19,196
    Portland, Oregon
    Don
    That is exactly what I have heard from some A320 pilots.
  21. Tcar
    Tcar F1 Rookie
    There are several big errors in that animation. That we already know about.
  22. Bob Parks
    Nov 29, 2003
    6,653
    Robert Parks
    The P&W JT3, JT4, and JT8 have a centrally located accessory drive that protrudes enough to cause the belly in the nacelle loft. Ground contact would have wiped that out as well as a lot of the high stage compressor case. I supervised the systems installation drawings on these engines and I got to know them pretty well but sometimes my memory loses some of the details.
  23. Gatorrari
    13,423
    Georgia
    Jim Pernikoff
    Of course, on the 737-300 and subq, the low ground clearance required all the accessory drives to be moved to either side of the CFM56s, so if they had done this with one of those aircraft, they might have gotten away with it. But the A320 never had that ground-clearance problem.
  24. red27
    red27 Formula Junior
    Sep 7, 2010
    556
    London UK
    Mark Oliver
