Perez to Redbull, Albon becomes reserve driver | FerrariChat
Discussion in 'F1' started by Nsd991, Dec 13, 2020.
  1. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    20,839
    Corpus Christi, Tx.
    Joe R Gonzales
    Nsd991 likes this.
  2. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    38,812
    Huntsville, AL., USA
    Andrew
    It would be good to see Perez with a drive next year. His team was crazy to drop him.
    All the best,
    Andrew.
    DF1 and jgonzalesm6 like this.
  3. piolaxo
    piolaxo Formula Junior
    Feb 24, 2012
    558
    Bay Area
    Salvador
    Best news after the DNF today...!
    Manda racing likes this.
  4. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    41,426
    ESP
    Bas
    Like I said....:)
    PureEuroM3 and JStone414 like this.
  5. DF1
    DF1 Two Time F1 World Champ
    Well you how the impulsive Billionaire can be :)
  6. 375+
    375+ F1 World Champ
    12,059
    Makes you wonder what Tracing Point could do next season with Seb and Checo . . .
  7. DF1
    Difficult to defeat the millennial family 'experience' - Billionaire style
  8. PureEuroM3
    PureEuroM3 F1 Veteran
    8,804
    Toronto, Ontario, Canada
    Thomas
    Yessir you called it...now let it come to fruition.
    Bas likes this.
  9. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    48,613
    @ the wheel
    Andreas
    No it doesn't.
  10. DF1
    6. Albon's closing statement at Red Bull was good, but hardly convincing
    Red Bull always said it would give Alexander Albon until the end of the season to impress for a seat for 2021, making Abu Dhabi his final opportunity to plead his case.
    Albon finished fourth, which is really the bare minimum for a Red Bull driver, and went on a rapid late charge to put Hamilton under a bit of pressure in third, cutting the gap from nine seconds to just 1.5 seconds late on.
    He did well to pass Norris in the first stint, ensuring he did not get stuck behind the McLaren under the safety car, but by that time, the Mercedes cars were already a long way up the road.
    Thankfully for Red Bull, Verstappen's pace was so good that split strategies wouldn't have been enough for Mercedes - but had it been, Albon likely would not have been there to play rear-gunner and help his team-mate out.
    It again highlights the issue Red Bull is facing. A decision is not thought to be too far off regarding Albon, who could be replaced by Perez, but it hardly has a strong enough case from the Anglo-Thai racer to go on.
    https://www.autosport.com/f1/news/154195/10-things-we-learned-from-the-abu-dhabi-grand-prix
  11. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,198
    Cheshire
    This would make a lot of sense. Redbull is a disaster for youngsters. They need someone like Perez that won’t be phased by the aura of max.
    tifosi12 likes this.
  12. tifosi12
    Oct 3, 2002
    48,613
    @ the wheel
    Andreas
    Gasly can attest to that.
    subirg likes this.
  13. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,267
    Finally, a real second driver for Red BUll.
  14. fatbillybob
    Aug 10, 2002
    26,420
    socal
    I'm kinda torn. If I owned the team Albon's position is the teams fault. The team needed to do what was done in last race. They needed Albon's Q2 qualy to always be on the faster tire. They needed to put their hope in Max. They needed to get Albon into P4 qualy or better to mess up cover off mercedez strategy like what happened last race. The team lets albon qualify as fast as possible and it does not owrk out for Albon or the team. They should groom albon for #2. Perez will try and win. If close to max there will be fireworks that will not benefit the team. RB mismanaged albon.
  15. Bas
    Mar 24, 2008
    41,426
    ESP
    Bas
    Albon was never meant to be a challenge for Max, they didn't expect Gasly or Albon to do so anyways. Both Gasly and Albon failed to do a good enough job to do exactly as you say: Qualify and race close enough so that the Mercs didn't have all the strategy options.
    Both Gasly and Albon have failed significantly in their qualifying efforts, and that's not because of Red Bull failure in them: Often Max has vastly outqualified both of them whilst he was on the slower tyre, both Albon/Gasly finding it necessary to use the softer tyre to get out of Q2 and still not managing.
    And then it comes to race pace where their completely inability to get to grips with the car is exploited: Both have been lapped in multiple races by Max, who was on his way to podiums or wins whilst they barely got any points.
    The Red Bull since 2019 has been a difficult car to drive. The aero is quite instable which leads to sudden unexpected spins. Both Gasly and Albon couldn't handle this very well and drove below the cars ability, which in turn means the slower cars are able to fight them quite easily. The obvious fix for that would be to make the car more aerodynamically stable, but there isn't really a quick fix for that. Well there is, but that quite simply means the car will be slower...and then you're dealing with another problem altogether: Do you follow the path of making the car easier to drive but slower, or do you make it difficult but fast? Clearly with 1 driver demonstrating he can hustle the car and comfortably finish on the podium so long there aren't any car problems, you take the latter path and hope the #2 driver adapts.
    Neither #2 driver could adapt, I also don't see any point bringing Gasly back to a car he couldn't drive before, so their only real option is to get another driver. I'm sure they got Perez for pennies on the dollar. Presumably a 1 year deal, if he can't drive the car so well either, they can always re-introduce Albon whenever they feel like it.
    subirg, tifosi12 and Nembo1777 like this.
  16. zygomatic
    zygomatic F1 Rookie
    4,855
    Washington, DC
    Chris
    Gasly and Albon in Alpha Tauri could provide a great "junior B" team in 2021. Franz Tost and the team there do seem to be able to provide something -- consistency, feedback, a less fraught atmosphere, cuddles -- that, along with good equipment, helps his drivers do well. Look at how well Gasly has decompressed there. I wonder if he can do the same with Albon....
    Igor Ound likes this.
  17. william
    william Two Time F1 World Champ
    25,594
    If the deal goes ahead, Sergio Perez may get something out of his sacking.
    The Red Bull car seems to be superior to a Racing Point.
    Although dealing with RB management can be daunting for young driver, Sergio has enough experience not to be pushed around, IMO.
    E60 M5, ktu and tifosi12 like this.
  18. tifosi12
    Oct 3, 2002
    48,613
    @ the wheel
    Andreas
    Welcome back william. You were missed on here. How was Abu Dhabi? :)
    william likes this.
  19. william
    25,594
    Thanks.
    I thought about not coming back to be honest.
    I am looking for a F1 forum that is more than a gossip column to discuss dress code, hair implant and musical choices.
    cairns likes this.
  20. tifosi12
    Oct 3, 2002
    48,613
    @ the wheel
    Andreas
    I'm glad you changed your mind. This forum needs your (occasionally contrarian) voice to stay honest.
    cairns, subirg, E60 M5 and 1 other person like this.
  21. ktu
    ktu F1 Rookie
    May 30, 2012
    3,924
    Welcome back! Yeah its been business as usual here
    cairns and william like this.
  22. simpen
    simpen Formula Junior
    Jun 14, 2016
    291
    I sure hope that hiring Perez also means sacking Marko. Alpha Tauri does not deliver the required talent to justify it to consider it a development team for the A-team. But in good RB tradition of both having and eating the cake, that will certainly not happen :) Maybe their tactics is to attract more sponsor-drivers and put all their money on Max?
  23. PureEuroM3
    8,804
    Thomas
    LOL oh that was a good one! Welcome back.
    william likes this.
  24. zygomatic
    zygomatic F1 Rookie
    4,855
    Washington, DC
    Chris
    That, and Sergio has shown that he can achieve when he isn't the team's focus.
    william likes this.
