Pennzoil Platinum Euro 5w-40 reformulated, no longer Ferrari approved | Page 2 | FerrariChat
Discussion in '360/430' started by f355spider, May 18, 2019.
  1. goto35march
    goto35march Karting
    Jul 23, 2009
    227
    mobile 1 5w-40?
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    Mobil 1 0W-40, European car formula. Mobil 1 is the factory fill in Mercedes, Porsche and Corvette.
  3. tazandjan
    39,007
    Any good 5W-40 or 0W-40 full synthetic will work fine, including the one that no longer has the little Ferrari emblem on the container. I use Valvoline 5W-40 full synthetic. Works great and no foaming.
    I'm 360 Canuck and Need4Spd like this.
  4. f355spider
    f355spider F1 World Champ
    18,027
    One of the important specifications would be the High-Temperature/High-Shear rating. Since the Ferrari approved oils also have the BMW LL-01 rating, you can extrapolate the HTHS as being greater than 3.5, which is required to meet LL-01. I would seek an oil with a similar rating. Ideally, a 0w-40 or 5w-40 with either an LL-01 rating or in the alternative, an HTHS of 3.5 or greater.
    flash32 likes this.
  5. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    I have my last batch of Pennzoil with the Logo that's going in the 360 next month. After that, I plan on using Castrol Edge 5W40. This is what I've been using for years in my other Europeans (Mercedes, Porsche and VW). I buy at Walmart for $24.97 for 5Qt Jug... https://www.walmart.com/ip/Castrol-EDGE-5W-40-Advanced-Full-Synthetic-Motor-Oil-5-Quarts/145736795
    It has all the proper high end German requirements FWIW.
    • API CF / SN
    • ACEA A3/B4
    • BMW Longlife-01
    • MB-Approval 229.3
    • Porsche A40
    • VW 502 00 / 505 00
    f355spider and Need4Spd like this.
  6. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    911
    Georgia
    Mark Gronsbell
    Several things spring to mind. The factory fill in the U.S. for Corvettes is 0W40 but not the Mobil 1 European car 0W40 but rather the new Dexos 2 Mobil 1 ESP 0W40 which is a different product formula for emission equipment preservation. Additionally, Ferrari specs 5W40 not 0W40.
    I'm 360 Canuck likes this.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    +1 for Castrol Edge 5W40. Putting it in my Cayman and 355.
  8. f355spider
    18,027
    There is generally no issue with a 0W-40 over a 5W-40. All that means is upon cold start, the 0W will have better flow as it is not as thick as a 5W before warming to operating temperature. Both will thin to a 40 weight at operating temperature.
    flash32, Flea7 and I'm 360 Canuck like this.
  9. f355spider
    18,027
    #34 f355spider, Apr 20, 2020
    The Castro Edge 0w-40 has even better specs, as it has the more stringent MB Approval 229.5 (lower soot, piston deposits, etc). It is claimed to also have a better base stock than the Castrol Edge 5W-40. But, it lost the BMW LL-01 approval when it was reformulated last year, presumably to meet the newer MB 229.5. It still has an HTHS of 3.5
    ACEA A3/B3, A3/B4 API SN/CF Meets Ford WSS-M2C937-A MB-Approval 229.3/ 229.5 Porsche A40 VW 502 00 / 505 00
    Lots of discussions comparing the Castrol Edge 0w-40 versus the 5w-40 on Bobistheoilguy.com forum and on the BMW forums. Even without the LL-01, many users believe the 0w-40 is the superior choice for BMWs and other european cars.
  10. tazandjan
    39,007
    Mark- Ferrari specifies 5W-40 or 0W-40 for the 360 and 575M. This is copied from the 2003 360 OM:
    Motor
    Capacità totale impianto 2.63 USgallon (9,95 l)
    System total capacity
    Capacité totale du circuit
    Capacidad total de la instalación
    Shell HELIX ULTRA
    SAE 5W-40
    or SAE 0W-40
    Caphill likes this.
  11. Doctor Mark
    Dec 15, 2005
    911
    Georgia
    Mark Gronsbell
    Thank you for calling that to my attention
  12. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    Hopefully you guys kept the "ferrrari approved" empty bottles.
    That way, when your car is sleeping, or Enzos ghost is visiting one of his mistress-ghosts, you can pour some other oil into them before later pouring it into your car, so noone is the wiser <wink>.
    Mario Andretti, Penzinger and flash32 like this.
  13. Dragster
    Dragster Formula Junior
    Jun 8, 2007
    501
    Charlotte, NC
    I know this is coming in over a year later, but you can select "old packaging" when you order this from Amazon.
    Does anyone know if the oil has actually been reformulated or has the packaging just been updated?
  14. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,068
    Josh @jtcarprojects
    Redline or motoul sport are true ester based group V . All most all that other stuff is group III
  15. goto35march
    goto35march Karting
    Jul 23, 2009
    227
    what oil is now used at the actual ferrari dealership?
  16. Mario Andretti
    Mario Andretti Formula 3
    1,739
    Boston
  17. f355spider
    18,027
    #42 f355spider, Oct 18, 2021
    It is, but the Pennzoil documentation is inconsistent. The PDF I linked in the first post shows it is not approved. But their advertising literature states their 5w-40 Euro is Ferrari approved. Its confusing.
  18. RedTaxi
    RedTaxi F1 Rookie
    3,307
    New Zealand
    Glen
    Another vote for Castrol Edge. I use it in everything. Stays clean, doesn't foam, doesn't burn. Been impressed for many years. Might try the 0-40 in the 430. Way more expensive than the 5-40 so must be better. :) Ran 5-40 in my AMG V8 and it didn't like it. Noisy lifters till warm. Switched to 0-40, problem solved.
  19. 67bmer
    67bmer F1 Rookie
    2,676
    MD
    I ordered some pennzoil from Amazon with the Ferrari logo and got the regular pennzoil without the logo.
  20. 67bmer
    67bmer F1 Rookie
    2,676
    MD
    Ps. I returned it because it wasn’t what I ordered for $5/qt more than the regular.
  21. f355spider
    18,027
    #46 f355spider, Oct 18, 2021
    You have to order the "old packaging" to get the earlier version with the Ferrari logo.
    https://www.amazon.com/Pennzoil-Platinum-Synthetic-5W-40-1-Quart/dp/B00JMCCBRW/ref=asc_df_B00JMCCBRW/?tag=hyprod-20&linkCode=df0&hvadid=242667734520&hvpos=&hvnetw=g&hvrand=17881286599472112673&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9033345&hvtargid=pla-442607056057&psc=1
    I emailed Pennzoil and asked if there was truly a difference between the products
  22. f355spider
    18,027
    BTW, if you go to the Pennzoil website and enter a Ferrari model into their look up, instead of recommending the Euro 5w-40 like it used to, it now says to call their technical support at an 800 number.
  23. Mario Andretti
    1,739
    Boston
    I did so; and got the non-Ferrari packaging... I think it's the same thing, and we're picking straws. It is good oil, and how long are we going to run it, 15k miles? no, it will be out next year at yearly fluid change, with most likely less than 3k miles on it. Still has all the Fiat , BMW, Porsche, etc approvals on it.
  24. Mario Andretti
    1,739
    Boston
    To be honest, if I would try something else, I would do the Liqui Molly Liechtlauf High Tech 5w-40. It is on recommendation list for Ferrari F430. LM is superb, my M3 does not burn any, and it's quiet as a mouse with this oil (of course; different weight, for M3 is 10w-60).
  25. Mario Andretti
    1,739
    Boston
