Passenger compartment glove box not opening | FerrariChat
Discussion in '360/430' started by Razmatazz, May 1, 2021.
  1. Razmatazz
    Razmatazz Rookie
    Apr 29, 2020
    14
    Hello, I tried to do a search but nothing was coming up that had an answer.
    Can’t seem to open it
    - the car is on
    - the associated fuse looks ok in the front trunk when removed but I don’t have a multimeter- visually doesn’t look blown
    - there is no string for the manual release - either it was removed or broken off but it’s no where visible even if I get underneath and dig around
    - I am not sure on how to remove the relay that’s associated with the passenger glove box compartment or how to test that
    Is my only option unscrew the glove box and attach a manual release for now ?
  2. Qavion
    Qavion F1 World Champ
    11,550
    Ian Riddell
    #2 Qavion, May 1, 2021
    The relay just unplugs like a regular automotive relay. If you don't know if the fuse is ok, try interchanging it with, say, the horn fuse (AF10).
    If that doesn't work, you could interchange the glovebox relay with the horn relay (AR12). The horn and glovebox fuses and relays have the same power rating.
    Razmatazz likes this.
  3. Qavion
    11,550
    Ian Riddell
  4. Razmatazz
    Razmatazz Rookie
    Apr 29, 2020
    14
    I’ll give this a try thank you
  5. Qavion
    11,550
    Ian Riddell
    Sorry, I forgot to ask something more basic... Is your ignition turned on? On the F360, I believe the spider only requires the ignition to be on, but I'm not sure about the F430. I only have one wiring diagram for the F430 glovebox and the diagram doesn't specify if it's for the spider or the coupe. Oddly, I found the diagram in a Scuderia manual which doesn't even have a passenger glovebox.
    Maybe you could fill out your profile details with the type of car you have so the folks here don't have to ask you every time you have a problem ;)
