Part No. 113414 l.h. conveyor | Page 2 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by moserpe, Jan 12, 2017.
  1. raemin
    raemin Formula 3
    Jan 16, 2007
    2,318
    Lyon (FR)
    R. Emin
    I guess not: "plastic weld" works well with ABS, but these rubbers are fuel proof, so they are so to say immune to most solvents.You could try to "prep" the rubber with MEK though.
    See my previous comment: for a "nice" patch, Shoegoe (or UHU-por) is probably the best bet. The most durable glue would be an hypalon adhesive: that's basically neoprene gel with an activator (similar to MEK) that is used to fix professional (rubber based) inflatable boats. They are a few issues with this glue: it is brownish, does not last more than a few days once opened, must cure under strict temperature and hydrometry, toxic, and quite costly ($30) . If you go to a shipyard supply store, you can buy such glue together with "patches". Any Zodiac specialist could probably do the job for you, which would end-up cheaper than buying the glue on your own.
    PetMar likes this.
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,435
    Canada
    Newman
    I said "something like" plastic weld, a product that would work on rubber.
    PetMar likes this.
  3. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Black Silicone RTV is possible. When cured it is flexible and it resists solvents (inside conveyor is air only). Color will match and it is cheap and easy to use. MHO
    Ken
    PetMar likes this.
