Painted Shields Retro Fit | FerrariChat
Discussion in 'FF/Lusso' started by PTG1, Oct 13, 2023.
  1. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    My authorised dealer has informed me that they can add painted shields to my 812 SF. I always stop and look at painted shields and absolutely love them especially on the 812. Does anyone have any opinions on if this is a good idea to modify the car away from original factory spec? The way I see it they are coming from an authorized dealer as an approved addition so, should be fine as they come with an invoice that says Ferrari etc but, of course they will not go on the original spec sheet so I'm still in two minds, any opinions will be greatly appreciated [emoji120]
    Sent from my SM-S9180 using FerrariChat.com mobile app
  2. NGooding
    NGooding Formula 3
    1,157
    Connecticut, USA
    Nate
    I would guess (but just a guess) that the impact on resale would depend mostly on the quality of the workmanship. If it's on par with a factory job (including being under the clear coat), I wouldn't think many people would mind if it doesn't match the original spec, so long as they like the painted shields. And a lot of people do like them, particularly on the V12s.
    On the other hand, if the workmanship looks subpar, that will definitely be a turnoff. Presumably for you too. So be sure that you trust them to do it right.
    That said, I'd think the resale impact would be small relative to the up-front cost. Presumably this will be an expensive job, particularly if you have enamel shields now. If you do, the cavity for the enamel shields likely means you'll need to replace your fenders:
    (Of course - as Caeruleus11 mentions - this should alleviate any resale concerns as you'll have the option to replace the original fenders.)
    If you don't have enamel shields, you wouldn't have to replace the fenders. But I'd still want to know how they'd do the job and confirm that you'll be satisfied with the quality.
    Please let us know what you decide. And if you move forward, let us know how it turns out!
  3. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    The original spec is without shields and I questioned them as to if the shields will be indistinguishable from the factory, they have assured me the shields will be exactly as per factory painted shields as the same process is followed. They have stated two or three clear coats will be used over the shields once painted and the work comes with a full warranty. I very much hope the quality of work is as per their description and due to the high cost I will not accept the work until it is perfect so I guess this should not have any negative impact or resale.
    Thecadster likes this.
  4. NGooding
    NGooding Formula 3
    1,157
    Connecticut, USA
    Nate
    Awesome! Obviously don't take my word for it on the resale, but that's what makes sense to me.
    Please post pics if/when you do it. Painted shields look great on the 812 SF if you ask me... :)
    Good luck!
  5. F12HeartThrob
    F12HeartThrob Rookie
    Oct 22, 2021
    48
    AZ
    Bobby L
    How much are they quoting you? And is it to convert your current bridges or a 2nd new set?
  6. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    The cost is reasonable as they only paint the shields and do not touch the original paint below. £5k which, I believe is less than as an original factory option. They key the whole top part of the wing, paint on the badge then lacquer the whole wing
  7. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    Many thanks, I most certainly will !
  8. F12HeartThrob
    Oct 22, 2021
    48
    AZ
    Bobby L
    That is significantly less than I would expect. What are they doing about the indentations for the current shields, or is is currently sheildless?
  9. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    Currently shieldless, I think that is what makes the huge difference, i personality thought it would be way more also. They are basically just stenciling on the shields and coating with two coats of lacquer
  10. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,534
    Longmeadow, MA
    Eric
    Curious to see how they come out. I love painted shields. My concern is they say it’s exactly as the factory would it but it’s not at the factory…..who’s doing the work and have you seen it? Is t it a $10K+ option?
  11. -K1-
    -K1- Formula Junior
    Jul 10, 2008
    699
    Northern Italy
    Ken
    No shields is such a rare (in the U.K.) and lovely spec.
    PTG1 and NYC Fred like this.
  12. JJ77
    JJ77 Formula Junior
    Oct 3, 2020
    546
    Wouldn’t even bother with this with a UK Dealer. Take it to Marco Zanassi at Zanassi Carroceria and pay the 15k euros, who does the painted shields for Ferrari. No worry on resale, and a better job than one UK Dealer showed me on a 488 Coupe and a 812 SF project. Think they were quoting £5k as well. Think Romans sold that 488 Coupe Redently and I think Amari did the same to their 812 SF in 2 Layer Verde/Green, sure you can find them in Sold Archive Photos. If I had to do it, would wait for Marco Zanassi to do it and have a great Italian trip there and back. GL
  13. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    Thanks for the input, may I ask which dealer this was?
  14. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,575
    Grant
    Zanassi Carroceria are the company that do most of the special paintwork for Ferrari and are based in Maranello, I think they also now have a base inside the factory as well. There was talk of this last year when I was at the factory but it may not have happened?
  15. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,575
    Grant
    Pete. Who is the dealer getting to do the paint work, if they can do it perfectly I would go for it for sure.
  16. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
  17. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
  18. JJ77
    JJ77 Formula Junior
    Oct 3, 2020
    546
    Wasn’t HR Owen..
  19. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
  20. NGooding
    NGooding Formula 3
    1,157
    Connecticut, USA
    Nate
    Wow, looks good to me! Are you happy with it?
    Looking forward to seeing more pics!!!
    PTG1 likes this.
  21. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
    I am happy with them, I need to see the whole car uncovered to get the full effect as I went by a day early so only the wings were uncovered, I can't wait to collect after ppf on Wednesday next week
    NGooding likes this.
  22. NGooding
    NGooding Formula 3
    1,157
    Connecticut, USA
    Nate
    I wouldn't have been able to woo either. So happy if turned out well. Send pics when you get the car next week. Going to be a long weekend of waiting!
    PTG1 likes this.
  23. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    789
    Pete
  24. NGooding
    NGooding Formula 3
    1,157
    Connecticut, USA
    Nate
    Looks amazing!!!
    PTG1 likes this.
  25. George Vosburgh
    George Vosburgh F1 Rookie
    I'd love to see the technique of the painting.
