Paint Protection Film removal question | FerrariChat
Discussion in '612/599' started by HOBE456, Jul 19, 2021.
  1. HOBE456
    HOBE456 Karting
    Apr 27, 2012
    168
    Hobe Sound, FL
    Tom
    I don't know the material that was used, but does anyone have any experience with PPF removal on an early (2008) 599 GTB?
  2. C4YES
    C4YES Formula Junior
    992
    Orange County, CA
    Todd
    Gently using a heat gun, set at low, or hairdryer. Don't put the gun too close to the paint, keep moving it don't let it sit on one spot.. Slowly pull. i did this w my 2007 599, no issues.
  3. George Vosburgh
    George Vosburgh F1 Rookie
    I've taken the film off of my '08 with very hot water, gently, slowly pulling. I've also seen video of someone doing it with steam.
    Mark Carbone likes this.
  4. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,230
    Indiana/North Carolina
    JIM
    You’ll need to take your time. It will be a very slow, painful process. Your fingers will hate you. If you have steam it will be better. Personally, I’d hire it out. You’ll run the risk of being impatient and the risk is repainting the entire hood.
    Jim
  5. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,136
    So. CA & NV
    Peter
    Mine was so difficult to get off that I needed to use a rubber wheel. Attaches to a drill and basically melts the film and then clean up the residual with good be gone.
  6. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Newport Coast, California
    Ron H
    I went the other way. I had 3M film that was put on in 2007 when the car was new. The film had yellowed and had a lot of swirl marks. I thought about taking it off but my paint was pristine and I wanted to keep it that way. So I had someone actually polish out the film and then apply a ceramic coating over it. It looked incredible. Got rid of all of the yellowing and swirls and looks like it doesn't have any film on and is also protected. From my point of view it is now good for another 10 or 15 years.
    So depending on the reason you are removing the film, this might be a better alternative.
