paging F430GT, need ur expertise on scud tires and pressures again.... | Page 2 | FerrariChat
Discussion in '360/430' started by johns930, Apr 24, 2012.
  1. Teachdocs
    Teachdocs Formula Junior
    Sep 3, 2012
    568
    Kansas City area
    Chad
    Scud/16M fronts are 8 inches wide, but I see a lot of Scud type wheels advertised that are 7.5.
    The 7.5's seem easier to come by.
    I'm looking for a second set of wheels for the track on the 16M. Should I really try to find another set of 8's for the front? I'm just trying to understand the pros/cons of the two setups.
    If I end up with one set of 7.5 and one set with 8, which setup for the track? I am assuming I would use the 7.5 with 235/35/19 for street with 285's on the rear. Then use 255/30/19 on the 8's for the track and go with a 305's on the rear for better balance.
    Any other suggestions?
  2. Darth_Homer
    Darth_Homer Formula Junior
    Mar 29, 2014
    272
    what about 245/35/19 front and 305/30/19 rear Pirelli Trofeo R on oem wheels for Scuderia?
    Do I still need spacers?
  3. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Yes, that setup works. You do not need/should not use spacers.
  4. tazandjan
    39,309
    Everybody knows recommended minimum wheel width for 305/30 19 MPSS tires is 10.5", correct? Using them on 10" wheels will introduce some tread instability, just like the wider tires on the front 7.5" Scud/16M look-alikes. Why not 295/30 19s with the suitably shorter front tires so ABS/stability control is happy.
  5. Darth_Homer
    Mar 29, 2014
    272
    yes you havea point there the tires a bit wider for the oem 10" wheel... but the overall diameter is also shorter by .5" from the stock size 285/35/19... so I think it will compromise if you install it, it might bulge a little bit but not too much bec of the undersize of .5"
    At first I was thinking of the 295/30 trofeo r... but its .8" undersize already, thats almost an inch smaller diameter than stock. I will also need to lower the car bec of the fender gap between the undersized tire.
  6. Darth_Homer
    Mar 29, 2014
    272
    Oh really? great thanks for the info 👍 so no more room even for 5mm spacers right?
  7. tazandjan
    39,309
    Darth- You missed the message. Does not have anything to do with the reduced height of the tire and that affects nothing regarding wheel width recommendations. Michelin's minimum recommended wheel width for the specific MPSS in 305/30 19 size is 10.5", and that already takes into account all the tire's dimensions.
  8. Darth_Homer
    Mar 29, 2014
    272
    yeah I know what youre saying... well I got the 305 tires already so the only thing to do is to try it out. Some scud owners here already did that and they said its fine and performs well.
  9. tazandjan
    39,309
    Darth- Should work fine. Good luck.
  10. Darth_Homer
    Mar 29, 2014
    272
    Thanks! Oh well worse case if its too fat for the rims I'll get the f430 challenge wheels which is 10.5" I think... 😏
  11. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    #36 Need4Spd, Apr 16, 2014
    I have a 360 with 18" stock size RE-11s. Last time at the track I started at 30-32 psi or so, and about 10-12 min. into the session, the tires got so hot I lost traction and almost went off track. So should I be starting at lower pressures? If I do, won't I risk damaging the sidewalls? Or should I get them hot, pull into the pits and bleed pressures half way through the sessions? I don't think they let you do that in the hot pit, do they? (I later tried starting out at 26 psi or so, and it seemed to work better, but is that too low?)
  12. ajc
    ajc Rookie
    Aug 8, 2005
    36
    uk
    AJC
    Now how does all this stack up in 2020 with the new tyre launches and availability ?
