Paddle shift not working :-( | FerrariChat
Discussion in 'Technical Q&A' started by James cln, Jan 2, 2023.
  1. James cln
    James cln Formula Junior
    Dec 20, 2015
    289
    San Antonio
    James cline
    Cali T - help my paddle shifts don’t change gears . Right one works only to go forward from park then both do nothing- what could it be ? Thanks james in San Antonio Tx
  2. tazandjan
    39,007
    Does she work in Auto mode? If so, take her to the dealer or a trusted tech with proper tools for diagnosis.
    Shorn355 likes this.
  3. RayJohns
    RayJohns F1 Veteran
    7,806
    West Coast
    Ray
    When in doubt, always reset the car by disconnecting the battery. You'd be surprised how often that cure mysterious issues.
    Could also be a sensor failure inside the gearbox. Any warning lights?
    Ray
  4. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    New Transmission Time.
  5. tazandjan
    39,007
    Not helpful.
    Qavion likes this.
  6. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,624
    SF Bay Area, CA
    Ruben
    Another potential avenue to (hopefully easily) discard: ensure that you have a healthy battery. With all of the electronics, things can go a bit awry if voltage isn’t up to 100%.
    Good luck!
  7. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Any alerts or warnings on the TFT ?
    As others have stated do a full battery disconnect- And ensure the battery is fully charged. These newer cars are hypersensitive to battery health.
    If problem persists take to dealer or indie with proper diagnostic equipment- if there is a core issue these cars self-diagnose and throw codes that can identify root cause.
    Good luck- I/we all know it's scary but more often than not it is not catastrophic.
  8. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,619
    South East
    Jimmie
  9. vjd3
    vjd3 F1 Rookie
    2,697
    Massachusetts
    Vic
    There is a small plastic actuator that has broken behind the paddle that’s not working. Remove the metal plate under the wheel and if you have both pieces you can probably epoxy it back together. The part is not available separately, the dealer will sell you the whole assembly which includes the paddles and a new ignition switch and it will be very expensive. But you can fix it for next to nothing. Threads in the California forum with good info. You can get the car out of neutral by hitting the PS button with your foot on the brake and then and drive it in auto mode.
  10. James cln
    Dec 20, 2015
    289
    San Antonio
    James cline
    Hi Vic , yep I took the covers off the paddle switch and the left little plastic actuator was broken.:-(( . Wish I could find the broken parts but not around. I am going to try to make it work but doubtful. May have to spend several thousand dollars to fix a broken 30 cent part - very upsetting! Can’t just buy broken plastic piece separately! Just discovered this today and then read your note tonight . You are right - thanks , james
    Mel Spillman likes this.
  11. James cln
    Dec 20, 2015
    289
    San Antonio
    James cline
    Wow , after much research I found that all the dealers and parts resources could only provide the whole paddle shift assembly for 3- 4 thousand dollars . Then to install, the steering wheel would have to be removed. :-(( . I kept searching and found an old thread which sent me to Exoticspecialtyparts.square.site and there is a video showing how to fix the paddle shift w new small parts they will provide for $350 .No removal of steering wheel, hooray! I am delighted to find this and wanted to share . Thanks all , james
    crinoid, vjd3 and Qavion like this.
  12. vjd3
    vjd3 F1 Rookie
    2,697
    Massachusetts
    Vic
    Let us know how that works out!
  13. Snapshift
    Snapshift Formula Junior
    897
    Centralia IL
    Lyle D. Pahnke
    See if you can get the geometry right pivot points etc, maybe from photos and see if someone can 3D print the part. It might just be doable. Possibly you could copy one on the other side if it is the samepart, get someone to cad draw it and someone to print out a few of them.
  14. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,794
    Dallas Texas
    If you know you know
    We have a guy locally that is working on a solution, he has created replacement pieces, that we are testing in 2 separate California T right now.
    When it proves out, I foresee this being an excellent solution to what is/was an expensive repair!
    I'm curious, is $350 for the pair or per replacement piece, or for the turn key repair?
    More to follow!
    Steve
    Qavion likes this.
  15. James cln
    Dec 20, 2015
    289
    San Antonio
    James cline
    Hi Steve $ 310 plus shipping, parts only .
    SAFE4NOW likes this.
  16. James cln
    Dec 20, 2015
    289
    San Antonio
    James cline
    Yep I thought of that but would rather pay a bit of a premium (310 bucks ) than fuss with it . Thanks
  17. James cln
    Dec 20, 2015
    289
    San Antonio
    James cline
    Hooray! , new parts arrived for paddle shift - wow ! Installed them in about an hour and she shifts better with paddles than since I got her . Hardy have to touch paddles and shifts up & down smooth as silk . Thanks for help . james in San Antonio Tx
    Il Tifoso, Qavion and bball16 like this.
  18. James cln
    Dec 20, 2015
    289
    San Antonio
    James cline
    For pair . Very well made - perfect!!! Even included a small tube of super glue to put on pins to temporarily hold them in while assembling- took about an hour - now works Better than ever
