Hi all. Hi all I'm trying to get as much info as possible on these machina,here's a list,any and all help gratefuly recieved.. - Ride height (front/rear) - Center of Gravity (front/rear AND heighth if possible) - Suspension measurements. If not possible then the Roll centers will do too. - A "default setup" of the car. Meaning various angles (camber, toe in, caster), springs, arb size etc... - Weight (Ideally dry weight,i.e. FIA scrutineering results) - gear ratios - final ratio - Differential lock (% of lock on power and coast if possible) - any aerodynamics values or at least how the car feels at speed - sound recordings .? Much thanks. Bon route a tous!
