Opinions on loctite/permatex 518? | FerrariChat
Discussion in 'Technical Q&A' started by bpu699, Jan 8, 2016.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,429
    wisconsin/chicago
    bo
    I see it mentioned on here quite a bit. Its used because its anaerobic and can't plug oil galleys... Tried to find the loctite stuff, but everyone carries only the permatex 518 (same manufacturer from what I am told).
    The only question I have, is how easy is it to dissassemble later? I ask because the instructions say to heat the part to 400 degrees and then pry apart to disassemble??? Is this stuff like superglue?
    Was going to use it around the oil seal and waterpumt seal as those are metal to metal surfaces, with really tight tolerances...
    But I don't want to "superglue" the parts in. The oil seal in particular, was awefully hard to remove...
    Thanks...
  2. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    eBay is a possibility. I used the Loctite on many occasions and it has served me well.
