Opinions on BG 44K | FerrariChat
Opinions on BG 44K
Discussion in 'Technical Q&A' started by RGigante, Dec 17, 2008.
  1. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
  2. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    #2 ProCoach, Dec 17, 2008
    I use to use it all the time twenty years ago when I owned my shop near BG Products in Charlotte, North Carolina USA.
    Sold quite a bit of it to folks with cruddy K-Jetronic systems (mostly VW/Audi and a few 308/328/Mondial/TR's). It worked extremely well for BMW 320i's that were prone to "buildup" on the back of the intake valves that badly affected idle quality and off throttle drivability.
    It was a good "topical" fix and idle quality was improved. Never saw any downside but began to remove injectors and use my Bosch Tester to clean and verify patterns. I think it's one of the few additives that works and it sounds ideal for a high-mileage 308/328.
  3. kosmo
    kosmo Formula 3
    Oct 19, 2008
    1,569
    BIg D
    I use it as a preventive and not as a preformance enhancer. I usually drive out completely w/in 1 to 2 days.
  4. RGigante
    RGigante F1 Rookie
    Nov 1, 2006
    2,874
    Portugal
    Thank you for your replies. I'm surprised there were so few ...
    Anyway since I've found no bad reviews anywhere, I've decided to give it a try and already ordered a can for gasoline and another for diesel. My daily driver has turned 180.000 Km and I'll give a try, too.
    I will let you know the results !
  5. f355spider
    f355spider F1 World Champ
    18,027
    If you have the original steel fuel injectors, it would be worth it to simply replace them all with the currently production brass ones. I think new are around $30 each or so. I did mine a few years ago when they were about $22 each, made a noticeable difference above 5k rpm. ;)
    My tech said that two or three of my injectors had very poor patterns.
  6. RGigante
    RGigante F1 Rookie
    Nov 1, 2006
    2,874
    Portugal
    I have replaced injectors, plugs and wires about 4.000Km ago, and they've made a difference both at idle (smoother) and at high rpm's
    I've removed the plugs to check how things were and I can see some carbon buid up at the top of the pistons. It made me look for a cleaner ...
  7. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    It was recommended not to let it hang about. Start with at least half a tank of gas (do they specify an amount to mix a can with?) and run it aggressively through in a day or two. It is pretty serious stuff.
  8. thecarreaper
    thecarreaper F1 World Champ
    17,958
    Savannah
    been using it for years, great stuff.
  9. Latsyrc
    Latsyrc F1 Rookie
    Jun 23, 2008
    2,798
    Utah, USA
    Travis
    I've put 2 cans through my current car. It seems to be helping...and you remind me it's time for another...
  10. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    This is interesting. It's usually hard to get first hand experience with products like these. Also, i'm always weary of buying snake oil in a can. Nice to see that people actually have had good experiance with it.
    Darrell.
  11. Shark49
    Shark49 Formula Junior
    Mar 31, 2005
    773
    Boone, NC
    Nathan
    The Seafoam brand works really well too. Theres a process I have done many times on my other cars and it saved me from a $4000k sticky valve fix on my land rover. Basically you unplug a vacuum hose from the intake manifold or valve covers of the car. Get a funnel with a small end on it and stick into the vacuum hose. While engine is running you slowly pour the stuff into the engine without allowing it to stall. Once the whole can is in you plug it up and turn the car off. Come back about an hour later and start the car up. It will smoke like the dickens which is all of the carbon buildup being burned off. You repeat the whole process until the car doesn't smoke any longer. I did this on my 03 disco rover, my 86 4runner, and my 01 ford f150 with great results.
    There is also a service you can get at some BF Goodrich shops called a Motorvac Carbon clean which does the same thing but with computerized machines but costs about 150 bucks.
    Never tried it on the ferrari.
  12. fletch62
    fletch62 Formula Junior
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    I have tested Sea Foam and it will not harm the O-rings in the Fuel Distributor. You should buy 2 common black O-rings at the hardware store put 1 in a jar with the BG 44 and leave 1 out, compare them after a few hours. I do not reccomend additives with lots of methanol or ethanol because they absorb water and this will cause fuel system corrosion to aluminum.
    Larry Fletcher
    CIS Flow Tech Llc
  13. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    Larry,
    I won't try this with grandkids around during the holidays..yes they wanna see 'the red head'.. so may I guess BG 'eats' the 'o' rings....?
    One thing I do use is sta bil...any downside with that?
  14. RGigante
    RGigante F1 Rookie
    Nov 1, 2006
    2,874
    Portugal
    wooppss... I've used my can of BG44 this morning! But according to the can contents there is no methanol or ethanol, unless I'm missing something: EC 232-489-3 stoddard solvent, EC 265149-8 distillates (petroleum) , hudrotreated light R 65, R10, S23, S24, S60, S62
    I did about 130Km, so I guess it is still too soon to feel any difference.
    Would you recommend quickly ending this tank of fuel ?
  15. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    I use a long nozzle on a bottle to fill each of my clylinders with Marvel Mystery Oil. I put an ounce or two in then turn the car over for a second to spread it up and down the walls then put another ounce or so in and let it sit overnight. One cylinder at a time. Haven't used a boroscope but just a penlight and can tell a difference in how clean the top of the piston looks.
    Never used the BG44k product before.
  16. the_stig
    the_stig F1 Rookie
    Sep 19, 2005
    3,497
    I once used the BG product on an engine that was badly sludged. Made so much smoke it scared the heck out of me - had to go driving on some deserted roads late at night to burn it off - anything else would have been begging for an arrest.
  17. f355spider
    18,027
    BTW, another product I have had recommended to me by three techs now, is Lubro Moly Ventil Sauber. It too, is designed to clean combustion chambers, and intake valves. Cleans the entire fuel system. I use it preventively on my 355 and my BMW 540. About every 3k miles or so I will run a can through.
    I have found the best online price here:
    http://catalog.etyparts.com/item.wws?sku=LM2001&qty=1&type=ETY
