On the road again - Robb's Ferrari Adventures | Page 109 | FerrariChat
Discussion in '348/355' started by Robb, Jan 12, 2016.
  1. tres55
    tres55 F1 Rookie
    3,495
    Canada
    This is exactly the scenario that led me into my 355. Was shopping for a 993 Turbo. :D
  2. tres55
    tres55 F1 Rookie
    3,495
    Canada
    Sorry I meant to say "dry ice blasting".
    I'm constantly amazing how this service turns back the time on cars without damaging original components.
    Robb likes this.
  3. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    13,891
    Robb
    copterjon, 05011994 and tres55 like this.
  4. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
  5. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
  6. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Nice Robb. Are you guys going to perform the updated power steering fluid reservoir on this one?
    Robb likes this.
  7. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
    Elliott,
    Yes I believe so. We have a long checklist with many items.
    where did you get your wiring loom boots? We need to replace ours.
    Robb
  8. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    I bought mine off eBay. Most are the Bosch 3 pin type. I also bought a special pin removal tool to de pin the connectors safely. I purchased that from digikey you will require one to do the job properly. It’s known as a JPT pin extraction tool. Made the job a lot easier.
    tres55, zstyle and Robb like this.
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
  10. KMR968Turbo
    KMR968Turbo Formula 3
    Nov 11, 2007
    1,001
    Calgary, Alberta
    Erik
    Depending when you were looking, you should have bought the 993TT and rode the appreciation curve then sell it. Would have enough to buy two 355’s and some change left over
  11. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,503
    Lake Villa IL
    ^ Sure but that could be said for almost anything.
    Right before I bought my first one, a 99 GTS, I looked at a higher mile (80k) 993 turbo at a local dealer. This was 2009. Asking price for the 993 was 35k. (was a bit rough) If I remember correctly 993tt and F355 in similar condition were similarly priced at the time.
    Biggest deciding factor was watching youtube videos of F355 fly by's. Chills!
  12. tres55
    tres55 F1 Rookie
    3,495
    Canada
    They've about doubled from where I was looking.
    However...they had already gone up 30-40% at the time and that's when I started at looking other 90s cars that I had always wanted and landed on the F355. At that point I didn't really care about value anymore...it just seemed like (and IMO is) better bang for your buck.
    I have friends that have 993s and they're eyeing 355's lately as well. The maintenance on a 355 isn't far off what these 993's cost to upkeep. They're not cheap by any means...I've seen the bills.
    mclaudio and INTMD8 like this.
  13. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,218
    Los Angeles
    Gotta disagree, as a DD 993 driver for almost 15 years. They're as reliable as Hondas and Toyotas once you take care of the valve guides. At least mine has been. Probably a big reason they're so valuable. I needed more drama in my life so I got a 355 ;)
    jimmym likes this.
  14. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
    Looking at Jon’s serial on his 95 B
    100298
    Sept 94 build.
    Anyone have the list on how this fits into overall production. It may be the first car brought into AZ.
    Thanks for any help in tracking down more info.
    Robb
  15. tres55
    tres55 F1 Rookie
    3,495
    Canada
    #2715 tres55, Dec 24, 2020
    What model 993?
    I'm referring to the RS', Turbos, etc. Even the C2S/C4S I've seen some service bills in the 3-5k range. Mostly taking care of leaks etc. though.
    I would imagine a base Carrera would be much easier on the wallet but where's the fun in that. :D
    Funny that you mention "once you take care of the valve guides"....isn't that what everyone's always bitching about with the 355? Like I said once the "major" potential issues are taken care of, they're not too far apart in maintenance costs. Even if the Ferrari averages $1k more per year...totally worth it over a dollar for dollar 993 without a shadow of a doubt.
    NOT saying the 993 isn't a great car...the RS that I got to drive for a few days was a fantastic car, but it's in no way comparable to the event it is to drive a 355 every time, IMHO of course. :D
    Targatime likes this.
  16. copterjon
    copterjon Formula 3
    1,536
    Mesa, Az.
    Shouldn't all this 993 chatter be better suited to a Porsche area? Let's get back on track here and that's what's cooking at Robb's place.
    Challenge, Carmellini, tres55 and 3 others like this.
  17. ShineKen
    ShineKen F1 World Champ
    16,604
    Southern California
    Nostradamus
    My car is a July 94 build with the single piece center undertray as well if that helps. If I recall correctly, 355 builds started in May 1994.
    Robb likes this.
  18. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    479
    Victoria, B.C, Can.
    John Glen Wesanko
    Just a note on refinishing Ferrari valve covers. When I recently paint stripped my old 348 valve covers I noticed that the most deteriorated areas of the painted surfaces were due to corrosion of the aluminum undre the "wrinkle" paint. I decided to pre paint the valve covers after glass bead blasting with a two part epoxy aircraft primer. I then applied to red wrinkle paint over the primer. I believe this will provide a longer lasting finish. Just my opinion.......I may be wrong, JGW
    Robb likes this.
  19. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
  20. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
    Will be removing from the cradle for new mounts as soon as parts arrive.
    Robb
  21. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,685
    Seattle, WA
    Brian White
    Hey Robb,
    I was looking through my phone for a certain picture when I happened upon a picture of your car from a few years ago. This was taken May 5, 2018 at the Exotics at Redmond Town Center weekend gathering.
    tres55, ShineKen, Robb and 1 other person like this.
  22. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
    I thought you had posted that previously. I love the shot. Thanks.
    Robb
  23. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,685
    Seattle, WA
    Brian White
    Sorry if I did. I thought I had posted the one from the event about a month before you got it, which was a different event.
  24. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
    All good but I have this photo saved to my iPad. So you were kind enough to share previously.
    have a good week.
    Robb
  25. Robb
    Robb Moderator
    Feb 28, 2004
    13,891
    Robb
