Oil Temp gauge purpose?` | FerrariChat
Discussion in 'General Automotive Discussion' started by ibesuc, Nov 22, 2009.
  1. ibesuc
    ibesuc Formula Junior
    Jun 16, 2009
    489
    NY
    Steve
    What's the point?
    Not all cars have them, but some do.
    And as far as I can see they are pointless as the temp of the oil will be affected by the temp of the engine which is already given?
    The volt gauge seems more important.
    Does any one know of any valid point?
    -Steve
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    On a dry sump engine, it's nice to know the temperature of the oil in the tank. The temperature of the oil can be far in excess of the temperature of the coolant and still be within its normal range. But if your coolant temp is 190 degrees and your oil temp shows 275 degrees, you might want to be able to monitor what is happening. A volt meter won't do you much good in such a case.
  3. ztunelover
    ztunelover Formula Junior
    Oct 1, 2009
    641
    Calgary, AB
    Krish
    Water Temp and Oil Temp is very different. If you are pushing a car hard, oil temp and pressure is very important. The first shouldn't be too high and the second shouldn't be too low.
    Water is keeping the block cool, but the oil keeps the metal reciprocating mass lubricated so it can keep turning. The temp and pressure is necessary to know because, if the pressure drops then oil isn't going where its supposed. And the higher the oil temp the less it is capable of lubricating the bearings and crank. Overheated low pressure oil is the ideal recipe for seized bearings.
    Oil temp is not completely dependent on the water temp. It gets cooled separately in high output engines. And high rev motors need to have the oil temp and oil pressure monitoring system. Because they almost always have separate cooling system, and heat up very disproportionately to the water temp.
    Voltmeters are important in track cars. Last thing you need is a failed battery in a race.
  4. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Oil temp takes longer to hit normal operating temp. On my 348 water is at "normal" within 2, 3 miles max, especially with a stop light. Oil won't hit normal temps for at least 7-10 miles.
    You don't want to start hitting the high rpm's until your oil is warmed up.
    Kai
  5. photonut
    photonut F1 Rookie
    4,080
    Michigan
    Joel
    i have never looked at my oil temp indicator! i agree, it seems like an unimportant feature in my dd (cayenne)
  6. UroTrash
    Jan 20, 2004
    40,197
    Purgatory
    Clifford Gunboat
    +1
    -1
  7. GuyIncognito
    98,978
    =0 ?
