Oil smell while driving; is it me or the guy in front? | FerrariChat
Discussion in 'Technical Q&A' started by hessank, Jun 7, 2015.
  1. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    I've had 4 P-Cars (front-engined) and always worry when I smell burning rubber or oil burning WHILE driving. A few times I've even taken an early exit and check that things were ok under the hood. Only 2 times in 30 years I found my car was the cause (steering fluid leak from HP hose dripping on exhaust and oil spill from a recent oil change burning off the exhaust).
    So yesterday I'm on the hwy and started smelling oil burning. I go schxt, look around at the cars around me and not one of them pouring blue smoke from an exhaust. I pull over safely and after a quick inspection continued. Paranoia? Hell yes.
    So my question is, this being a rear-engined car can it ever be me? With the airflow and all would you smell burning oil if there was burning oil from the back?
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,397
    romano schwabel
    sure you may smell burning or burned oil, it does not matter if front, middle or rear engine
  3. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Try this. Try following different cars around. I the odor persists, it's probably not them.
  4. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Maybe it was a stupid question. I am quite sure you have all smelled burning /burnt oil while driving before. My question was, this being a rear-engined car, is it ALWAYS the other car and not mine (being rear-engined).
  5. dm_n_stuff
    I think it's maybe a LITTLE less likely that you'd smell it in a mid/rear engined car, BUT, I do know that I've smelled it a few times in Porsches and in Ferraris and it's ALWAYS been my car that had the issue.
    Leaky oil lines in a couple different 911's and a bad job of filling the oil on my Dino all resulted in the issues.
    Always best to err on the side of safety. If your car is leaky or smoking, you'll know right away when you stop, and can then motor safely on your way if it's not the cause.
    D
  6. bigsquat
    bigsquat Formula Junior
    478
    Westchester, NY
    Troy
    I think it's just as likely that you would smell any leak you had if the fluid was burning off. This is how I knew I had a leak that turned out to be my TO bearing.
  7. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Thanks Dave & Troy for your replies.
  8. pietro
    pietro Karting
    Dec 24, 2011
    64
    So Cal
    Check your cam bearings. Might be a small leak.
  9. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I've smelled oil in my mid engine car. Especially when driving slow or immediately after pulling in garage.
  10. Prugna
    Prugna Formula 3
    2,005
    Northern California
    Its ALWAYS you. Just like farts.
