360 - Oil pressure gauge erratic while driving | Page 2 | FerrariChat
360 Oil pressure gauge erratic while driving
Discussion in '360/430' started by MR. JETSON, Oct 20, 2020.
  1. RedNeck
    RedNeck F1 Veteran
    9,978
    The CSA
    Me
    Are you using a 26mm or a 24mm? Hopefully 24 because 26 would round it off and make it almost impossible. If it's stuck you can probably use a little WD40 and if you have something like a pole that you can put on the end of the handle to give you a little more leverage. Mine came off rather easily.
  2. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Been trying to get it off by using vice grips on the sender it’s self but no avail
  3. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  4. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,302
    San Jose
    dc
    Kroil usually works well. Perhaps the sender nut area needs "grab material" too. (like drive grip?)
  5. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  6. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,738
    Memphis, TN
    Qavion likes this.
  7. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,302
    San Jose
    dc
    Maybe put some thread sealant on the end when replacing.
  8. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    I prayed to the ferrari gods!
    brookliner7 likes this.
  9. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
    Details please.
  10. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Hey guys sorry for the delay!!! Yes it was a bit tough to get to, not so much to get off... i removed both air intakes and throttle bodies. I also removed the power stealing reservoir and moved the hoses aside and zipped tied them away from my work area... there’s two small sensors on the left side of the crossbrace (white and brown small boxlike snap on sensors), I removed those also and moved them away to give me more clearance and not to damage anything since I knew I was going to tug on this thing with all my might! With all these removed I managed to use an adjustable wrench. In this forum another tech told me to use a 24mm spanner however it was too thin and was rounding the nut on the oil sensor itself, so I needed to use something thicker and found it at ace hardware 12” long. I crawled over the left side of the car and hovered over the engine, slid the wrench between the crossbrace and engine, adjusted for the oil sensor nut and pulled with all my might!!! It turned!!! Then I just removed and replaced it with my hands. Putting the new one was easy and just tightened it German Tight... Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Qavion and armedferret like this.
  11. EastMemphis
    May 25, 2019
    1,738
    Memphis, TN
    That's a lot of ear clamps to replace! "While you're in there", you might as well crinkle paint the oil disareator...
    MR. JETSON likes this.
  12. delaney
    delaney Formula Junior
    Nov 8, 2003
    704
    St Petersburg, FL
    PETER DELANEY
    Don’t use sealer. The sender uses the threads as an earth contact. Needs good electrical contact between sender and engine body.
    Qavion likes this.
  13. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  14. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  15. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,665
    Central NJ
    Dominick
    What are you looking to do with it e.g. just read codes ?
    Sent from my moto g(7) using Tapatalk
  16. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,665
    Central NJ
    Dominick
    Unless you have a newer TCU or A stradale TCU, i don't believe any scanner can read or set clutch parameters other than factory SD or leonardo
    One that is inexpensive that will read, reset codes and read a number of data streams but will not interface with the transmission ecu on earlier 360s is the ap200
    Other than a stradale TCU i am not sure which year or cutoff for the non stradale TCU would / wouldn't work
  18. MR. JETSON
    MR. JETSON Karting
    Sep 29, 2020
    114
    ADRIAN
    Ok...wanted something that did self learning and ran through the gears... have you used this one before?
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,665
    Central NJ
    Dominick
    Which ? I haven't used used anything on older 360s so my knowledge on capabilities for that specific models
    I know a number of people have used the x431 mini or torque but again, although it has the functions on menu i haven't seen or heard if it works on older 360s .. maybe others with a older 360 and a x431 can chime in
