Oil Preference | FerrariChat
Oil Preference
Discussion in '360/430' started by piratepress, Apr 25, 2018.
  1. piratepress
    piratepress Formula Junior
    May 18, 2009
    722
    Mississippi
    Chip A.
    Curious about what oil everyone is using in their 360? The Ferrari dealer uses Castrol Syntec 5W-50, but Ricambi recommends Pennzoil 5w40 Platinum Euro, Ferrari approved.
    Both oils are the same price, so any reason I should choose one over the other?
  2. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    Weird that a Ferrari dealer uses Castrol
    BeIng Pennzoil (owned by Shell) the one Ferrari has a partnership with
    My dealer has the hard to get Shell Ultra in big containers.
    Honestly I believe any kind of top tier oil will do the work as long it is changed every year and it is the same (or similar) viscosity.
  3. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    Love an oil discussion! You should post in the tech section for a deeper dive. The 50 vs. 40 is interesting. Our engines are based on a long developed platform that is different than what is in the present day cars, maybe they only stock one kind of oil? What do the 458's need? I am guessing that your car's condition, operating environment and maintenance frequency "might" be more of a guide to changing the oil spec but I would want the tech to explain this to me before switching. I use the Pennzoil 5-40 with the Ferrari approved stamp on the box when I do my own change. Here is the manual page. Two choices are given.
    Carnut, whatheheck and piratepress like this.
  4. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Falcon Wing likes this.
  5. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,430
    On the Limit
    Dino
    Pennzoil Platinum 5-40
  6. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    582
    SW Suburbs of Chicago, IL
    Lawrence P.
    Interesting, my Ferrari dealer just installed Castrol Syntec in my 360 Spider.
  7. bzubi
    bzubi Karting
    May 7, 2007
    138
    NOVA
    Bashar Zubi
    Pennzoil Platinum Euro 5W40
  8. f355spider
    f355spider F1 World Champ
    18,027
    I think Shell/Pennzoil changed, I used to see a lot of foaming years ago with my F355 spider, I haven't seen it the past three years with the 430 Scuderia.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,662
    Central NJ
    Dominick
    Somewhere there is an article from shell that says foaming is good ...helps lubricate ..dining believe that is a totally another story
    I use mobil 0w 40
    Sent from my Moto G (4) using Tapatalk
  10. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,429
  11. tazandjan
    39,007
    Valvoline Full Synthetic 5W-40. No foaming.
  12. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    I think foaming might be good (supposedly because it reaches more), only problem is checking the level.
    I don’t think our cars burn oil (the manual states it only to cover their asses) and as long as the foam shows on the dipstick and the oil is changed every year the level would be fine
  13. cpep
    cpep Formula Junior
    428
    new york
    CHARLIE
    Just bought some redline.
  14. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    yup, someone posted a video where a Shell engineer talked about the foaming properties being done on purpose, by design, to lubricate hard to reach places that don't have direct access to oil jets
    whatheheck likes this.
  15. LightGuy
    LightGuy Four Time F1 World Champ
    44,497
    Texas
    David
    There was a thred where a long time mercedes mechanic / shop owner evaluated all the oils over his years.
    His recommendation was
    https://www.amsoil.com/shop/by-product/motor-oil/motorcycle/15w-60-synthetic-v-twin-motorcycle-oil/?code=MSVQT-EA
    He also recommended selling your new Mercedes right after the warranty expires :D
    Apparently motorcycle oils still have all the nasty environmentally irresponsible metal additives that car makers are not allowed to use anymore.
    Best metal moving part engines need.
    On the other hand the Medical doctor that did an EXTENSIVE oil thread years ago said to use a 0W-XX oil as circulation when cold was the critical factor.
    0W flows best at cold temps. Anything under warmed up engine temp is considered "cold".
    So I'm still looking for the "perfect" oil.
    Chances are Amsoil has it.
    Absolutely the best.
  16. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I’ve read the opposite. Foaming means the oil is mixed with air, which doesn’t lubricate as well as just oil. On wet sump engines, designers go to great efforts to protect the oil in the pan from the spinning engine crank so as to avoid the crank foaming the oil like a blender. It’s good to hear that newer Shell oils don’t foam like they used to, but since it’s a pain to drain and refill the engine if I encounter foaming, I don’t think I will switch back to Shell just as an experiment.
  17. SnowmanUK
    SnowmanUK Karting
    Dec 11, 2010
    174
    London, UK
    Shell Helix Ultra every time I've had a service.
  18. LorenzoR
    LorenzoR F1 Rookie
    Im using Pennzoil 5w 40 euro,,bought it thru amazon
  19. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    Foam becomes superheated steam bubbles that explode violently and damage your bearings, not tiny scrubbing bubbles that clean better, lol.
  20. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,749
    Boston, MA
    John E. Kenney
    #20 John_K_348, May 5, 2018
    Shell Rotella 5w40 T6 (SM multifleet). No issues, variators sound better than when I bought it. Soon to be replaced by Penzoil Platinum Euro 5w40 (Cavallino marked). Good price on Amazon.
  21. johnfe
    johnfe Karting
    Dec 22, 2016
    121
    SoCal Usa
    John F Edwards
    piratepress:
    Hi, here's one of the best articles on learning about engine oils that you can ever read, it's a bit long but every bit is very educational. Note what he says he uses in his Ferrari's:
    https://www.minimania.com/Motor_Oils_-_It_Is_So_Very_Misunderstood
    Let me know what you think.
    One of his main points he makes is, it's grade of oil at the engine start up that's most important.
    I ended up buying the Pennzoil 5w40 from Amazon at $7.71/Quart as they have the very best price.
    Best Regards,
    johnfe
    piratepress likes this.
  22. f355spider
    18,027
    It available right on this forum, no need to go to another website:
    https://www.ferrarichat.com/forum/threads/motor-oil-all-chapters-inclusive-copy-and-save-this.136052/
  23. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    That's not how it works.
  24. f355spider
    18,027
    Explain.
  25. tazandjan
    39,007
    All oils flow better at higher temperatures, regardless of weight. 0W just means it flows like a 0 weight when cold (winter), but the 0W-40 means it protects like a 40 weight when warm. A straight 0 weight oil would still flow better when warm, but would be kind of thin when it did get warm.
    dbluestein likes this.
