360 - Oil in spark plug threads | FerrariChat
360 Oil in spark plug threads
Discussion in '360/430' started by 550nitis, Aug 22, 2020.
Tags:
  1. 550nitis
    550nitis Formula Junior
    765
    Houston
    Changed the spark plugs today to have the updated NGK version that ends with a B. First time doing this and was surprised how incredibly easy it was.
    Was also surprised to find oil in the spark plug threads. Wasn't in the spark plug itself but just on the threads on all plugs. Gaskets?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,019
    Isle of man- uk
    A lot better than seized in the head
  3. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Yep, valve cover gaskets are known / common to leak / seep.
    Those valve cover gaskets are horrible. Tightness / torque has to be perfect and remain perfect.
    If torqued too tight or too light oil will leak or seep.
    Check the valve cover gasket bolts regularly and ensure they are torqued to spec.
  4. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,132
    Calif
    Brett
    Hmmm...haven't been doing that check in my annuals. no issues so far at 44K miles.
