Oil Change Royal Purple | FerrariChat
Discussion in '360/430' started by nchhotu, Feb 19, 2013.
  1. nchhotu
    nchhotu Formula Junior
    Nov 19, 2007
    310
    Roseville, Ca.
    Nick
    I completed my first DIY 2001 360 oil change over the weekend. First thanks to all the FChat folks for providing the details on this DIY project.There were so many great threads on this topic. I wanted to make sure i followed up with my findings as it relates to Royal Purple Synthetic Oil. I used RP 5-40 and i must say there is a noticeable difference. The car starts better idles a little higher at start-up and is smoother and quieter.
    On the road the engine feels more responsive and the RPM's increase much quicker especially during fast acceleration.I'm going to monitor the car a little more closely over the next few weeks but "wow" very impressed so far.
    The oil in the car prior was Shell 5-40 Helix and had about 1,100 Miles on it and about 15 months since its last oil change
  2. jpk
    jpk Formula Junior
    Keep us informed as to how it goes. I'm considering switching from the Shell Helix to Royal Purple myself.
  3. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,840
    Jupiter, FL
    Paul Bianco
    not trying to be a wiseguy so excuse the question. but could this just be your imagination?
  4. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    1+
    He have a point!
  5. nchhotu
    Nov 19, 2007
    310
    Roseville, Ca.
    Nick
  6. rob4092xx
    rob4092xx Formula Junior
    Mar 8, 2010
    570
    Phoenix, AZ
    I have found several Threads on DIY oil changes. Some seem to have points that contradict each other. Can you please share with me which one you followed? Thanks!
  7. nchhotu
    Nov 19, 2007
    310
    Roseville, Ca.
    Nick
    Since it had only been a little over a year and 1,500 miles i did not do the multiple step process oil change that you see in some of the threads. I basically drained the oil via the two drain plugs, new filter, changed out my faulty oil sending unit, and added 8qts back started the car let it warm up and added another 1.5qts until the oil showed up just a little below the first mark on the dipstick. I may need to add a little more but will do that when i take her out on a drive.
