Ohm specs for 355 Motronic 5.2 MAF sensor? | FerrariChat
Discussion in '348/355' started by f355spider, Feb 24, 2008.
  1. f355spider
    f355spider F1 World Champ
    18,026
    I searched threads, and there are many specs given for the 348, but none for the 355. Anyone have the specs for the
    BOSCH Part # 0280217800 Used on the 1996 to 1999 F355? Also used on the BMW E34 540 (BMW part #13621702078) Anyone with a BMW/Bentley workshop manual?
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    I would like to know too... :eek:
  3. WilyB
    WilyB F1 Rookie
    4,266
    AZ
    #3 WilyB, Feb 25, 2008
  4. f355spider
    18,026
    It may...the question to someone who owns the book; does it actually give specs for the hundreds of different MAF's out there? And more specifically, the one I have listed at the start of this post?
    Btw, WilyB is that you over on bimmerfest too? ;)
  5. f355spider
    18,026
    I PM'd Jim Conforti and he says the hot film type MAF used in the 5.2 Motronic 355's from 1996 to 1999 cannot be so simply adjusted like the 348. Requires some sort of specialized laser trimming device to trim the circuitry.
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The voltage for the fuel injectors passes through the 348 MAFs. Lower the MAF resistance and the 348's fuel injectors receive higher voltage (which means that they open wider so you'll run richer).
    The 348's ECUs control how long the 348 fuel injectors are open, but the MAFs control how wide open they go.
    It's effective, but it's an analog solution that harkens back into the 1980's.
    That being said, you could still probably rig a circuit to raise or lower the voltage to the fuel injectors on 355's to get the same effect, easily...without a lot of drama.
    No need to go through the 355's MAF to do so, either...going straight to the fuel injectors would work better and easier, in fact. You just need a higher input voltage and an adjustable resistor...commonly available.
  7. f355spider
    18,026
    That is not my point. I am just trying to find out if my MAF is properly calibrated and working correctly.
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Sounds like a good plan.
    On the 348, each MAF has two entirely different circuits:
    1 circuit measures airflow/temp in the engine air intake
    the other circuit influences the voltage that opens the fuel injectors
    I'd think that you'd want to know if the 355 single MAF has both of the above circuits, and if so, would want to calibrate both of them independently.
  9. f355spider
    18,026
    According to Jim, it is not adjustable. I would still like to know if it was even correct or not. Seems with OBDII you only know if it has completely failed, but not out of calibration. I am surprised at the number of folks that have proven better performance (dyno runs) after replacing MAF's, even though they have not had any CEL's, just basic drivability issues/problems.
  10. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Basically, It doesnt matter because the computer trims to the 02 sensor(s), not the amount of air.
    I can't explain why replacing one afm with an identical part number would increase performance. There are other substitutions that increase hp, but I've never experienced any change with apple apple substitution.
    Jay
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    O2 sensors are ignored at full throttle.
  12. f355spider
    18,026
    Not increase, restore hp.
  13. bowbells
    bowbells Formula Junior
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    How much misinformation can a person absorb?
    The fuel quantity is a function of injector duration, ie time, not by how wide open they go. Please try to avoid confusion by giving proper explanations, they are plainly written in the w'shop manuals.
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The information that I gave above is accurate, as shown in Ferrari's 348 fuel injection schematic, workshop manual, and Motronic 2.7 programming code.
    The whole reason that adjusting the resistance on the M2.7 MAF modifies CO is that resistance controls the voltage delivered to each fuel injector. In turn, the voltage controls the speed and depth of each fuel injector opening. This is why the Ferrari 348 Workshop Manual refers to the MAF resistance as the CO adjustment screw.
    On the other hand, the programming and fuel maps inside each Motronic ECU control how long each injector is open.
  15. bowbells
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    I had no doubt that you would argue about this!
    The ECU/chip/fuel map switches the ground signal to the injectors, the duration of that ground determines the time of injector opening, voltage to the injectors is not flucuated as you could lead others to believe. Time of opening is influenced by air flow (measured va the MAF),coolant temp, engine speed, throttle opening (I think that's all I recall from my Bosch training)
  16. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    It's true that the ECU/chip/fuel map controls how long the injectors are open, but you are forgetting that the CO screw on the MAFs actually has a real function (that being: controlling the actual voltage that reaches the injectors).
    Voltage is just as critical to the injectors as timing.
    In fact, the ECU/chip/fuel maps adjust to longer timing durations for the injectors if your system voltages are low (e.g. low battery, alternator not fully charging, etc.).
  17. bowbells
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    So you believe that the MAF reading directly influences the voltage to the injectors? You believe that miniscule voltage adjustments are being made at the injectors which limit the range of opening of the pintle in the injector?
    By your reasoning, one could control say...the fuel door release flap, by applying a smaller voltage? Seems to me that when sufficient voltage appears, the solenoid operates. Full stroke, period. Please explain how one can expect an injector to operate differently, X volts operates it, period. X being around 5.0v.
  18. fana355france
    fana355france Formula Junior
    284
    France
    nicolas
    #18 fana355france, Feb 28, 2008
    Hello F355spider, here is a link of a suplier of MAF sensor.
    There is a list of others cars that could have same sensors
    Hope it could help.
    Nico
    http://cnhchcar.en.alibaba.com/product/200017256/200556043/air_flow_sensor/air_flow_sensor_0280_213_012_.html
    Detailed Product Description
    Relative Number: 0280 213 012
    It fits: 0 986 280 110
    OEM Number: 154916
    88 27 429
    91 13 846
    30539175
    3517569
    8602793
    HONGCHUANG NUMBER: A45-13000
    Suit For: FERRARI/SAAB/SCANIA/VOLVO
    Ftts the following models:
    FERRA 456 GT 5.5 (F116) 01.93
    SAAB 9000 2.3-16 Turbo 09.90-08.93
    SAAB 9000 Hatchback 2.3-16 Aero CS 02.93-12.98
    SAAB 9000 Hatchback 2.3-16 Turbo 09.90-12.98
    VOLVO 740 Kombi (745) 2.3 Turbo 08.89-07.90
    VOLVO 960 (964) 2.0 08.90-09.93
    VOLVO 960 (964) 2.9 08.90-07.94
    VOLVO 960 II (964) 2.9 07.94-12.96
    VOLVO 960 Kombi (965) 2.0 08.90-09.93
    VOLVO 960 Kombi (965) 2.9 08.90-07.94
  19. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    That's incorrect.
    What do you think the factory-adjustable MAF resistance does to the Ferrari fuel injection circuit?!
  20. f355spider
    18,026
    Nico,
    Thanks but no thanks! That is not the correct style/model for the 5.2 Motronic, and worse, it is a Chinese copy/reproduction!!! I know on many other car sites (VW, BMW, etc.) people have tried these reproductions, and had many problems. Not recommended.
    The mid 1990's E34 BMW 540 uses the exact same MAF, and I have seen them for $241 from www.autohauz.com with free shipping.
  21. eric355
    eric355 Formula 3
    1,210
    Toulouse (France)
    Eric DECOUX
    I have a datasheet of the MAF we have in the 5.2 F355. I can confirm that it is not adjustable and that there is no resistance measurement which is possible to diagnose it. PM me if you want a copy in pdf format.
    You can have an idea of how far you are from calibration if you look at the "Long Term Fuel Trimming" parameters using an OBD2 reader.
    This parameter is learnt by the Motronic when your engine runs in closed loop. It tells, based on O2 sensor reading, how far the Motronic needs to correct the map which are stored in its memory. Even if the O2 sensors are not used at WOT, the "Long Term Fuel Trimming" still corrects fuel injection based of what was learnt while in closed loop mode.
    If your MAF is out of calibration, the Motronic will see it because it will have to correct the base-map looking at the O2 sensors, and you will see a similar drift of both banks. On the contrary, if you have a failed pressure regulator or bad injectors on one bank, the LTFT parameter will drift on only one side of the engine.
    This self-compensation capability of the 5.2 explains that, except if you are far from the original tuning (more than 20% on LTFT), there will be no extra power changing a slightly bad MAF or slighly bad FPR.
  22. f355spider
    18,026
    Eric, thank you for the excellent explaination! I always wondered what some of that stuff meant that I was reading with the OBDII code reader.
    Thanks, PM sent.
  23. bowbells
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    A much more eloquent and informed response to the original question. Thank you for posting accurate information which no doubt will fall on some deaf ears.
    Thanks.
  24. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Different systems. Accurate for Motronic 5.2, not accurate for Motronic 2.7 (e.g. 1995 355's).
    M5.2's have no CO screw on the one MAF. In contrast, M2.7's have CO adjustment screws on both MAFs.
  25. Llenroc
    Llenroc F1 Veteran
    5,420
    Colorado
    Vern
    Sorry more misinformation, only the 2.7 used on the 348 has a CO adjustment the 2.7 355 does not. Thanks Bowbell and Eric355 for correctly
    telling us what my Bosch Manuals state.
