oh crap I dropped a screw in the engine bay | FerrariChat
Discussion in 'Technical Q&A' started by Challenge64, Apr 11, 2006.
  1. Challenge64
    Challenge64 F1 Veteran
    6,358
    Ron
    I got my new BMC airfilters today for my 360 CS...
    I pulled the old ones out. Put new ones in..and in the course of things...I dropped a screw. It bounced off a cat and vanished.
    how big a disaster is this? I called the dealer and they were a bit vague.
    So far Ive pulled off a rear wheel, opened up the small access on the undertray..and spent over an hour looking.
    crap. help.
  2. Ricambi America
    Sponsor Owner
    Turn the car upside down and shake really hard.
    Just kidding. Personally (and I'll get flamed for this) I wouldn't worry too much.
    1. It didn't magically fly all the way to your timing belts and through the covers,
    2. It didn't magically fly into the gearbox, past all the casing,
    3. It didn't magically fly into the oil tank,
    4. It didn't magically seat itself inside the brake caliper,
    5. It didn't magically glue itself to the throttle cable,
    6. It didn't shred a CV boot and swim through the grease and stick inside a bearing.
    If you heard it hit the cat, then odds are it's on the floor, or resting on one of the frame pieces, or resting on the gearbox, or maybe, just maybe, resting on the inside lip of your wheel.
    Keep looking. You'll find it.
    More importantly, how's the cat feeling? Probably pretty neglected, huh?
  3. Challenge64
    6,358
    Ron
    the cat is off killing scorpions..or at least that is her elected job around here
  4. Admiral Thrawn
    Admiral Thrawn F1 Rookie
    Jul 2, 2003
    3,932
    I've done this many times.
    Get some compressed air and blast all over the engine bay (preferable an air gun attached to a compressed air line).
    Obviously make sure the oil filler cap, etc, are closed first.
    If it doesn't drop out the bottom, poke around with an extendable magnet.
  5. Texas Forever
    Texas Forever Eight Time F1 World Champ
    85,536
    Texas!
    What diagnostic code did you get? :)
    Back in the day, I was dumb and stupid enough to ride British motorcycles. This meant, of course, that I had to learn how to fix British motorcycles (Bad joke: What does BSA stand for? Bastard Stopped Again.)
    We never worried about dropping a screw into the case. Who needs stinkin bearings anyway?
    But the cat? Well, that might have cause problems...for the cat.
    Dale
  6. EC308
    EC308 Formula 3
    Aug 28, 2005
    1,146
    jenkintown, pa
    ed
    There are many nuts, bolts and screws that live out the rest of there lives trapped in some obscure nook or cranny in the bowels of many cars. It may not be found until someone restores it. It's highly unlikely it will have found its way into something where it would do damage. The compressed air idea is your best bet. The magnet will also be of big help. I just wouldn't go as far as pulling the motor over a drop screw.
  7. Admiral Thrawn
    Jul 2, 2003
    3,932
    I once found a rusty old ring spanner that had been left suspended on a car's RHF brake bleeder nipple for 2 years...
  8. carlrose
    carlrose Formula Junior
    Nov 25, 2003
    324
    The telescoping magnet has saved me many, many times...
    :) Carl
  9. UroTrash
    Jan 20, 2004
    40,209
    Purgatory
    Clifford Gunboat
    I once dropped a screw in a Weber carb I put on a bug-eye Sprite. Never seemed to be a problem.
  10. 348_project_car
    Jan 29, 2006
    80
    Chicago
    Dale
    Daniel, you left out were it will magically end up, in your front tire, causing a flat the morning
    you had a big drive planned. Whats that called "Murphy's Law":D
  11. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    I dropped a small flanged spacer from one of the webers and I didn't even hear it hit. I checked the inside of the carbs with a mirror and then looked all around telling myself that I will not quit until I find it. After about 30 minutes of looking, I gave up and said "what the heck". 3 weeks later, I found it resting on a small shelf when I removed a shroud for some other work (major glee and a "there you are you little s....".
    The magnet works real good but it will stick to lots of things. I tried it on a string too, but that sticks to everything. I also tried compressed air. The spacer was very low in the engine compartment and I thought "sure, gravity did the work".
    Good luck
    -Rjay
  12. Rifledriver
    36,760
    The screw is stainless and a magnet will not get it. It is laying in the belly pan somewhere and if the car is on a rack you can undo the front belly pan bolts and pull it down to have a look. Otherwise get another screw.
  13. dogue
    dogue Formula Junior
    Sep 2, 2001
    967
    Phoenix, AZ
    Terry
    I dropped a spacer a few months ago in the intake of my 308 and spent 5 days searching. I have a couple fiber optic lights that are flexible and they help in searching as well as a few telescopic magnets if you need help. Just email me.
    Terry
  14. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Floor pan is not that hard to undo. Just last week my race mechanic dropped a screw while working on the 360C and instead of just getting another screw he pulled the floor pan and retrieved the sucker fairly quickly.
    Maybe that's why I like him, because that's what I would have done myself. A loose screw on the floor pan is no big deal, but it sure will bug the hell out of me knowing it's there.
  15. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    If gravity applies in your garage, the thing is at or below the level of the object it hit. Just a guess.
  16. rammsteinmatt
    rammsteinmatt Formula Junior
    Jul 26, 2005
    371
    Glendora, CA
    Matthew Shinavar
    i had a friend work on his car and upon removing a piece (forgot which, an airbox or something) found a 12mm wrench sitting down there still on the bolt. interesting......... i'd say someone was short a 12mm
  17. Challenge64
    6,358
    Ron
    lol..yea I heard that story tonight at dinner.
  18. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    I dropped a carb hold down nut onto the engine and it never hit the floor. spent 2 hours looking for it. then i dropped a similar nut from the same location on purpose to see where it would go, and whala!, i found them both hiding in an obscure location and pulled them out with a magnet.
    john
    78 308 euro GTS
