OEM Plug wire protective sleeving color | FerrariChat
Discussion in '308/328' started by jdamon, Mar 9, 2017.
  1. jdamon
    jdamon Formula Junior
    Jul 6, 2015
    288
    Boston
    Jeff
    #1 jdamon, Mar 9, 2017
    I am changing out my 83' QV plug wires and decided to clean/ restore/ flip the sleeving I already have, and re use the boots. The problem though, is that unfortunately I have two different colors of the sleeving and boots, and a couple of the sleeves are missing all together. I purchased a used set of plug wires, so I can use the sleeving, but would like to confirm the factory correct color and the factory correct boots. I think it's the brighter, more orangey red as opposed to the darker red. The boots both have the same number stamped on the inside, but the color is slightly different, and the texture is also a bit different. The lighter color red of the two has a smoother texture. The used set I got has the brighter orangey red sleeves and the smoother textured boots. Thanks!
  2. jdamon
    Jul 6, 2015
    288
    Boston
    Jeff
    And are the coil wires supposed to have a black or red boot on the end? I have seen both in the pics found on the web
  3. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,129
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I was faced with the same dilemma when restoring the ignition wires on my '83. My car had darker boots and lighter sheaths, presumably factory. However, the difference in shade was much smaller than what your photos show; it was only a subtle difference and they both tended toward the brighter shade in your photos.
    For the restoration, I also had available a used set of sheaths and boots from a 328 which had the lighter boots and the darker sheaths (!). In the end, I used the darker shade (i.e. my original boots and the 328 sheaths) which color matched quite nicely. I went for aesthetics rather than historical accuracy (on a very minor issue).
    The coil boots should be black.
    If you find a source for new sheathing, let us all know!
  4. Rifledriver
    36,760
    #4 Rifledriver, Mar 10, 2017
    There seems to be an assumption here that every car Ferrari made with red silicone wire covering had exactly the same product.
    The wire sets were made by a subcontractor in small batches and the silicon parts were made by a subcontractor to them in small batches with no one really caring if the wires made in 1984 looked exactly the same as the wires made in 1989.
    That's a little like getting a color code for the yellow paint proof marks. The people at the factory get a good laugh at that.
  5. fatbillybob
    Aug 10, 2002
    28,565
    socal
  6. jdamon
    Jul 6, 2015
    288
    Boston
    Jeff
    I am not assuming they were all the same, I would just like to be accurate to factory for my model year as I can be. But it seems the take home is I could use either one and be factory correct. Thanks for the info!
  7. jdamon
    Jul 6, 2015
    288
    Boston
    Jeff
    That link is definitely helpful, thanks! Pretty pricey though :). Not sure if you saw the earlier post, but I bought a used set of plug wires, and I am re using the sleeves only, replacing the wires themselves with the Taylor pro series wires. My existing set had a couple different colored sleeves, so I wasn't sure which was "correct".
    If those wires are really what they look like in the picture (from kingsbornewires) then they look pretty good. I may have ordered a set from another parts supplier before deciding to rebuild, that utilized that same picture, but when they arrived they were completely different. At least they are willing to take them back :)
  8. jimgolf1
    jimgolf1 Formula Junior
    Aug 23, 2013
    375
    Reno, NV
    Jim Small
    #8 jimgolf1, Mar 10, 2017
    I just took my 85 Euro QV in for a cold misfire issue. Turned out to be one bad wire. They told me a new set of wires would be $600. I said no thanks, I'll find a used wire for now and shop for some myself. On the link it looks like they are around $400. Is that a good price?
  9. ClydeM
    ClydeM F1 World Champ
    11,603
    Wayne, NJ
    Clyde E. McMurdy
    watch the kingsborne site. make sure you buy wires for your '83. they list two. lengths do vary between model years.
  10. jdamon
    Jul 6, 2015
    288
    Boston
    Jeff
    It's only like $50 for a new set of wires, and you can recycle your existing boots and wire sleeves. But if you are not willing to swap the sleeves, then $300 is what it will cost.
  11. Alden
    Alden F1 Rookie
    3,365
    Central Florida
    I need one long red sleeve only to replace one on my front bank that got damaged.
    Since it is on the front bank it is not really "seen" but you know how it is, lol!
    If anyone has one to spare, let me know.
    Alden
  12. jdamon
    Jul 6, 2015
    288
    Boston
    Jeff
    I am gonna have some left over from my project, definitely will have a long "darker red version". Do you have a preference on the color? I might have a lighter red one too. Have you tried to turn the damaged one inside out? None of mine are new, all are in need of a thorough cleaning and I am still planning to turn them over. I'll let you know what I have when I am done, may get to it this weekend.
  13. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    402
    PA
    Alex
    jdamon... so do you have a 250 GT slot car for that track of yours? :)
  14. Archer911
    Archer911 Formula Junior
    Sep 26, 2016
    907
    New England
    Tim
    This is just a guess but due to slightly different materials and decades of heat and age could the colors of the wires, boots, etc have changed colors differently? My guess is yes.
    I have an 84 and bought new wires and yes paid up the ying yang for them. If someone wants to buy the old wires let me know...
  15. Alden
    Alden F1 Rookie
    3,365
    Central Florida
    Mine are the brighter red color.
    Alden
    Sent from my VS986 using Tapatalk
  16. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,771
    Australia
    Mark R
    +1
  17. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Yes that is a problem in all the collector car restoration hobby. Someone tell somebody his is not correct because the other one is different. Then everybody try to copy the one they THINK is correct. That is why I often say cars are very often over restored. Everything gets overdone, metal finish, plating, paint etc etc. New cars are never perfect more especially Ferraris that were all test driven by the factory before delivery.
    Many different suppliers, with different finishes. Different period of production etc etc. Every super low miles unrestored cars I've seen in my life were much less perfect than the restored ones.
  18. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,771
    Australia
    Mark R
    Very true, over restoration is a big problem. Owners add things or get things finished because they see others at a show or concorso event and think they need to add it too. Then more and more cars have those very same add on's and after a while people think it is factory, but it never was.
  19. jdamon
    Jul 6, 2015
    288
    Boston
    Jeff
    #19 jdamon, Mar 11, 2017
    Of course I do :). My 330 P4 is way faster though!
  20. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,129
    1983 US 308 GTS QV
    Fortunately, there are a few unused cars in museums which provide a benchmark regarding what the cars are supposed to look like.
    I don't think of over restoration as a "problem" per se. It is just a form of modification. I wonder how many cars at the Pebble Beach concours came with from the factory with $100,000 paint jobs like they have now. I would dearly love a paint job like that on my 308.
  21. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,771
    Australia
    Mark R
    Many cars from Ferrari from the 60's, and 70's were repainted after a few years or even less as the original paint job was so poor.
    No original flawless, $100,000 style paint jobs back then (or even today) for that matter.
