Oem like radio ? | FerrariChat
Oem like radio ?
Discussion in '348/355' started by cascade, May 4, 2021.
  1. cascade
    cascade Karting
    Sep 12, 2012
    67
    I’ve attempted to search with no luck. I’m looking for a modern radio / head unit that will match the classic look of the 355.
    the closest I got was the VDO continental series but it lights up orange or blue :/. We need green.
    any help is appreciated.
  2. cascade
    cascade Karting
    Sep 12, 2012
    67
  3. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,177
    NYC, USA
    Phil
    I run a Becker 430 head unit in my 355, it's "Ferrari" branded and is more modern than the stock Sony (although at this point it's 15 year old tech). I don't recall if it's display is green or amber though, whatever color it is, it doesn't upset my F-OCD.
    Let me know if you want a photo of it.
    PhillipSimone likes this.
  4. tres55
    tres55 F1 Rookie
    3,496
    Canada
    Continental probably looks the most "at home" but the backlight issue is unfortunate. Friend of mine said a competent tech should be able to physically change the backlight though.
    360/550 etc. radios aren't much better.
    Bluetooth audio streaming is basically the bare minimum.
    Clarion M508 is nice also. I have it on my boat and the Bluetooth streaming is top notch. Connects quickly.
  5. emac
    emac Formula Junior
    851
    upstate SC
    ernest
  6. judd10
    judd10 Formula Junior
    457
    Seattle, WA
  7. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    463
    Chicago IL
    I have an out of sight audio unit in mine. Basically hidden amp unit that you connect to via bluetooth and phone is the only control. Stock head unit runs through it but doesn't have to. I have that 360 head unit linked above mine
    tres55 likes this.
  8. cascade
    cascade Karting
    Sep 12, 2012
    67
    pm sent
  9. tres55
    tres55 F1 Rookie
    3,496
    Canada
  10. tres55
    tres55 F1 Rookie
    3,496
    Canada
    This was my plan with my previous 355. I would do the same to my current one but it doesn't have the original head unit anyway so might as well put something else in.
  11. Pepsi10
    Pepsi10 Formula Junior
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    #12 Pepsi10, May 6, 2021
    The Becker Cascade, and your Bremen both sound like good ideas. I was looking at this Sony. It is very simple looking. So that appealed.
    https://www.crutchfield.com/p_158RSXGS9/Sony-RSX-GS9.html
  12. Ferrarista98
    Ferrarista98 Formula Junior
    259
    Jason L
    Bremen SQR46 is a great unit I have in my 964. I agree it's more Porsche style but I don't think would look bad in the 355, particularly because you can change the color to match factory.
  13. tres55
    tres55 F1 Rookie
    3,496
    Canada
    Pepsi10 likes this.
  14. tres55
    tres55 F1 Rookie
    3,496
    Canada
    That's the main reason I bought it...retro look with infinitely adjustable RGB LED's to match the factory lighting.
    I wish the continental units had this.
  15. DaisyCutter
    DaisyCutter Karting
    Jul 15, 2014
    249
    Sweden
    Dayan
    Have you considered buying a period-correct cassette radio with CD controller, then usean adapter cable from the CD output to your phone/MP3 player?
  16. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    I did that in a 98 Mercedes SLK using some bits from GROM audio, an adapter plugged in perfectly where the CD connection was before. And it created a bluetooth connection, which is what I want. Pretty happy with that. The Bremen still sounds like what I will do for my 355.
    https://gromaudio.com/
