OEM 456 rear damper hydraulic accumulator spec | FerrariChat
Discussion in '456/550/575' started by cwwhk, Dec 6, 2016.
  1. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #1 cwwhk, Dec 6, 2016
    Just want to post up some tech info on 456 rear damper's self levelling hydraulic accumulators.
    In the end I decided to buy OEM Ferrari part from Ricambi America instead of similar BMW part as suggested in other thread. Price difference is not worth the risk of substitution IMHO.
    Stamped on the new OEM part spec shows 155bars at 0.5 liter capacity. So for those of you who do want to buy generic this is what you need to get.
    Also in another thread someone mentioned the distance from inlet fitting to bladder is different on his used parts suggesting this may be one way of checking if the accumulator has failed. So I used a calliper to measure my two new accumulators. From inlet to membrane the distance is 45.35mm and 45.8mm.
    Hope this is of use to some of you.
    Regards,
    Wayne
  2. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    No risk of substitution in my case. The BMW accumulators I bought were identical to factory except for the mounting hole size.
  3. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,629
    SF Bay Area, CA
    Ruben
    +1 here with the BMW pieces. Mounted a few weeks ago without any issues and completely transformed the car!
    Ruben
  4. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    I know they look the same, but does anyone know the pressure specification of BMW 37211132043 accumulators? And how does that compare to the Ferrari OEM units? If static nitrogen pressure of the substitute accumulator is different, then that will directly affect the dynamic damping and self levelling characteristics of the car.
    BMW 37211132043 is about $150/pc while Ferrari 158693 is $300/pc. Respectfully, $300 cost difference for a pair of substitutes is not worth it to me unless I know their pressure specs are the same as Ferrari OEM.
  5. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    I do not know the specs on the BMW unit. It's been a while, but as I recall I checked the OEM part # stamped on the unit vs. the original and they were the same.
    I paid less than $150 for them, and at the time I couldn't find the originals for anywhere near $300.
  6. tazandjan
    39,019
  7. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
    An interesting question.
    My thinking is the pressure in the accumulator will vary the rate/speed the self leveling system returns to its preset height.
    The only way to ascertain the pressure in the system is to make a test rig as nether BMW or Ferrari will tell you the pressure.
  8. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #8 cwwhk, Dec 16, 2016
    Just an update.
    I sent my car to local Ferrari specialist to install new rear dampers and accumulators, because my right rear damper was slightly leaking and thought might as well replace the accumulators at the same time as a precaution against hydraulic lock and blowing out the new OEM dampers.
    Well I got the car back today along with the old parts. It seems the accumulators were already replaced fairly recently by previous owner with aftermarket Lemforder part #515550002 with the larger mounting screw hole. On the unit it is stamped 155bar pressure and 0.45 liter capacity. See photos.
    My new Ferrari OEM accumulators had 155bar and 0.5 liter stamped on them. So now I have confirmation the Lemforder part is indeed a suitable substitute.
    Just for laughs I also measured the distance between inlet fitting flange and accumulator membrane on the Lemforder and got 45.25mm and 45.6mm on both, which compares favourably to new Ferrari OEM 45.35mm and 45.8mm. So I guess these used Lemforders are still good as spares.
    Will send the old dampers to Bilstein to rebuild as my spares for future use.
  9. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    hi, found this old thread..
    I do not own a 456.. but curious for my own knowledge..
    what is this rear hydraulic leveling system on the 456 for ? is it on all 456 variations..?
    I know the 456 has the red suspension actuators.. like a 355.. but don't understand what this hydraulic system is for?
    does it just function on its own.. or does it operate via the suspension/sport button in the car..?
    stock with the tiny wheels the 456 ride height is crazy high. and unfortunately makes the car look completely ridiculous..
    but ive seen some nicely adjusted lower, with larger wheels, which completely transforms the car..
  10. tazandjan
    39,019
    The hydraulic leveling system is used to keep ride height constant with varying loads in the back seat and luggage compartment.
    Doubt the 456/456M owners appreciate your ridiculous comment. Would you say that to their faces? If not, does not belong here, either.
    Fennicus likes this.
  11. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    thanks for the explanation.
    yes i would say to a 456 owner in person, that the car needs to be lowered and put larger wheels. would they do it just because i suggested it, i dont know. that’s simply my option.
    but there are plenty of 456 owners who have done so.
  12. Fennicus
    Fennicus Formula Junior
    Apr 10, 2015
    593
    Helsinki, Finland
    Pekka T.
    Ok, then I would most likely say that’s very childish and ruins the car in both looks and ride quality.
    My car has been lowered by a PO and it has 18” 550 wheels, but I also have the original 17” wheels and IMO they look MUCH better on the car than ANY other wheels I have ever seen.
    And in which universe are 17” wheels ”small”? Classic cars (Ferraris, Lambirghinis, Maseratis and Jaguars) all look best in their original 15” or sometimes 14” wheels and proper tyres.
    I leave the wide rims with bling and thin rubber bands to immature teens and tuning magazines who have no sense of style nor elegance.
    The 456 GT is a very classy and well performing GT car as it was designed, and that is why I’ve got one.
    Cheers!
  13. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    17” wheels in general are not small.
    but fitted into the gigantic wheels wells in addition very high stock ride height of 456, they look like training wheels.
    and in today’s age, does not age the 456 well.
    i’m not talking about bling/flash 20” wheels. at max 19”. which i’ve seen plenty of 456 fitted with.
    combined with moderate lowering of suspension, completely transforms the car.
    does this look ugly? if so that’s ok, it’s your preference. likewise my preference/opinion is it completely modernizes the 456.
  14. Fennicus
    Apr 10, 2015
    593
    Helsinki, Finland
    Pekka T.
    Hi,
    No I am not saying it is ugly, I am just saying that the 456 GT looks perfect the way it was designed. There is absolutely nothing wrong with the original stance, original alloy wheels and original tire size, They are all perfect. No need to improve anything.
    I am not trying to "modernize" it any more than I would "modernize" my 1972 V12 E-type (15" wheels) or my 1950 Jaguar MKV DHC (16" wheels).
    They are what they are, the way they were designed and I am just enjoying all of them. (and fixing a lot of things which are problems only created by oxidization, previous owners and normal wear, not the original design.)
    I loved the 456 GT the way it came out back in 1992 and I still love it. For two decades I thought I would never be able to afford one, but I guess I was lucky.
    Cheers!
  15. Fennicus
    Apr 10, 2015
    593
    Helsinki, Finland
    Pekka T.
  16. Aerosurfer
    Aerosurfer Formula 3
    1,791
    Indianapolis
    Nick
    This is interesting information, as BMW/Febi/SWAG/Meyle accumulators are advertised at 23 (but inconsistently on various websites). Ferrari/LF stamp 155Bar on theirs. I’m looking to craft a suitable solution with a Mercedes/Corteco part and those are also stamped 155Bar. I’m curious and confused where the 23 bar number may be coming from and if it should be ignored.
    any chance these are all pressured to that much within the Nitrogen bladder (23 bar) and the 155 bar is simply what the sphere itself rated for
