Odyssey Battery | FerrariChat
Odyssey Battery
Discussion in '360/430' started by RobScud, Aug 28, 2015.
  1. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
    Hi,
    I've read that some owners have installed the Odyssey PC925 to save weight. Has anyone tried the Odyssey PC950, as it seems more powerful and even less weight than the PC925.
  2. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    The 925 works fantastic for a 360. How do the specs compare between the two?
  3. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    Another one to consider.
    Before I went to the amazingly light (but expensive) Braille Lithium battery I previous had ran a PC925, it works well if you keep it on a charger all the time but i then wanted to take the car on holidays and not worry if it would start so I eventually settled on a PC1100 (Or Extreme Racing 40) which has much much better specs and wasn't that much heavier.
    12.5KG (for the 40) vs 11.8KG.
  4. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
  5. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
    Trev - The PC1100 is taller than the OEM battery, did it not touch the metal bar at the top?
  6. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    586
    North east, USA
    I also used the 925, 2 years is max life I got, and as stated above - when not in use it need to be kept on a charger.
  7. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
    Just two years and it was on a charger? WOW I thought these batteries were meant to last longer than lead batteries. The Bosch S5 series seem to last for 4-5 years no problems.
  8. F430Rod
    F430Rod Formula Junior
    Feb 17, 2007
    482
    Orange County
    Rod
    My Odyssey PC925 lasted 9 years in my E46 BMW M3. I often had it on a charger which is key.
    On the F430 I recently purchased a Braille B2015 batter. It's rated more powerful than the PC925 but also costs around $50 more. I have not yet installed it. This Braille battery is quite small in dimensions and I'm still trying to figure out the best way to securely mount it.
