OBD2 codes | FerrariChat
OBD2 codes
Discussion in 'Technical Q&A' started by ernie, May 15, 2007.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    So that people can find these in the future, here is the list of generic codes.
    Generic OBDII Trouble Codes
    P0001 - Fuel Volume Regulator Control Circuit/Open
    P0002 - Fuel Volume Regulator Control Circuit Range/Performance
    P0003 - Fuel Volume Regulator Control Circuit Low
    P0004 - Fuel Volume Regulator Control Circuit High
    P0005 - Fuel Shutoff Valve "A" Control Circuit/Open
    P0006 - Fuel Shutoff Valve "A" Control Circuit Low
    P0007 - Fuel Shutoff Valve "A" Control Circuit High
    P0008 - Engine Positions System Performance Bank 1
    P0009 - Engine Position System Performance Bank 2
    P0010 - "A"Camshaft Position Actuator Circuit Bank 1
    P0011 - "A" Camshaft Position - Timing Over - Advanced or System Performance Bank 1
    P0012 - "A" Camshaft Position - Time Over - Retarded Bank 1
    P0013 - "B" Camshaft Position - Actuator Circuit Bank 1
    P0014 - "B" Camshaft Position - Timing Over - Advanced or System Performance Bank 1
    P0015 - "B" Camshaft Position - Timing Over - Retarded Bank 1
    P0016 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A
    P0017 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor B
    P0018 - Crankshaft Position - Camshaft Position Correlation Bank 2 Sensor A
    P0019 - Crankshaft Position - Camshaft Position Correlation Bank 2 Sensor B
    P0020 - "A" Camshaft Position Actuator Circuit Bank 2
    P0021 - "A" Camshaft Position - Timing Over - Advanced or System Performance Bank 2
    P0022 - "A" Camshaft Position - Timing Over - Retarded Bank 2
    P0023 - "B" Camshaft Position - Actuator Circuit Bank 2
    P0024 - "B" Camshaft Position - Timing Over - Advanced or System Performance Bank 2
    P0025 - "B" Camshaft Position - Timing Over - Retarded Bank 2
    P0026 - Intake Valve Control Solenoid Circuit Range/Performance Bank 1
    P0027 - Exhaust Valve Control solenoid Circuit Range/Performance Bank 1
    P0028 - Intake valve Control Solenoid Circuit Range/Performance Bank 2
    P0029 - Exhaust Valve Control Solenoid Circuit Range/Performance Bank 2
    P0030 - HO2S Heater Control Circuit Bank 1 Sensor 1
    P0031 - HO2S Heater Circuit Low Voltage Bank 1 Sensor 1
    P0032 - HO2S Heater Circuit High Voltage Bank 1 Sensor 1
    P0033 - Turbo Charger Bypass Valve Control Circuit
    P0034 - Turbo Charger Bypass Valve Control Circuit Low
    P0035 - Turbo Charger Bypass Valve Control Circuit High
    P0036 - HO2S Heater Control Circuit Bank 1 Sensor 2
    P0037 - HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
    P0037 - HO2S Heater Control Circuit Low Bank 1 Sensor 2
    P0038 - HO2S Heater Control Circuit High Bank 1 Sensor 2
    P0039 - Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
    P0040 - O2 Sensor Signals Swapped Bank 1 Sensor /Bank 2 Sensor 1
    P0043 - HO2S Heater Control Circuit Low (bank 1, sensor 3)
    P0044 - HO2S Heater Control Circuit High (bank 1, sensor 3)
    P0050 - HO2S Heater Control Circuit Bank 2 Sensor 1
    P0051 - HO2S Heater Control Circuit Low Bank 2 Sensor 1
    P0052 - HO2S Heater Control Circuit High Bank 2 Sensor 1
    P0053 - HO2S Heater Resistance Bank 1 Sensor 1
    P0054 - HO2S Heater Resistance Bank 1 Sensor 2
    P0055 - HO2S Heater Resistance Bank 1 Sensor 3
    P0056 - HO2S Heater Control Circuit Bank 2 Sensor 2
    P0057 - HO2S Heater Conrol Circuit Low Bank 2 Sensor 2
    P0058 - HO2S Heater Control Circuit High Bank 2 Sensor 2
    P0059 - HO2S Heater Resistance Bank 2 Sensor 1
    P0060 - HO2S Heater Resistance Bank 2 Sensor 2
    P0061 - HO2S Heater Resistance Bank 2 Sensor 3
    P0062 - HO2S Heater Control Circuit Bank 2 Sensor 3
    P0063 - HO2S Heater Control Circuit Low Bank 2 Sensor 3
    P0064 - HO2S Heater Control Circuit Low Bank 2 Sensor 3
    P0065 - Air Assisted Injector Control Range/Performance
    P0066 - Air Assisted Injector Control Circuit or Circuit Low
    P0067 - Air Assisted Injector Control Circuit High
    P0068 - MAP/MAF - Throttle Position Correlation
    P0069 - Manifold Absolute Pressure - Barometric Pressure Correlation
    P0070 - Ambient Air Temperature Sensor Circuit
    P0071 - Ambient Air Temperature Sensor Range/Performance
    P0072 - Ambient Air Temperature Sensor Circuit Low
    P0073 - Ambient Air Temperature Sensor Circuit High
    P0074 - Ambient Air Temperature Sensor Intermittent
    P0075 - Intake Valve Control Solenoid Circuit Bank 1
    P0076 - Intake valve Control Solenoid Circuit Low Bank 1
    P0077 - Intake Valve Control Solenoid Circuit High Bank 1
    P0078 - Exhaust Valve Control Solenoid Circuit Bank 1
    P0079 - Exhaust Valve Control Solenoid Circuit Low Bank 1
    P0080 - Exhaust Valve Control Solenoid Circuit High Bank 1
    P0081 - Intake Valve Control Solenoid Circuit Bank 2
    P0082 - Intake Valve Control Solenoid Circuit Low Bank 2
    P0083 - Intake Valve Control Solenoid Circuit High Bank 2
    P0084 - Exhaust Valve Control Solenoid Circuit Bank 2
    P0085 - Exhaust Valve Control Solenoid Circuit Low Bank 2
    P0086 - Exhaust Valve Contrtol Solenoid Circuit High Bank 2
    P0087 - Fuel Rail/System Pressure - Too Low
    P0088 - Fuel Rail/System Pressure - Too High
    P0089 - Fuel Pressure Regulator 1 Performance
    P0090 - Fuel Pressure Regulator 1 Control Circuit
    P0091 - Fuel Pressure Regulator 1 Control Circuit Low
    P0092 - Fuel Pressure Regulator 1 Control Circuit High
    P0093 - Fuel System Leak Detected - Large Leak
    P0094 - Fuel System Leak Detected - Small Leak
    P0095 - Intake Air Temperature Sensor 2 Circuit
    P0096 - Intake Air Temperature Sensor 2 Circuit Range/Performance
    P0097 - Intake Air Temperature Sensor 2 Circuit Low
    P0098 - Intake Air Temperature Sensor 2 Circuit High
    P0099 - Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
    P0100 - MAF Sensor Circuit Insufficient Activity
    P0101 - Mass Air Flow System Performance
    P0102 - Mass Air Flow Sensor Circuit Low Frequency
    P0103 - Mass Air Flow Sensor Circuit High Frequency
    P0104 - Mass Air Flow Circuit Intermittent
    P0105 - Manifold Absolute Pressure Sensor Circuit Insufficient Activity
    P0106 - Manifold Absolute Pressure System Performance
    P0107 - Manifold Absolute Pressure [MAP] Sensor Circuit Low Voltage
    P0108 - Manifold Absolute Pressure [MAP] Sensor Circuit High Voltage
    P0109 - Manifold Absolute Pressure Circuit Intermittent
    P0110 - Intake Air Temperature Circuit
    P0111 - Intake Air Temperature Circuit Range/Performance
    P0112 - Intake Air Temperature [IAT] Sensor Circuit Low Voltage
    P0113 - Intake Air Temperature [IAT] Sensor Circuit High Voltage
    P0114 - Intake Air Temperature Circuit Intermittent
    P0115 - ECT Sensor Circuit
    P0115 - Engine Coolant Temperature Sensor Circuit
    P0116 - Engine Coolant Temperature Sensor Circuit Performance
    P0117 - Engine Coolant Temperature [ECT] Sensor Circuit Low Voltage
    P0118 - Engine Coolant Temperature [ECT] Sensor Circuit High Voltage
    P0119 - Engine Coolant Temperature Circuit Intermittent
    P0120 - Throttle Position [TP] Sensor Circuit
    P0121 - Throttle Position Sensor A Circuit Range/Performance
    P0122 - Throttle Position Sensor Circuit Low Voltage
    P0123 - Throttle Position Sensor Circuit High Voltage
    P0124 - Throttle Position Sensor A Intermittent
    P0125 - Engine Coolant Temperature [ECT] Excessive Time To Closed Loop Fuel Control
    P0126 - Insufficent Engine Coolant Temperature for Stable Operation
    P0127 - Intake Air Temperature Too High
    P0128 - Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
    P0130 - HO2S Circuit Bank 1 Sensor 1
    P0131 - HO2S Circuit Low Voltage Bank 1 Sensor 1
    P0132 - HO2S Circuit High Voltage Bank 1 Sensor 1
    P0133 - HO2S Slow Response Bank 1 Sensor 1
    P0134 - HO2S Circuit Insufficient Activity Bank 1 Sensor 1
    P0135 - HO2S Heater Circuit Bank 1 Sensor 1
    P0137 - HO2S Circuit Low Voltage Bank 1 Sensor 2
    P0138 - HO2S Circuit High Voltage Bank 1 Sensor 2
    P0139 - HO2S Slow Response Bank 1 Sensor 2
    P0140 - HO2S Circuit Insufficient Activity Bank 1 Sensor 2
    P0141 - HO2S Heater Circuit Bank 1 Sensor 2
    P0142 - HO2S Circuit Bank 1 Sensor 3
    P0143 - HO2S Circuit Low Voltage Bank 1 Sensor 3
    P0144 - HO2S Circuit High Voltage Bank 1 Sensor 3
    P0145 - HO2S Circuit Bank 1 Sensor 2 Slow Response
    P0146 - HO2S Circuit Insufficient Activity Bank 1 Sensor 3
    P0147 - HO2S Heater Circuit Bank 1 Sensor 3
    P0150 - HO2S Circuit Bank 2 Sensor 1
    P0151 - HO2S Circuit Low Voltage Bank 2 Sensor 1
    P0152 - HO2S Circuit High Voltage Bank 2 Sensor 1
    P0153 - HO2S Slow Response Bank 2 Sensor 1
    P0154 - HO2S Circuit Insufficient Activity Bank 2 Sensor 1
    P0155 - Heated Oxygen Sensor Heater Circuit (bank 2, sensor 1)
    P0156 - HO2S Circuit Bank 2 Sensor 2
    P0157 - HO2S Circuit Low Voltage Bank 2 Sensor 2
    P0158 - HO2S Circuit High Voltage Bank 2 Sensor 2
    P0159 - HO2S Slow Response Bank 2 Sensor 2
    P0160 - HO2S Circuit Insufficient Activity Bank 2 Sensor 2
    P0161 - HO2S Heater Circuit Bank 2 Sensor 2
    P0162 - HO2S Circuit Bank 2 Sensor 3
    P0163 - HO2S Circuit Bank 2 Sensor 3 Low Voltage
    P0164 - HO2S Circuit Bank 2 Sensor 3 High Voltage
    P0165 - HO2S Circuit Bank 2 Sensor 3 Slow Response
    P0166 - HO2S Circuit Bank 2 Sensor 3 No Activity
    P0167 - HO2S Heater Circuit Bank 2 Sensor 3
    P0169 - Fuel Composition Sensor
    P0170 - Fuel Trim Bank 1
    P0171 - Fuel Trim System Lean Bank 1
    P0172 - Fuel Trim System Rich Bank 1
    P0174 - Fuel Trim System Lean Bank 2
    P0175 - Fuel Trim System Rich Bank 2
    P0176 - Fuel Composition Sensor Circuit
    P0177 - Fuel Composition Sensor Circuit Performance
    P0178 - Fuel Composition Sensor Circuit Low Voltage
    P0179 - Fuel Composition Sensor Circuit High Voltage
    P0180 - Fuel Temperature Sensor A Circuit
    P0181 - Fuel Temperature Sensor A Circuit Range/Performance
    P0182 - Fuel Temperature Sensor A Circuit Low Input
    P0183 - Fuel Temperature Sensor A Circuit High Input
    P0184 - Fuel Temperature Sensor 1 Circuit Intermittent
    P0185 - Fuel Temperature Sensor 2 Circuit
    P0186 - Fuel Temperature Sensor B Circuit Range/Performance
    P0187 - Fuel Temperature Sensor B Circuit Low Input
    P0189 - Fuel Temperature Sensor 2 Circuit Intermittent
    P0190 - Fuel Rail Pressure Sensor Circuit
    P0191 - Fuel Rail Pressure Sensor Circuit Performance
    P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage
    P0193 - Fuel Rail Pressure Sensor Circuit High Voltage
    P0194 - Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 - Engine Oil Temperature Sensor Circuit
    P0196 - Engine Oil Temperature Sensor Performance
    P0197 - Engine Oil Temperature Sensor Low Voltage
    P0198 - Engine Oil Temperature Sensor High Voltage
    P0199 - Engine Oil Temperature Sensor Intermittent
    P0200 - Injector Control Circuit Voltage
    P0201 - Injector 1 Control Circuit
    P0202 - Injector 2 Control Circuit
    P0203 - Injector 3 Control Circuit
    P0204 - Injector 4 Control Circuit
    P0205 - Injector 5 Control Circuit
    P0206 - Injector 6 Control Circuit
    P0207 - Injector 7 Control Circuit
    P0208 - Injector 8 Control Circuit
    P0209 - Injector 9 Control Circuit
    P0210 - Injector 10 Control Circuit
    P0211 - Injector 11 Control Circuit
    P0212 - Injector 12 Control Circuit
    P0213 - Cold Start Injector 1
    P0214 - Cold Start Injector 2
    P0215 - Engine Shutoff Control Circuit
    P0216 - Injection Timing Control Circuit
    P0217 - Engine Over Temperature - Hot Light Requested
    P0218 - Transmission Fluid Over Temperature
    P0219 - Engine Overspeed Condition
    P0220 - Throttle Position Sensor 2 Circuit
    P0222 - Throttle Position Sensor B Circuit Low Voltage
    P0223 - Throttle Position Sensor B Circuit High Input
    P0224 - Throttle Position Sensor B Circuit Intermittent
    P0225 - Throttle Position Sensor 3 Circuit
    P0226 - Throttle Position Sensor 3 Circuit Performance
    P0227 - Throttle/Pedal Position Sensor/Switch "C Circuit Low"
    P0228 - Throttle/Pedal Position Sensor/Switch "C Circuit High"
    P0228 - APP Sensor 3 Circuit High Voltage
    P0229 - Throttle Position Sensor C Circuit Intermittent
    P0230 - Fuel Pump Relay Control Circuit
    P0231 - Fuel Pump Feedback Circuit Low Voltage
    P0232 - Fuel Pump Feedback Circuit High Voltage
    P0234 - Turbocharger Engine Overboost
    P0235 - Turbocharger Boost Sensor 1 Circuit
    P0236 - Turbocharger Boost Sensor 1 Performance
    P0237 - Turbocharger Boost Sensor 1 Circuit Low Voltage
    P0238 - Turbocharger Boost Sensor 1 Circuit High Voltage
    P0239 - Turbocharger Boost Sensor 2 Circuit
    P0240 - Turbocharger Boost Sensor 2 Performance
    P0241 - Turbocharger Boost Sensor 2 Circuit Low Voltage
    P0242 - Turbocharger Boost Sensor 2 Circuit High Voltage
    P0243 - Turbocharger Boost Solenoid Control Circuit
    P0244 - Turbocharger Wastegate Solenoid 1 Performance
    P0245 - Turbocharger Wastegate Solenoid 1 Low Voltage
    P0246 - Turbocharger Wastegate Solenoid 1 High Voltage
    P0247 - Turbocharger Wastegate Solenoid 2
    P0248 - Turbocharger Wastegate Solenoid 2 Performance
    P0249 - Turbocharger Wastegate Solenoid 2 Low Voltage
    P0250 - Turbocharger Wastegate Solenoid 2 High Voltage
    P0251 - Injection Pump Fuel Metering Control A
    P0252 - Injector Pump 1 Rotor/Cam Performance
    P0253 - Injector Pump 1 Rotor/Cam Low Voltage
    P0254 - Injector Pump 1 Rotor/Cam High Voltage
    P0255 - Injector Pump 1 Rotor/Cam Intermittent
    P0256 - Injector Pump 2 Rotor/Cam
    P0257 - Injector Pump 2 Rotor/Cam Performance
    P0258 - Injector Pump 2 Rotor/Cam Low Voltage
    P0259 - Injector Pump 2 Rotor/Cam High Voltage
    P0260 - Injector Pump 2 Rotor/Cam Intermittent
    P0261 - Cylinder #1 Injector Circuit Low
    P0262 - Cylinder #1 Injector Circuit High
    P0263 - Cylinder #1 Contribution/Balance
    P0264 - Cylinder #2 Injector Circuit Low
    P0265 - Cylinder #2 Injector Circuit High
    P0266 - Cylinder #2 Contribution/Balance
    P0267 - Cylinder #3 Injector Circuit Low
    P0268 - Cylinder #3 Injector Circuit High
    P0269 - Cylinder #3 Contribution/Balance
    P0270 - Cylinder #4 Injector Circuit Low
    P0271 - Cylinder #4 Injector Circuit High
    P0272 - Cylinder #4 Contribution/Balance
    P0273 - Cylinder #5 Injector Circuit Low
    P0274 - Cylinder #5 Injector Circuit High
    P0275 - Cylinder #5 Contribution/Balance
    P0276 - Cylinder #6 Injector Circuit Low
    P0277 - Cylinder #6 Injector Circuit High
    P0278 - Cylinder 6 Contribution/Balance
    P0279 - Cylinder #7 Injector Circuit Low
    P0280 - Cylinder #7 Injector Circuit High
    P0281 - Cylinder 7 Contribution Balance
    P0282 - Cylinder #8 Injector Circuit Low
    P0283 - Cylinder #8 Injector Circuit High
    P0284 - Cylinder 8 Contribution/Balance
    P0285 - Injector Circuit Cylinder 9 Low Voltage
    P0286 - Injector Circuit Cylinder 9 High Voltage
    P0287 - Cylinder 9 Balance System
    P0288 - Injector Circuit Cylinder 10 Low Voltage
    P0289 - Injector Circuit Cylinder 10 High Voltage
    P0290 - Cylinder 10 Balance System
    P0291 - Injector Circuit Cylinder 11 Low Voltage
    P0292 - Injector Circuit Cylinder 11 High Voltage
    P0293 - Cylinder 11 Balance System
    P0294 - Injector Circuit Cylinder 12 Low Voltage
    P0295 - Injector Circuit Cylinder 12 High Voltage
    P0296 - Cylinder 12 Balance System
    P0298 - Engine Oil Overtemperature Condition
    P0300 - Random/Multiple Cylinder Misfire Detected
    P0301 - Cylinder 1 Misfire Detected
    P0302 - Cylinder 2 Misfire Detected
    P0303 - Cylinder 3 Misfire Detected
    P0304 - Cylinder 4 Misfire Detected
    P0305 - Cylinder 5 Misfire Detected
    P0306 - Cylinder 6 Misfire Detected
    P0307 - Cylinder 7 Misfire Detected
    P0308 - Cylinder 8 Misfire Detected
    P0309 - Cylinder 9 Misfire Detected
    P0310 - Cylinder 10 Misfire Detected
    P0311 - Cylinder 11 Misfire Detected
    P0312 - Cylinder 12 Misfire Detected
    P0320 - Ignition/Distributor Engine Speed Input Circuit
    P0321 - Ignition/Distributor Eng. Speed Ckt. Performance
    P0322 - Ignition/Distributor Engine Speed Circuit No Signal
    P0323 - Ignition/Distributor Engine Speed Circuit Intermittent
    P0325 - Knock Sensor 1 Circuit Bank 1
    P0326 - Knock Sensor 1 Circuit Range/Performance (Bank 1)
    P0327 - Knock Sensor 1 Circuit Low Input (Bank1)
    P0328 - Knock Sensor 1 Circuit High Input (Bank 1)
    P0329 - Knock Sensor 1 Circuit Bank 1 Intermittent
    P0330 - Knock Sensor 2 Circuit Bank 2
    P0331 - Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 - Knock Sensor 2 Circuit Low Input
    P0333 - Knock Sensor 2 Circuit High Input
    P0334 - Knock Sensor 2 Circuit Bank 2 Intermittent
    P0335 - Crankshaft Position [CKP] Sensor A Circuit
    P0336 - Crankshaft Position Sensor Circuit A Range/Performance
    P0337 - CKP Sensor Circuit Low Frequency
    P0338 - CKP Sensor Circuit High Frequency
    P0339 - CKP Sensor Circuit Intermittent
    P0340 - Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
    P0341 - Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or single sensor)
    P0342 - Camshaft Position Sensor Circuit Low Voltage
    P0343 - Camshaft Position Sensor Circuit High Voltage
    P0344 - Camshaft Position Sensor Circuit Intermittent
    P0350 - Ignition Coil Primary/Secondary Circuit
    P0351 - Ignition Coil A Primary/Secondary Circuit
    P0352 - Ignition Coil B Primary/Secondary Circuit
    P0353 - Ignition Coil C Primary/Secondary Circuit
    P0354 - Ignition Coil D Primary/Secondary Circuit
    P0355 - Ignition Coil E Primary/Secondary Circuit
    P0356 - Ignition Coil F Primary/Secondary Circuit
    P0357 - Ignition Coil G Primary/Secondary Circuit
    P0358 - Ignition Coil H Primary/Secondary Circuit
    P0360 - Ignition Coil J Primary/Secondary Circuit
    P0361 - Ignition Coil K Primary/Secondary Circuit
    P0362 - Ignition Coil L Primary/Secondary Circuit
    P0370 - Timing Reference High Resolution System Peformance
    P0371 - Too Many High Resolution Signal 1 Pulses
    P0372 - Too Few High Resolution Signal 1 Pulses
    P0373 - Intermittent High Resolution Signal 1 Pulse
    P0374 - No High Resolution Signal 1 Pulses
    P0375 - Timing Reference Signal 2 High Resolution
    P0376 - Too Many High Resolution Signal 2 Pulses
    P0377 - Too Few High Resolution Signal 2 Pulses
    P0378 - Intermittent High Resolution Signal 2 Pulse
    P0380 - Glow Plug/Heater Circuit A
    P0381 - Glow Plug/Heater Indicator Circuit
    P0385 - Crankshaft Position Sensor Circuit B
    P0386 - CKP Sensor B Circuit Performance
    P0387 - Crankshaft Position Sensor 2 Circuit Low Voltage
    P0388 - Crankshaft Position Sensor 2 Circuit High Voltage
    P0389 - Crankshaft Position Sensor 2 Circuit Intermittent
    P0400 - Exhaust Gas Recirculation Flow
    P0401 - Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 - Exhaust Gas Recirculation Flow Excessive Detected
    P0403 - Exhaust Gas Recirculation Control Circuit
    P0404 - Exhaust Gas Recirculation Control Circuit Range/Performance
    P0405 - Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 - Exhaust Gas Recirculation Sensor A Circuit High
    P0407 - EGR Sensor 2 Circuit Low Voltage
    P0408 - EGR Sensor 2 Circuit High Voltage
    P0410 - Secondary Air Injection System
    P0411 - Secondary Air Injection Incorrect Upstream Flow Detected
    P0412 - Secondary Air Injection Switching Valve A Circuit
    P0413 - Secondary Air Injection Switching Valve A Circuit Open
    P0414 - Secondary Air Injection Switching Valve A Circuit Shorted
    P0416 - Secondary Air Injection Switching Valve B Circuit Open
    P0417 - Secondary Air Injection Switching Valve B Circuit Shorted
    P0418 - Secondary Air Injection System Relay A Circuit
    P0419 - Secondary Air Injection System Relay B Circuit
    P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 - Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 - Main TWC Efficiency Bank 1 Below Threshold
    P0423 - Heated TWC Efficiency Bank 1 Below Threshold
    P0424 - Heated TWC Temperature Bank 1 Below Threshold
    P0426 - Catalyst Temperature Sensor Range/Performance (Bank1)
    P0427 - Catalyst Temperature Sensor Low Input (Bank 1)
    P0428 - Catalyst Temperature Sensor High Input (Bank 1)
    P0430 - Catalyst System Low Efficiency Bank 2
    P0431 - Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 - Main TWC Efficiency Bank 2 Below Threshold
    P0433 - Heated TWC Efficiency Bank 2 Below Threshold
    P0434 - Heated TWC Temperature Bank 2 Below Threshold
    P0436 - Catalyst Temperature Sensor Range/Performance (Bank2)
    P0437 - Catalyst Temperature Sensor Low Input (Bank 2)
    P0438 - Catalyst Temperature Sensor High Input (Bank 2)
    P0440 - Evaporative Emission Control System
    P0441 - Evaporative Emission Control System Incorrect Purge Flow
    P0442 - Evaporative Emission Control System Leak Detected (small leak)
    P0443 - Evaporative Emission Control System Purge Control Valve Circuit
    P0444 - Evaporative Emission Control System Purge Control Valve Circuit Open
    P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted
    P0446 - Evaporative Emission Control System Vent Control Circuit
    P0447 - EVAP Vent Valve Control Circuit Open
    P0448 - EVAP Vent Valve Control Circuit Shorted
    P0449 - EVAP Canister Vent Solenoid Valve Control Circuit
    P0450 - Evaporative Emission Control System Pressure Sensor
    P0451 - Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 - Evaporative Emission Control System Pressure Sensor Low Input
    P0453 - Evaporative Emission Control System Pressure Sensor High Input
    P0455 - Evaporative Emission Control System Leak Detected (gross leak/no flow)
    P0456 - Evaporative Emission Control System Leak Detected (very small leak)
    P0460 - Fuel Level Sensor Circuit
    P0461 - Fuel Level Sensor Circuit Range/Performance
    P0462 - Fuel Level Sensor Circuit Low Voltage
    P0463 - Fuel Level Sensor Circuit High Voltage
    P0464 - Fuel Level Sensor Circuit Intermittent
    P0465 - Purge Flow Sensor Circuit
    P0466 - Purge Flow Sensor Circuit Performance
    P0467 - Purge Flow Sensor Circuit Low Voltage
    P0468 - Purge Flow Sensor Circuit High Voltage
    P0469 - Purge Flow Sensor Circuit Intermittent
    P0470 - Exhaust Pressure Sensor
    P0471 - Exhaust Pressure Sensor Range/Performance
    P0472 - Exhaust Pressure Sensor Low Input
    P0473 - Exhaust Pressure Sensor High Input
    P0474 - Exhaust Pressure Sensor Circuit Intermittent
    P0475 - Exhaust Pressure Control Valve
    P0476 - Exhaust Pressure Control Valve Range/Performance
    P0477 - Exhaust Pressure Control Valve Circuit Low Voltage
    P0478 - Exhaust Pressure Control Valve High Input
    P0479 - Exhaust Pressure Control Valve Intermittent
    P0480 - Coolant Fan 1 Control Circuit
    P0481 - Coolant Fan Relay 2 Control Circuit
    P0500 - Vehicle Speed Sensor
    P0501 - Vehicle Speed Sensor Range/Performance
    P0502 - Vehicle Speed Sensor Circuit Low Input
    P0503 - Vehicle Speed Sensor Intermittent
    P0505 - Idle Control System
    P0506 - Idle Control System RPM Lower Than Expected
    P0507 - Idle Control System RPM Higher Than Expected
    P0508 - Idle Control System Circuit Low
    P0509 - Idle Control System Circuit High
    P0510 - Closed Throttle Position Switch
    P0512 - Starter Request Circuit Performance
    P0522 - Engine Oil Pressure Sensor Circuit Low Voltage
    P0523 - Engine Oil Pressure Sensor Circuit High Voltage
    P0530 - A/C Refrigerant Pressure Sensor Circuit
    P0532 - Air Conditioning [A/C] Refrigerant Pressure Sensor Circuit Low Voltage
    P0533 - A/C Refrigerant Pressure Sensor Circuit High Voltage
    P0533 - Air Conditioning [A/C] Refrigerant Pressure Sensor Circuit High Voltage
    P0534 - Air Conditioner Refrigerant Charge Loss
    P0541 - Intake Air Heater Circuit Low
    P0542 - Intake Air Heater Circuit High
    P0550 - Power Steering Pressure Sensor Circuit
    P0551 - Power Steering Pressure Sensor Circuit Range/Performance
    P0552 - Power Steering Pressure Sensor Circuit Low Voltage
    P0553 - Power Steering Pressure Sensor Circuit High Voltage
    P0554 - Power Steering Pressure Sensor Circuit Intermittent
    P0560 - System Voltage
    P0561 - System Voltage Unstable
    P0562 - System Voltage Low
    P0563 - System Voltage High
    P0565 - Cruise Control ON Signal
    P0566 - Cruise Control OFF Signal
    P0567 - Cruise Control RESUME Signal
    P0568 - Cruise Control SET Signal
    P0569 - Cruise Control COAST Signal
    P0570 - Cruise Control ACCEL Signal
    P0571 - Cruise Control Brake Switch A Circuit
    P0572 - Cruise Brake Switch 1 Circuit Low Voltage
    P0573 - Cruise Brake Switch 1 Circuit High Voltage
    P0574 - Cruise Control System - Vehicle Speed Too High
    P0600 - Serial Communication Link
    P0601 - Internal Control Module Memory Check Sum Error
    P0602 - Powertrain Control Module Programming Error
    P0603 - Powertrain Control Module Keep Alive Memory (KAM) Error
    P0604 - Internal Control Module Random Access Memory Error
    P0605 - Powertrain Control Module Read Only Memory (ROM) Error
    P0606 - ECM/PCM Processor
    P0608 - Vehicle Speed Output Circuit
    P0615 - Starter Relay Control Circuit
    P0620 - Generator Control Circuit
    P0621 - GEN Lamp 'L' Control Circuit
    P0622 - GEN Field 'F' Control Circuit
    P0636 - Power Steering Control Circuit Low
    P0637 - Power Steering Control Circuit High
    P0640 - Intake Air Heater Control Circuit
    P0645 - A/C Clutch Relay Control Circuit
    P0646 - A/C Clutch Relay Circuit Low Voltage
    P0647 - A/C Clutch Relay Circuit High Voltage
    P0650 - Malfunction Indicator Lamp (MIL) Control Circuit
    P0654 - Engine Speed Output Circuit
    P0656 - Fuel Level Output Circuit
    P0660 - Intake Manifold Tuning Valve Control Circuit - Bank 1
    P0661 - Intake Manifold Tuning Valve Control Circuit Low - Bank 1
    P0662 - Intake Manifold Tuning Valve Control Circuit High - Bank 1
    P0666 - PCM/ECM/TCM Internal Temperature Sensor Circuit
    P0670 - Glow Plug Module Control Circuit
    P0671 - Cylinder 1 Glow Plug Circuit
    P0672 - Cylinder 2 Glow Plug Circuit
    P0673 - Cylinder 3 Glow Plug Circuit
    P0674 - Cylinder 4 Glow Plug Circuit
    P0675 - Cylinder 5 Glow Plug Circuit
    P0676 - Cylinder 6 Glow Plug Circuit
    P0677 - Cylinder 7 Glow Plug Circuit
    P0678 - Cylinder 8 Glow Plug Circuit
    P0683 - Glow Plug Control Module to PCM Communication Circuit
    P0684 - Glow Plug Control Module to PCM Communication Circuit Range/Performance
    P0700 - Transmission Control System (MIL Request)
    P0701 - Transmission Control System Performance
    P0702 - Transmission Control System Electrical
    P0703 - Brake Switch B Input Circuit
    P0703 - Brake Switch Circuit
    P0704 - Clutch Switch Input Circuit
    P0705 - Transmission Range Sensor Circuit (PRNDL Input)
    P0706 - Transmission Range Sensor Circuit Range/Performance
    P0707 - Transmission Range Sensor Circuit Low Input
    P0708 - Transmission Range Sensor Circuit High Input
    P0709 - Transmission Range Sensor Circuit Intermittent
    P0710 - Transmission Fluid Temperature Sensor Circuit
    P0711 - Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 - Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 - Transmission Fluid Temperature Sensor Circuit High Input
    P0714 - Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 - Turbine Shaft Speed Sensor Circuit
    P0716 - Input/Turbine Speed Sensor Circuit Performance
    P0717 - Input/Turbine Speed Sensor Circuit No Signal
    P0718 - Turbine Shaft Speed Sensor Circuit Intermittent
    P0719 - Brake Switch 2 Circuit Low Voltage
    P0720 - Output Shaft Speed Sensor Circuit
    P0721 - Output Shaft Speed Sensor Circuit Range/Performance
    P0722 - Output Shaft Speed Sensor Circuit No Signal
    P0723 - Output Shaft Speed Sensor Circuit Intermittent
    P0724 - Brake Switch 2 Circuit High Voltage
    P0725 - Engine Speed Input Circuit
    P0726 - Engine Speed Input Circuit Performance
    P0727 - Engine Speed Circuit - No Signal
    P0728 - Engine Speed Input Circuit Intermittent
    P0730 - Incorrect Gear Ratio
    P0731 - Gear 1 Incorrect Ratio
    P0732 - Gear 2 Incorrect Ratio
    P0733 - Gear 3 Incorrect Ratio
    P0734 - Gear 4 Incorrect Ratio
    P0735 - Gear 5 Incorrect Ratio
    P0736 - Reverse Incorrect Ratio
    P0740 - Torque Converter Clutch Circuit
    P0741 - Torque Converter Clutch Circuit Performance Stuck Off
    P0742 - Torque Converter Clutch Circuit Stuck On
    P0743 - Torque Converter Clutch Circuit Electrical
    P0744 - Torque Converter Clutch Circuit Intermittent
    P0745 - Pressure Control Solenoid A
    P0746 - Pressure Control Solenoid A Performance or Stuck Off
    P0747 - Pressure Control Solenoid Stuck On
    P0748 - Pressure Control Solenoid Electrical
    P0749 - Pressure Control Solenoid Circuit Intermittent
    P0750 - Shift Solenoid A
    P0751 - Shift Solenoid A Performance or Stuck Off
    P0752 - Shift Solenoid A Stuck On
    P0753 - Shift Solenoid A Electrical
    P0754 - 1-2 Shift Solenoid Intermittent
    P0755 - Shift Solenoid B
    P0756 - Shift Solenoid B Performance or Stuck Off
    P0757 - Shift Solenoid B Stuck On
    P0758 - Shift Solenoid B Electrical
    P0761 - Shift Solenoid C Performance or Stuck Off
    P0762 - 3-4 Shift Solenoid Stuck On
    P0763 - Shift Solenoid C Electrical
    P0764 - 3-4 Shift Solenoid Intermittent
    P0765 - Shift Solenoid D
    P0766 - Shift Solenoid D Performance or Stuck Off
    P0767 - 4-5 Shift Solenoid Stuck On
    P0768 - Shift Solenoid D Electrical
    P0769 - 4-5 Shift Solenoid Intermittent
    P0770 - Shift Solenoid E
    P0772 - Shift Solenoid E Stuck On
    P0773 - Shift Solenoid E Electrical
    P0774 - Shift Solenoid 5 Intermittent
    P0775 - Pressure Control Solenoid B
    P0779 - Pressure Control Solenoid B Intermittent
    P0780 - Shift
    P0781 - 1-2 Shift
    P0782 - 2-3 Shift
    P0783 - 3-4 Shift
    P0784 - 4-5 Shift
    P0785 - Shift Timing Solenoid
    P0786 - Shift Timing Solenoid Performance
    P0787 - Shift Timing Solenoid Low Voltage
    P0788 - Shift Timing Solenoid High Voltage
    P0789 - Shift Timing Solenoid Intermittent
    P0790 - Normal/Performance Switch Circuit
    P0791 - Intermediate Shaft Speed Sensor Circuit
    P0794 - Intermediate Shaft Speed Sensor Circuit Intermittent
    P0795 - Pressure Control Solenoid C
    P0796 - Pressure Control Solenoid C Performance or Stuck Off
    P0797 - Pressure Control Solenoid C Stuck On
    P0799 - Pressure Control Solenoid C Intermittent
    P0801 - Reverse Inhibit Control Circuit
    P0803 - 1-4 Upshift (Skip Shift) Solenoid Control Circuit
    P0804 - 1-4 Upshift (Skip Shift) Lamp Control Circuit
    P0812 - Reverse Input Circuit
    P0814 - Transmission Range Display Circuit
    P0815 - Upshift Switch Circuit
    P0816 - Downshift Switch Circuit
    P0818 - Driveline Disconnect Switch Input Circuit
    P0840 - Transmission Fluid Pressure Sensor/Switch A Circuit
    P0841 - Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance
    P0844 - Transmission Fluid Pressure Sensor/Switch A Circuit Intermittent
    P0846 - Transmission Fluid Pressure Sensor/Switch B Circuit Range/Performance
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    It's worth mentioning that some 355 owners have complained that their OBD2 scanners only read the codes when their motor is running.
    Likewise, some 360's require a TSB fix (free!) by a local Ferrari dealership for OBD2 codes to be scanned.
  3. eric355
    eric355 Formula 3
    1,210
    Toulouse (France)
    Eric DECOUX
    On 355 I really do not think that engine running is mandatory, only key in position II ... but one must take care that the alarm is desactivated (LED not blinking)
  4. Whatever
    Whatever Formula Junior
    Sep 6, 2002
    346
    Highland Village, TX
    Dan Marlett
    Wow, this is great! Are these codes generic to Ferrari or Generic to OBDII? I have a 360 and most of the codes are P1xxx, maybe earlier models did not utilize the high code numbers?
    Thanks in advance,
    Dan
  5. glasser1
    glasser1 Formula Junior
    Sep 2, 2006
    510
    Oregon
    OBDII P0 codes are generic (all manufacturers)
    OBDII P1 codes are manufacturer specific (Ferrari or whatever)
  6. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Right on the money!! :D
  7. pedalpusher
    pedalpusher Rookie
    Feb 20, 2005
    12
    Does anyone have a listing of the Ferrari specific OBDII codes? I have a code P1501, in conjuction with a generic 410 code.
    It would be great to have the entire list for everones future reference.
  8. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
  9. MD26
    MD26 Rookie
    Aug 3, 2022
    47
    Chicago
    Marcin
    Hi guys . Looks like its a pretty old chat but here is my issue . I got few codes that i scanned with generic scanner. U3114 C0300 and U3111 ... Any idea what the codes mean ?
    I appreciate any help .
    Thank you
  10. Qavion
    Qavion F1 World Champ
    13,805
    Ian Riddell
    What car do you have?
  11. MD26
    MD26 Rookie
    Aug 3, 2022
    47
    Chicago
    Marcin
    It's a 360 modena. Sorry I forgot to mention.
  12. tazandjan
    39,007
    See if this helps, but none of those codes are on this list.
  13. Qavion
    13,805
    Ian Riddell
    That's ok. I read your profile. I'd just never seen the codes before on a 360. A quick forum search didn't show these codes either.
  14. MD26
    MD26 Rookie
    Aug 3, 2022
    47
    Chicago
    Marcin
    Same here. Very interesting. Oh well. Looks like a trip to the dealership.
  15. RedNeck
    RedNeck F1 World Champ
    11,971
    The CSA
    Me
    http://enginecodes.net/network-codes.html
    http://u3114.enginecodes.net/
    http://u3111.enginecodes.net/
    http://c0300.enginecodes.net/
    I can't say that I've seen any of those codes before, not on a 360 anyway. "C" is chassis codes and "U" is network codes.
    https://www.obd-codes.com/trouble_codes/obd-ii-u-network-codes.php
  16. MD26
    MD26 Rookie
    Aug 3, 2022
    47
    Chicago
    Marcin
    Thank you for helping out :)
    I need to get this scanned with a professional tool.
  17. smwalker
    smwalker Rookie
    Apr 9, 2023
    9
    Steve Walker
    U codes are generally communication errors between modules. They communicate 1000 of time a minute if one packet is bad it will trip a code. It is nothing to worry about unless you cannot start your car, then it can be helpful in tracking down an issue.
    C codes and B codes are chassis and Body codes. They are also nothing to worry about till a problem pops up. It could be something as simple as it does not like the voltage it sees when you raise your window, but it still raises the window. For the most part they are useless. The average MBZ or BMW has about 150 B,C and U codes driving around every day. If you took your car to the shop for every U,B,C code 1 you would be broke and 2 dealerships cannot do much about them because they are so intermittent. Now if you have an actual issue or feature that is broken then they can do something about that. But taking it there just to get rid of some codes that do not produce any real world problem is just a wallet empty maneuver for the dealer.
    Now the main ones you have to worry about are the P (Powertrain) codes. Those are the ones that turn on the check engine light, most all others do not.
  18. MD26
    MD26 Rookie
    Aug 3, 2022
    47
    Chicago
    Marcin
    Hi there,
    Thank you for the clarification. It only happened one time and since then no codes. No P codes what so ever.
    I really appreciate your help.
