430 - OBD Pinout | FerrariChat
430 OBD Pinout
Discussion in '360/430' started by akagan, Jul 8, 2020.
  1. akagan
    akagan Rookie
    Aug 13, 2014
    15
    Oakland, CA
    Avi Kagan
    Does anyone have the pinout for the OBD port on the 430? I could have sworn I had found this at some point, but haven't been able to track it down. Specifically this is a 2009 430 Scuderia.
  2. Skidkid
    Skidkid F1 Veteran
    8,753
    Campbell, CA
    John Zornes
  3. akagan
    akagan Rookie
    Aug 13, 2014
    15
    Oakland, CA
    Avi Kagan
  4. Skidkid
    Skidkid F1 Veteran
    8,753
    Campbell, CA
    John Zornes
    Both CAN pins are listed at that link.
  5. akagan
    akagan Rookie
    Aug 13, 2014
    15
    Oakland, CA
    Avi Kagan
  6. akagan
    akagan Rookie
    Aug 13, 2014
    15
    Oakland, CA
    Avi Kagan
    Ok it took me a bit to understand the way Ferrari lays out their wiring diagram, but from going through that this is what I believe. Note this is specifically for a Scuderia, but probably applies to any 08-09 430.
    Pin 1: B-Can B (Likely High, but need confirmation)
    Pin 2: J 1850 Bus +
    Pin 3: Immobilizer (Couldn't find what the pin on the immobilizer is from my diagram)
    Pin 4: Gnd
    Pin 5: Gnd
    Pin 6: C-Can High (Note there are actually multiple C-CAN buses, mostly between the two engine ECU's, but those don't get to the OBD plug)
    Pin 7: ISO 9141-2 K Line
    Pin 8: HVAC K-Line (Note the diagram lists two connections on the HVAC node as K-Line, but one is likely L-Line?)
    Pin 9: B-Can A (Likely Low, but needs confirmation)
    Pin 10: J1850 Bus -
    Pin 11: HVAC K-Line (See note above)
    Pin 12: Dashboard K-Line
    Pin 13: Suspension Module K-Line
    Pin 14: C-Can Low
    Pin 15: ISO 9141-2 L-Line
    Pin 16: +12V Un-switched
    If anyone has any corrections to what I've mapped out let me know, and I will update this for reference if I find any new information.
  7. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    372
    NC
    I can confirm the CAN-B bus.
    I do have a Maserati pinout somewhere I can dig up if its helpful. A lot of the systems are identical between the cars and hence the mappings of which ECU's/to which pins&bus should be similar.
