OBD Fault Code Reader that works on Ferraris | FerrariChat
Discussion in '360/430' started by whatheheck, Oct 19, 2014.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #1 whatheheck, Oct 19, 2014
    Finally found an app that not only would read and interpret codes, would reset the codes and works great for Ferrari cars (360 & 430).
    It also reads all 3 ECU's (Engine 1 & 2 ECU and Transmission ECU).
    I tried Torque Pro first but it would only read 1 ECU so I continued to search for an app that works great for F cars.
    Here you go for sharing. App is called EOBD Facile. Cost is $12.00.
    I tried it yesterday and it read my current fault codes, it decoded it and after I've done some possible fixes the program reset the fault codes.
    It also does all sorts of things like reading of sensors in real time, etc.
    Program works great on my Samsung S3 Android phone and per their website works great on Apple phones too.
    The program also is compatible with the ELM327 bluetooth adapter I bought from Amazon.
    http://www.amazon.com/DBPOWER%C2%AE-Bluetooth-CAN-BUS-Diagnostic-Windows/dp/B009RLB4Z8/ref=cm_cr_dp_asin_lnk
    Here you go. Note: I have no affiliation to the seller or owner of the program. Just sharing info.
    Outils OBD Facile - Info about the OBD, ELM327 and automobile diagnostics
    Dan
  2. RedTaxi
    RedTaxi F1 Rookie
    3,307
    New Zealand
    Glen
    Thanks, I have the Torque pro and it works, but seems a bit hit and miss.
  3. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I have torque pro too and you are right, its hit and miss. And not only that - it only reads 1 ECU so we really dont know which ECU its reading........
    Dan
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I havent tried the TCU reading mode yet. I just noticed in the menu that when I select pull fault codes it gives me a selection of either ECU1, ECU2 or TCU.
    I will try it soon and report back.
    Thanks.
    Dan
  6. ibseloni
    ibseloni Rookie
    Aug 29, 2014
    13
    Austin, TX
    Kent
    Their website says it is compatible with the 430. Has anyone tried it on a 360?
  7. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    My car is a 360 and it works great.
    Dan
  8. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,152
    San Diego CA
    Fernando
    #8 ferralc, Jun 4, 2015
    Dan, does EOBD facile sees stored codes (not current fault codes)
    I have an Actron CP9575L OBDII reader but according to its website it doesn't see "trouble codes retained in memory" and I had a flashing CEL while in limp mode after my service a week ago and after restarting the car ran fine (no CEL) and there are no codes (I assume because it's is not present)
  9. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    586
    North east, USA
    I am in the process of using AutoEnginuity- about $4000. It is reading both ecu's but I have not been able to connect to the TCU yet of a 360 challenge car. It is supposed to be able to allow you to bleed the system, center the actuator and set pis value, but all that remains to be seen.
    On the engine side it is working properly and reading all Ferrari specific codes, have not tested it on the 430 or any other Ferrari s yet.
  10. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    I don't know much about the Challenge TCUs but if the software is similar to the early 360 TCU then you have no chance with the Auto Enginuity software.
    I'm very familiar with the aftermarket (AE, Texa & Leo) diagnostic kit as well as SD2/3 - early 360 TCUs are SD/Leonardo only.
  11. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    To the best of my recollection - yes, EOBD reads stored fault codes (not currently active). However it only works when the engine is running so ensure your engine is running, then select "Read Stored Fault Codes". Here you go:
    https://itunes.apple.com/us/app/eobd-facile-car-diagnostic/id713921569?mt=8
    Dan
  12. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,375
    I have a 360 RHD 1999 - and I can not find any OBD connector.
    Any suggestions ?
  13. rmarchjr
    May 21, 2012
    586
    North east, USA
    It's there, can be relocated if desired, under dash to about 3-4" right of steering colum on 99 CH car.
  14. FlyingHaggisRacing
    Jul 2, 2013
    1,375
    I'll look again in the morning.
  15. rmarchjr
    May 21, 2012
    586
    North east, USA
    you were right - no joy on the 360 challenge tcu, but good for 2004 360 tcu, scud tcu, and f430. worth the money to me.
