430 - Novitec supercharger kit, what is it worth? | FerrariChat
430 Novitec supercharger kit, what is it worth?
Discussion in '360/430' started by Freddan, Feb 22, 2022.
  1. Freddan
    Freddan Formula 3
    2,346
    Vansbro (Sweden)
    Fredrik
    A very subjective question i know.
    I have found a Novitec Rosso Supercharger kit Complete for the F430 (low milage and in good shape according to the seller) He´s located in Germany and i don´t have the possibility to check the condition for myself.
    Any inputs In what it´s worth? I honestly have no idea how to price this.
    any thoughts? Feedback appreciated. Thanks
  2. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,579
    San Jose
    dc
    Probably super expensive and would need to be serviced before installed. Then your F430 would be instantly worth less when you put it on. Win-win
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,907
    Isle of man- uk
    Good attachment to drop its value, would u buy a car that had one fitted.
  4. Freddan
    Freddan Formula 3
    2,346
    Vansbro (Sweden)
    Fredrik
    I´ve should have seen this coming... :)
    Yes, i would not have any issues with buying a car with this mounted but that´s another story. Weather it´s good or bad value on the car is another forum, my question was about pricing the kit itself and reference to this.
    I search some and found one for sale here around 2017 at 8500 usd but not sure how it did.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,907
    Isle of man- uk
    Probably blew the bottom end out of the engine, it will up your firing pressure a lot and load up the bottom end bearings.
  6. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    The good news is that hardly anyone would want it so it could go for peanuts
    The bad news if he bought it new he probably doesnt want your peanuts
  7. Freddan
    Freddan Formula 3
    2,346
    Vansbro (Sweden)
    Fredrik
    Seems to attract few people for sure. It´s bit funny - when you do mods like this on a Lambo it goes under "upgrades" and ads value. but more or less downgrade when it comes to Ferrari:)
    I don´t know if he´s the first owner of this kit/re-build. good question, but again - i on´t believe the first owner will go thru the trouble and spend that crazy money on a kit and then remove and sell.
  8. RedTaxi
    RedTaxi F1 Rookie
    3,307
    New Zealand
    Glen
  9. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,930
    Melbourne Florida
    KGC
    Find out what he wants for it and then decide what you would pay for it. I know it sounds stupid simple but really it is all about what it is worth to someone. You said he's in Germany, so the worst he can do is simply ignore you. Frankly, I would have to score a very, very, good deal on it considering the fact that I will be dealing very long distance with someone if there is a problem --- and of course, as previously mentioned, he can always simply ignore you.
    I know guys who have held on to stuff like that for years because they just keep telling themselves; "it's just got to be worth $_______". But ultimately, it's not worth any more than someone will give them for it.
    I've had to wait out the denial phase on some stuff I bought for my cars from sellers. But I am not afraid to offer exactly what I think I would be willing to pay. And that's it. With that said, I've bought some stuff that I wanted for a whole lot less than the seller thought he would take for it initially. Personally, I'd have to get it pretty darn cheap.
    brogenville likes this.
  10. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,579
    San Jose
    dc
    With luck he is just a scammer and you will only be out the "cost" of the kit.
  11. F131 one of one
    F131 one of one Karting
    Oct 12, 2019
    119
    Netherlands, Europe
    Taco Vonk
    Hi Freddan, In an advertising in Germany a Novitec set is offered for the 360. Asking price € 17.000 New € 29.600 ex tax. For a 430 a used set may be well over € 20K.
  12. tres55
    tres55 F1 Rookie
    3,552
    Canada
    Aren't the bottom ends of Ferrari's basically bullet proof more or less?
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,907
    Isle of man- uk
    You put a blower on the engine and you up the cylinder pressure a lot, i wonder how much they would take.
    On the big marine engines i used to work on, the diesel cylinder pressures are so high they stopped using white metal bearing shells- now use an aluminum alloy a few thou thick as the surface coating on a steel and copper backing. The white metal will not take the loading and will squeeze like pastry. The new alloy finish is great but the shells have to be changed on engine hours and the oil has to be spotless clean as any grit will scratch the journal.
  14. tres55
    tres55 F1 Rookie
    3,552
    Canada
    Yeah just saying Ferrari uses titanium rods. The engines are basically bulletproof. Not saying it doesn't add stress...but if you've ever built an engine for boost, most of the components you're going to use, modern Ferrari's already come with from the factory.
    They don't need much boost to make lots of power either since generally compression ratios are already high (and probably shouldn't add too much boost either).
    There a guy who twin turbo'd a 355 recently and with a stock motor was putting down over 600 to the wheels.
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,907
    Isle of man- uk
    They generally drop the compression ratio for boosted engines, i worked on a marine diesel with a turbo output pressure of 3.7 bar @ 22500 rpm on the blower turbine. It was giving 190 bar firing pressure, bloody loud
  16. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,930
    Melbourne Florida
    KGC
    Sounds risky without at least lowering the compression ratio. These kind of mods usually have to be engine coordinated. Also ECU coordinated, I would think.
    And that all starts to get pretty costly.
  17. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,579
    San Jose
    dc
    Highly refined 11+ compression ratio, perfected for the NA setup. Like above you would want to take the engine apart and drop down to say 8.5 CR when planning boost. But why add the cost and complexity? Sell the F430 and buy higher HP turbo Ferrari.
  18. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,930
    Melbourne Florida
    KGC
    I have had a bunch of NA 911s. IMO there are very few engines more bulletproof. I've run on the track with a failing engine ( upon tear-down there were cracked rings, and a cracked piston) and the engine kept going. Blowing smoke, but never came apart.
    Probably important to realize that even in the years where the NA 911 engines were running at high 9's in compression ratios (before variable timing), the Turbos at the time were dialed back to the mid eights, 8.5 IIRC. Added stress on the bottom end is always a concern with forced induction.
  19. Freddan
    Freddan Formula 3
    2,346
    Vansbro (Sweden)
    Fredrik
    Long story short... he wanted astronomical numbers for the kit so he owns it for sure.
    He's not the first owner/ builder of the car it was mounted on.
  20. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    I am absolutely not a big fan of these kits for both the 360 or F430. Just don't do it at any price!
    In my humble opinion the support of their stuff has been bad in the past and it isn't engineered for longevity plus they won't even support their original converted cars for basic replacement parts things like supercharger belts or even the bi annual oil service. I bet most conversions haven't even had a thing done since they got converted so no wonder they go pop.
    The engineering was done also using "piggy back" injectors which is never a good idea, in fact I hate the idea and wouldn't do it that way. Normally if the main engine ecu detects any actuator or sensor failures (afm's, cam position sensor failure, etc) it can react by pulling fuel and timing to protect the engine, with a hacked piggy back solution overlay on to it cannot help you, so you can imagine the result... boom...
    As for pressure, the original engine is more than capable at the speeds they run the Rotrex compressors at. If you wanted to go further you'd need some differences in gaskets, CR, etc. and maybe upgraded internals like pistons, bearings and shot peened con-rods but its pretty strong even without upgrades. The problem is when things fail all safety systems wont work, you will break something in a catastrophic way! Bad design I'm afraid...
    duck.co.za likes this.
  21. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,676
    LA & OKC
    Kevin
    I facilitated the sale of a couple of these kits way back in the day. A large part of the value of the kit was the installation by their “techs” who were flown in from Germany
    buying the kit used I think you’re losing one of the main components of what inflated the value of the kit in the first place
    parts wise the kit is maybe $10k-$15k in parts. I would rather source my own stuff and build a custom if I was going this route than run 10-15 year old used parts…
    I would not supercharge a F430 or 360 personally but if I was determined to go that route I would piece together my own kit since you’re not getting the labor from Novitec anyways.
  22. Alpintourer
    Alpintourer F1 Rookie
    Jul 20, 2013
    3,764
    The Low Country
    Dave Steven
    You want a faster Ferrari?
    Buy a newer Ferrari.
    I never understood why people spend good money to make their cars worth less.
  23. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,930
    Melbourne Florida
    KGC
    For the most part I agree. But in some folks defense, most shopping for a "used" Ferrari cannot afford a new model Ferrari. So as a result we shop for the best equipped, nicest color combinations, and options we can find in a "used" Ferrari. So with that said, sometimes we justify the investment in upgrades to a car we know we already would have a hard time replacing. But of course, in this case, I wouldn't go with the supercharger set up. No matter how cheap I could get it.
    Heck, my 360 for the street is already a better, faster car than I am driver.
