F8 - Novitec Springs and installation | FerrariChat
F8 Novitec Springs and installation
Discussion in '458 Italia/488/F8' started by Ddushman, Jul 15, 2022.
  1. Ddushman
    Ddushman Rookie
    Dec 18, 2021
    47
    Hello,
    Just curious if this seems reasonable. I'm pretty sure I have seen the installation around $1k or so from of owners. The Springs are pretty close but still on the high side.
    Thoughts?
    Novitec spring set (yellow), $1,950.00
    Install Novitec springs and lower 15mm’s, $1,680
  2. Viperjoe
    Viperjoe F1 Rookie
    You can lower the car 15mm on the stock springs, although ride quality will be compromised a bit. 30mm on Novitech springs will yield the best look without compromising ride quality.
    9650max likes this.
  3. JanStuart
    JanStuart Karting
    Mar 20, 2019
    80
    Sarasota Florida
    Jan Sirota
    I put them on and the car was lowered too much. Had it raised up to european spec and I am now happy. Springs do make a difference. By the way, the pricing for mine:
    Labor total: $1,880.00
    Shop supplies/Waste disposal: $47.00
    Parts total: $1,967.52
    Shipping total: $63.18
    Fluids total: $0.00
    Subtotal: $3,957.70
    FL Sales tax: $277.04
    Total due $4,234.74
  4. Viperjoe
    Viperjoe F1 Rookie
    The numbers ($) are fair.
  5. SNKTWN305
    SNKTWN305 Rookie
    Aug 25, 2020
    25
    Orlando, FL
    Springs $1800
    Install $1500
    + 7% Sales tax
  6. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,200
    Tampa FL
    Those numbers are good…you should get it aligned too…lowering changes camber and toe.
    Viperjoe likes this.
  7. Ddushman
    Ddushman Rookie
    Dec 18, 2021
    47
    Thank you. This helps.
  8. Ddushman
    Ddushman Rookie
    Dec 18, 2021
    47
    Yes, thank you. Will be doing the alliignment at the same time.
