No fuel out of injectors | FerrariChat
Discussion in 'Mondial' started by Gossimer, Jun 2, 2020.
  1. Gossimer
    Gossimer Rookie
    May 5, 2013
    42
    Melbourne, FL
    I need a little help.
    I am not getting fuel out of the fuel injectors. The car hasn't run in a couple years. I have replaced: fuel pump, fuel filter, fuel accumulator, fuel injectors and also tried adjusting mixture screw. When I disconnect a fuel injector and push down the pressure plate, fuel comes out of the fuel line, but if I put a fuel injector on the, place it in a bottle and press down on the pressure plate, no fuel is squirted from the injector, fuel injectors are new and all tested good. Any ideas what could be the issue?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Measure your control pressure first.
  3. Qavion
    Qavion F1 World Champ
    11,555
    Ian Riddell
    #3 Qavion, Jun 2, 2020
    If the pressure is good at the rails, do you have 12 volts dc at the injectors? Are both banks affected? Put your voltmeter red probe on the power pin and the black probe on a suitable engine earthing point.
    I don't have a wiring diagram for the Mondial (T?), but normally injector relay/s provide power to the injectors and the ECU/s provide an earth to individual injectors.
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,666
    CT
    John Kreskovsky
    I believe he has a Mondial with CSI. No fuel rails. The key is "press down on the pressure plate".
    Qavion likes this.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Looks like you are short of pressure- you have flow with no injector but not enough when you fit it. If i remember correctly i think there is a non return valve in the outlet line of the pump
  6. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Ian, from what he was describing, it looks like a CIS system so there is no injector wirings.
    Qavion likes this.
  7. Qavion
    11,555
    Ian Riddell
    Thanks, guys, this car is older than I thought.
  8. conan
    conan Formula Junior
    Nov 13, 2011
    389
    It is almost only mechanics .. so measure system pressure and control pressure by inserting a valve and gauge between distributor and warmup regulator. I found it easier to disconnect at the wur side.
    System pressure when valve is closed 5 bar approx when fuel pump is running. Then open valve and check that control pressure rises slowly as the heating element in the wur warms up.
  9. Gossimer
    Gossimer Rookie
    May 5, 2013
    42
    Melbourne, FL
    System pressure is really high. My guage only goes to 10 bar, but it is pegged out. I guess that means something is wrong with the fuel distributer, something plugged? Not allowing fuel to pass resulting in the high pressure, but I don't really know, think I am pretty much just guessing. Any ideas?
  10. Steve Magnusson
    25,145
    Yes, on the K-Jets, the fuel pressure regulator is part of the fuel distributor so has to be something bad there or something like the return line to the tank is blocked. Long disuse is never good for CIS as there are a bunch of very small clearances/orifices/fits so getting it refreshed won't be a waste. Larry Fletcher at CIS FlowTech in Alabama is the US rebuilder (i.e., many places may advertise rebuilding CIS components, but most are just sending them to Larry). Best to call him or send him a text (email, or even his website contact form, isn't a priority).
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Disconnect the return line to the tank and rig up a hose to a container , see if you get any flow and a drop in your pressure
  12. conan
    Nov 13, 2011
    389
    The pressure regulator can be checked next by unscrewing it from the FD. Fig 12 D14 page in the Mondial WSM.
    Of course, it needs to be set to correct pressure then, but that should be easy using the gauge.
    Are you sure the gauge reading is ok? You might want to verify it with an air compressor set at 5 bar and some white spirit in the lines to the gauge.
    Caution of course use eye protection and no open flames or sparks ...
  13. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    It sound like your fuel distributor is clogged with varnish from old dried out fuel. I would first make sure that your fuel tanks are flushed out, and you have a new fuel filter installed. Varnish will tend to collect in the fuel filter.
    The best thing I've found to remove the varnish is Techron. Fill up the fuel distributor, and all fuel lines with pure Techron, and let that sit in there for a couple of days. That should help clean out the system.
  14. Gossimer
    Gossimer Rookie
    May 5, 2013
    42
    Melbourne, FL
    I just wanted to say thank you to everyone for helping with this issue. I ended up sending the fuel distributor to Larry at cis flowtech to be rebuilt.
