No Drill Magnetic License Plate Mount | FerrariChat
Discussion in '206/246' started by Nuvolari, Nov 12, 2014.
  1. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,594
    Toronto / SoCal
    Rob C.
    Once we finished our Dino we realized that we had to mount the rear license plate but could not bring ourselves to drill holes in the freshly restored sheet metal. Originally the cars left Ferrari with no holes and it was up to the dealer to mount the plate for the customer. Ferrari supplied no drilling specs which made for quite the variation in mountings between cars.
    We wanted a clean install free of holes and decided that high strength magnets were the way to go. After quite a lot of experimentation we put together a kit that includes high strength rubber coated magnetic mounts together with a top quality USA made stainless steel license plate frame in either a chrome polish or semi-gloss black powder coat finish. Top it off with some nice period looking hardware and you have a nice slick install with no holes or risk of paint damage.
    Of course we wanted to make these available and they can be bought at: Dino 246?Home in the store (about half way down the page)
    Some more product info with lots of photos can be seen here:
    Dino 246 Restoration Blog: New Dino246.com Product: No Drill Magnetic License Plate Mount
    Hopefully these can help a fellow owner out. We have tested ours for over 1000 miles without the slightest hint of a problem.
  2. pk246gt
    pk246gt Karting
    Apr 4, 2006
    169
    Adelaide, Australia
    Paul
    Rob,
    That's a nice solution. Hold do you pry the plate off (without damage to the paint)?
    On the the various styles of surround, do you know whether the larger 'square' frame - eg sold on S/Formance, was attributed to a particular market i.e. Euro?
    Mine came drilled with this pattern (and is Euro) - and of course doesn't match the State required rectangular style.
    Paul
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,594
    Toronto / SoCal
    Rob C.
    Paul taking the plate off requires nothing more than a firm pull. The magnets have a large surface area and are rubber coated to perfectly protect the paint. Also because the fit of the whole assembly is so nice and tidy nobody would have a clue that the plate is installed in this fashion making plate theft no more likely with this setup.
    Regarding the holes in your car the square frame as you mention is for European cars and regrettably if you have those holes on your car it is hard to hide them with just about any other plate used in the world.
  4. dgt
    dgt Formula 3
    Jan 14, 2011
    1,291
    Northeast, USA & Oz
    Andrew
    Great solution and product guys.
    I had the plate holes filled in the back of #00962 in the hope these would be available so you have a sale here!
    To others: get it while you can, I've been waiting patiently for a front 'plateclip' which I was told will be manufactured again soon.
  5. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,120
    Norfolk - UK
    Tony
    Interested in what grade of stainless steel you are using (4xx)
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,594
    Toronto / SoCal
    Rob C.
    Tony the frames are 304 stainless steel. Good enough for the cladding of the St. Louis Gateway Arch so it should be ok for a license plate :)
    We have also amended our original blog post to show that we will include matching screw cap covers for those who prefer to hide their hardware. I personally like the look of the screws but other prefer them hidden so the covers give the option at no extra cost.
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #7 synchro, May 11, 2015
  8. NYC Fred
    NYC Fred F1 World Champ
    15,113
    Fort Lauderdale, FL
    Fred C
    Can't really tell from the pic...are those "dummy" bolt/screw heads on the frame?
  9. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  10. HMB-Dino
    HMB-Dino Formula 3
    2,251
    Pebble Beach, CA
    RonG
    A word to the wise, the screw cap covers are very delicate. One of mine is hanging on by a thread. But the whole assembly works and looks great.
  11. ENZOSON
    ENZOSON Formula Junior
    660
    Erie, Colorado
    PIETRO
    I ordered one today! Can't wait to install it
    Cheers
    Pietro
  12. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,594
    Toronto / SoCal
    Rob C.
    Thank you for the compliments on the product. All orders have been fulfilled which will make for some happy Dino customers. The plate is also great for car shows when you want to remain incognito for photos. Just pull off the plate when you park and put it back on when you leave.
  13. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Pietro,
    You are going to enjoy this!
    The single biggest deciding factor for me was the ability to easily remove it during washing to clean that sooted rear vertical.
    Carb'ed cars get dirty back there and that is just a natural fact on the Dino. Using this mag license plate mount lets you clean the whole panel; even behind the plate.
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I actually like the exposed slot screws but added a split washer on the back side of the plate per the instructions to keep the depth below the magnet mounting surface
  15. ENZOSON
    660
    Erie, Colorado
    PIETRO
    Waiting for my personalized plate to come - cant wait.
    Cheers
    Pietro
  16. ENZOSON
    660
    Erie, Colorado
    PIETRO
    #16 ENZOSON, Jun 14, 2015
    Great fit - perfect set up to solve my issue...
    Holes on the car are drilled to fit 1976 Italian "square plate".. Magnetic frame allowed me to remove "adapter plate"....
    Cheers
    Pietro
  17. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #17 synchro, Aug 26, 2015
    Sweet shots Pietro!
    UPDATE:
    Anyone wondering if the magnets will hold on well should be assured that after my 2000 mile Monterey trip they did not move a mm. Unbridled driving did not shake them.
    They also do not clean themselves ...
  18. Iceblue
    Iceblue Formula Junior
    Nov 5, 2012
    424
    Virginia Beach
    Olivier Perault
    I received my magnetic plate holder and place them on 6 months old paint job.
    It made a very loud sticky sound wen removing. Leaving my paint perfectly unharmed.
    I got scared for a minute. To my surprise no problem
    I went one extra step, I wrapped each magnets with filo cooking paper. Creating a thin soft film that helps with the sticky rubber on fresh paint.
    I would advise people to remove once a month to make sure there is all if fine.
  19. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,594
    Toronto / SoCal
    Rob C.
    Very cool. Now THAT is durability testing
  20. dino2X6lover
    dino2X6lover Karting
    May 26, 2015
    91
    Los altos, CA
    @nuvolari do you have a magnetic solution to attach glass covers over the headlights?
    If you read through feeds related to this, you will see there is high demand for this type of product. Few Dino owners want to drill holes in their cars to attach these covers, yet many owners, like myself, would love the flexibility of having covers on from time to time. A magnetic solution would also make it easier/quicker to remove the glass for cleaning and to improve visibility at night.
    Many thanks!
    CC
