New picture Thread for Boxer/TR/Ms!! | Page 10 | FerrariChat
Discussion in 'Boxers/TR/M' started by Challenge64, Apr 21, 2006.
  1. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,965
    houston/geneva
    Ross
    VColin, Robb and Auraraptor like this.
  2. ross
    Mar 25, 2002
    37,965
    houston/geneva
    Ross
    if any of you dont know, THIS is my favorite car.
    i love this car completely.
    if it were human it would either be my best friend, or i would marry it.
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,507
    romano schwabel
    and when you would get separated it will cost much less than a separation from a marriage woman ;)
  4. MM355
    MM355 Formula 3
    Apr 7, 2008
    1,152
    GMT + 3
    I know you have an F40 and 512TR, what are your thoughts on owning both ?
    Would owning an F40 make the 512TR obsolete or the 512TR outing less of an occasion.
    I am lucky to own a 512TR which has been a 90's aspiration and my ultimate car goal is to own a F40 sometime soon which always had the prized position in my heart.
    Auraraptor likes this.
  5. ross
    Mar 25, 2002
    37,965
    houston/geneva
    Ross
    they are different cars, for different purposes, and needs and moods.
    i am an equal opportunity car enthusiast :)
    i believe that there are many different cars to suit different purposes, so i try not to duplicate abilities - each car i own is for a slightly different reason.
    the F40 is a special car. around town and off boost, it runs like the 308 it came from; docile enough, but very raw - no comforts. on the open road, it can get very violent, and you better be paying attention since the revs rise in a flash and you need to change gears and hang on! the noise, the harsh ride, heaviness of all of the controls is initially intimidating, and then you have to forget you are driving a million dollar car that wants to kill you. but eventually you get used to it, and start to get comfortable with some of the quirks, and enjoy it.
    the 512tr, as Phil Hill once said, is about 3/4 of an F40. but this is an incomplete description. the power may eventually be 3/4 of the F40, but the delivery is entirely different. the tr revs rise smoothly as expected in a 12 cylinder atmospheric; you have time to think about the gear changes. and the sweet spot for the tr is cruising on big stretches of highway at high speed for hours. the seats are nice, the view is great, the ac works, the radio works, and all is well in the world - you feel majestic. you can relax. there is not much relaxing going on in the F40.
    G8TD, ronc52 and MM355 like this.
  6. turbo-joe
    Apr 6, 2008
    9,507
    romano schwabel
    you can not compare a normal aspirated engine with a turbo engine. 2 totally different things
  7. Hubs348
    Hubs348 Karting
    May 9, 2013
    176
    Thousand Oaks, CA
    Brian
    Patricia2020, ag512bbi and Auraraptor like this.
  8. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,955
    MO
    Omar
    They look absolutely stunning, period correct, and perfect on the Single-lug TR.
  9. Hubs348
    Hubs348 Karting
    May 9, 2013
    176
    Thousand Oaks, CA
    Brian
    @Auraraptor I agree. The look is really fantastic while maintaining that classic period appearance. Ferrari branded and you can say you own a very small piece of a great Ferrari Supercar!
  10. boxerman
    boxerman F1 World Champ
    19,684
    FL
    Sean
  11. boxerman
    19,684
    FL
    Sean
    Great compro.
    Would you add your BB views too please.
  12. ross
    Mar 25, 2002
    37,965
    houston/geneva
    Ross
    well you are probably pretty well versed in what the boxer feels like yourself ! :)
    but as a contrast to the other two.....
    the 512bbi is more comfortable than the f40, but less than the 512tr.
    it is cramped for anybody taller than 6ft.
    all of the controls seem like a car from the 70's, so the feel is 20+ years older than the 512tr, eventho they are only 9 years apart
    as i always say, the bbi is not a low tech car, it is a no-tech car.
    everything is heavy and requires deliberate action and interaction by the driver - you must be paying attention, and there is not much relaxing going on.
    but, it drives very smoothly, pulls nicely from low revs, has mostly predictable behavior, and is rewarding for a driver.
    more nimble than the 512tr, but not as good a cruiser.
    the behavior is improved with bigger rims/sticky rubber vs the oem.
    but here in houston the roads are so bad that i went to my daytona croma's with original size tires to give me some more suspension travel.
  13. boxerman
    19,684
    FL
    Sean
    Thanks for the feedback.
    Maybe you're runnign too much psi on modern rubber. With 17 inch rims and PS2s Ive found 29 psi front and 30 rear works out great in terms of steering feel and ride quality is way better than stock. Stock I think the book called for 40 psi because of those felxy sidewalls which made for atrocious ride.
    If Im backroading it might go to 30 or even 31 front as it noticeably lightenes the wheel, but its then more twitchy over 120 or so on highway.
    The other issue with modern rubber is alignment as its very different to stock. You might look at Tr specs as thats 17 in rims on a very similar chassis.. Personaly I like a car with 1.5 mm toe in each side for the rear, ie 3mm total. In front assuming its not all worn 1mm total toe in works, or you can to no toe for more reactivity, or the other way a bit more than 1mm toe in for more stabilty.
    ross likes this.
  14. boxerman
    19,684
    FL
    Sean
  15. boxerman
    19,684
    FL
    Sean
  16. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    221
    España - Madrid
    dkyranakis likes this.
  17. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    221
    España - Madrid
    Nobody knows anything about that unit (#93894) or that auction?
  18. Enzo Belair
    Enzo Belair Formula 3
    Jul 27, 2004
    1,553
    Texas
    Scott
    dinges, G8TD, of2worlds and 6 others like this.
  19. boxerman
    19,684
    FL
    Sean
    Where did your car come from, whats its background.
    Spider68 likes this.
  20. Enzo Belair
    Jul 27, 2004
    1,553
    Texas
    Scott
    Car was originally imported by Ferrari of Houston, they federalized the car and sold it. The car never left Houston and has had three owners, including the last owner being Ferrari of Houston. I traded my F12 for the car about 4 years ago and fully restored the car over the time period, including bringing it back to its normal specifications. 9K original miles, the car now lives with me and its other Ferrari siblings here in NJ.
    of2worlds and Spider68 like this.
  21. Spider68
    Spider68 Karting
    Aug 21, 2010
    209
    Switzerland
    What kind of green is that ? Really nice car
    Gesendet von iPad mit Tapatalk Pro
  22. Enzo Belair
    Jul 27, 2004
    1,553
    Texas
    Scott
