New lift and of course a project. | Page 2 | FerrariChat
Discussion in 'Mondial' started by Freerange72, Nov 22, 2017.
  1. Freerange72
    Freerange72 Karting
    May 22, 2017
    56
    Cincinnati
    Donnie
    So i took off a couple of days this week to get my CV boots replaced. Had to cut off two bolts.... which was easier than I thought it would be. Found a replacement curved washer for 6 bucks. Now this..... i am assuming that this is the cause for the inner CV boot tearing in the first place. Repair or replace? In Birdmans helpn guide his look a little misshapen, but not this severe. Thoughts? Image Unavailable, Please Login
    Sent from my SM-G955U using Tapatalk
  2. JimboMondial
    JimboMondial Karting
    Dec 26, 2005
    73
    Portsmouth UK
    Jim
    It's very soft metal just make it round again with a curved former (round bit of wood) and a hammer.
    Sent from my Lenovo YT3-X50F using Tapatalk
    Freerange72 likes this.
  3. moysiuan
    moysiuan F1 Rookie
    4,167
    Canada
    Yes it is a very soft metal so no problem to do the wood and hammer thing. I bent mine during the process of cleaning up the grease, the unit is heavy so even just putting it down a bit abruptly will deform the collar.
    It is possible the old (non-oem) retaining band was cinched so tight it cut the rubber and deformed the collar, but more likely just bent during all the comotion during the uninstall.
  4. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    The collar deformation can't really be 100% avoided. Even putting the car on jacks risks doing this, as the half-shafts (without the weight of the car to keep them nearly horizontal) will angle/bend down to the point they are touching/bending the collar inside the boot. Basically it's an original design flaw.
    Identical new ones are nearly impossible to find. You can either use the ones for the 328 (similar, but different) or pull out a hammer and form it back into place. But as noted, even new ones will get bent eventually.
  5. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Hey freerange can you remove the engine and trans with the quick jack?
    I’m between the quick jack or Maxjax I can’t decide.
  6. Freerange72
    Freerange72 Karting
    May 22, 2017
    56
    Cincinnati
    Donnie
    I have not tried. I did get the extentions with plans to do so in future. I think i have to lift it up and put it on jack stands, then add the extensions. I got the suv extension.
  7. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Ok thanks. You happy with the QuickJack overall?
  8. Freerange72
    Freerange72 Karting
    May 22, 2017
    56
    Cincinnati
    Donnie
    So far. It is alot heavier than I thought it would be. But it seems to work well and set up was pretty easy. Have you checked out YouTube videos to see what you get?
    JLF likes this.
  9. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Yea just started watching some last night
  10. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    I have the same lift for my Mondial -85. A bit heavy as Donnie says, but when you are under the car it feels kind of ok. I would be worried if it was too light.... I have the 12V version and it works great. Lifts very fast, no problem with just 12V.
    /Peter
    JLF likes this.
  11. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Thanks Peter
  12. ATSAaron
    ATSAaron Formula 3
    1,135
    Shady Shores, TX
    Aaron Bunch
    That's just the stamped piece that the boot clamps onto, right? If so then it's no big deal as long as the boot clamps tightly. Toyota MR2's have a similar inner joint design and I have done about 200 of those.
    Aaron
  13. Freerange72
    Freerange72 Karting
    May 22, 2017
    56
    Cincinnati
    Donnie
    Aaron, you are correct. It is and I have been using a 2.5 diameter dowel rod and mallet to get into a "more" round shape. As someone commented before, the previous clamp may have been responsible for the deformity.
  14. Nuno Andrade
    Nuno Andrade Karting
    Aug 24, 2019
    154
    Houston
    Nuno Andrade
    Thorn, do you have the reference of this tool?
  15. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Nuno Andrade and WATSON like this.
