New CV Flange won't fit half moon washers. Do i need them? | FerrariChat
Discussion in '308/328' started by Speedsterbeast, Mar 30, 2024.
  1. Speedsterbeast
    Nov 20, 2018
    31
    Thunder Bay Ontario
    Cory Zyromsky
    Hi gang, I just replaced my inner cv boot and flange on 1982 308. I didn't notice unti I greased it and went to install it, that the new flange has extruded dimples that will not allow the half-moon washers to be used. The original flange got bent a bit when I removed, but I guess I could reuse it. Although I'd have to clean and rebuild it again. Does anyone know if these dimpled ones simply do not require the washers? Do I just use regular flat or lock washers? Or do I try and straighten and rebuild with original flange? Any help would be greatly appreciated. Thanks for reading!
    -Cory Z
  2. Steve Magnusson
    26,506
    That flange design just requires washers IMO. The "forming" provides the same extra support that the arced pieces provide, but it will be a rather special washer -- about same thickness as the arced piece (which is rather thick for a 10mm diameter washer) and a rather small OD for a 10mm diameter washer. I think a flat washer would be fine, but this style of lockwasher would be OK, too (and it has the necessary extra thickness and small OD):
    https://www.mcmaster.com/91190a560
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    They're tq distribution plates. Even Porsche used them, but they are shaped to fit. This is what you'd be looking for. Porsche bolts the reverse of Ferrari, the output flange on the Porsche is threaded so the bolt passes thru the other way. Ferrari uses captive nuts, so make sure the nuts will be held captive by the Porsche style flange.
    https://www.pelicanparts.com/More_Info/91133219100.htm?pn=911-332-191-00-M127&msclkid=0482c0b24bfc194aad8da6bad608d953&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%20Ads%20-%20Porsche&utm_term=4580634170083223&utm_content=Porsche%20Catch%20All
    350HPMondial likes this.
  4. Speedsterbeast
    Nov 20, 2018
    31
    Thunder Bay Ontario
    Cory Zyromsky
    Maybe I'll just grind out the OEM ones that I already have to fit. Thanks for the help all!
