*NEW BUILD!* SF90 STRADALE ON HRE P104SC WHEELS & MORE - TAG Motorsports | FerrariChat
Discussion in 'SF90 Stradale' started by TAGMotorsports, Jun 23, 2021.
  1. TAGMotorsports
    TAGMotorsports Formula Junior
    Sponsor
    One of our long-time clients just took delivery of a beautiful white SF90 and sent it right over us to get the TAG treatment. HRE wheels were selected as the rollers of choice, with the P104SC being the style of choice. Finished in HRE's brushed clear, we think it compliments this SF90 perfectly. Some small tweaks were made by adjusting the stock suspension to be lowered 15 mm to compliment the new wheelset. A nice final touch was painting the brake calipers in Blu Scozia for a hint of contrasting color.
    Enjoy the full photo gallery HERE
    2021 Ferrari SF90
    -HRE P104SC wheels in Brushed Clear
    -Brake Calipers painted by TAG Motorsports in Blu Scozia
    -Stock suspension lowered 15mm
    -Xpel Ultimate Plus PPF
    If you have any questions feel free to contact us HERE
    LMP, Napoli, stavura and 3 others like this.
  2. Nicolas21
    Nicolas21 Formula Junior
    Jul 13, 2016
    665
    Near a nuclear powerplant
    Nicolas
    Honnestly: perfect :)
  3. Sean@TAG
    Sean@TAG Formula Junior
    Sponsor
    Feb 25, 2015
    454
    Thanks so much!! We tend to agree :)
    Nicolas21 likes this.
  4. Xrayv8
    Xrayv8 Formula Junior
    905
    New Jersey
    Xray
    Beautiful! Did you also do the color match reflectors for the client?
    jr-f12-15 likes this.
  5. Sean@TAG
    Sponsor
    Feb 25, 2015
    454
    Thank you! And yes, we certainly did!
    Napoli likes this.
  6. EyeMac
    EyeMac Rookie
    Sep 9, 2021
    3
    Damien Macaluso
    Awesome build. Waiting for my SF90 Spider! I had the exact same wheels/finish on my Cerulean Blue 720S!
    Napoli likes this.
  7. Sean@TAG
    Sponsor
    Feb 25, 2015
    454
    Thank you so much. Congrats!!! Can't wait to see it!!
  8. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
  9. Sean@TAG
    Sponsor
    Feb 25, 2015
    454
    20" front 21" rear. 255/3520 and 325/25/21 :)
  10. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    The rear size suits the car well. But I don't know about the fronts. Normally when wheel diameters are staggered, the tyre profile is either kept the same, or taller on the rears. Hence why a 355/25/21 or 305/30R21 would normally be used with a 255/35R20. In that case they have the same profile but different diameter which looks pretty cool. Here I think it looks a bit odd with the taller profile in the front. I'm guessing that it was done because of the 4wd system, so that the diameter stayed close to OEM correct?
    Just sharing thoughts here, but have you thought about rather than a stagger the diameter like is normally done on an F8 for example, the SF90 might appear better with 21" squared and then 265/30R21 front with 325/25R21 rear? That way you retain a difference in diameter which is close to stock, and very similar front and rear sidewall heights, albeit slightly taller sidewalls on the rear. An added benefit would also be that as the rear tread width is increased, so is the front. This could serve to retain the steering balance of the car.
    Just some ideas for future SF90 setups:)
    of2worlds likes this.
  11. Sean@TAG
    Sponsor
    Feb 25, 2015
    454
    While totally understood, it was the ultimate goal to keep as close to OEM OD's as possible. This was to limit the possibility of "angering" the cars sophisticated systems. These are rather sensitive to modification!
  12. kyeleon
    kyeleon Rookie
    May 13, 2021
    15
    New York City
    May I ask how much did you guys modify the OEM offset or width of the wheels?They look somehow sticked out.
  13. Sean@TAG
    Sponsor
    Feb 25, 2015
    454
    These are a fully custom built wheel set with added width/ offset. in order to get that nice stance :)
  14. Sean@TAG
    Sponsor
    Feb 25, 2015
    454
    For reference, here are the specs :)
    20x9.5 ET25 (18mm more aggressive than OEM wheels) , 21x12 ET25 (about 17mm more aggressive than OEM wheels)
  15. Sean@TAG
    Sponsor
    Feb 25, 2015
    454
    Way back Wednesday :) Cannot believe this was 2 years ago already !
