New battery choice | Page 6 | FerrariChat
New battery choice
Discussion in '456/550/575' started by ferraridriver, Jun 1, 2016.
  1. fatbillybob
    Aug 10, 2002
    28,909
    socal
    don't known what that is. Orphan battery tender?
    308 GTB likes this.
  2. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    That may be.
    The cables appear to have a lot of surface wear from a P.O. connecting a trickle charger.
    308 GTB likes this.
  3. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
    ralfabco and 308 GTB like this.
  4. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    #129 ralfabco, Jul 5, 2020
    New battery installed.
    The car does not start or turn over :D.
    Idiot lights and Check OK light in the center of the dash are all ok and normal.
    Driver's glass window drops and all the normal sounds are present.
    I sent an email to the shop I use and asked for advice.
    I pushed the button on the immobilizer and the little tiny red light no longer illuminates after I pushed it several times.
    Just had a major service completed during Feb 2020, by a marque specialist.
    Should I consider the battery inside of the immobilizer has reached the end of it's life.
    ______
    Just received an email reply from the shop.
    The shop asked, if I can lock the car with the immobilizer.
    I no longer can lock the door with the immobilizer.
  5. ferraridriver
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
    Bingo ! ;)
    ralfabco likes this.
  6. fatbillybob
    Aug 10, 2002
    28,909
    socal
    That does not prevent car starting. To be sure to eliminate the fob immobilizer system use your pin.
    550 will not crank if imobilo is preventing it.
  7. ferraridriver
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
    It doesn't crank, The red LED on the fob doesn't light,
    My money is on the fob battery, 23A 12 volt
  8. fatbillybob
    Aug 10, 2002
    28,909
    socal
    Yes the fobs are wonky. I have had failure w no start. Put new bsttery in bent pins for good contact w no start. Then start car with pin. Then car start fine with fob!!!! This system sucks. I always think of having the trev360 delete it for me but I never think about it until it gives me trouble and I'm on my 2nd paragraph of 4 letter words...
  9. 308 GTB
    308 GTB F1 World Champ
    11,713
    New Jersey
    Barry Wolinsky
    Duracell MN 21/23 12V for the fob.
  10. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    Thanks. I will buy a new immobilizer battery.
  11. Laserguru
    Laserguru Formula 3
    Aug 7, 2016
    1,255
    New Hampshire
    Eric
    Buy three and keep two virgins in the glovebox. This is informed advice. Sadly....
  12. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    At some point I need to upgrade beyond one key.
  13. tazandjan
    39,141
    The fob is not the immobilizer and the immobilizer has no battery. There is a battery in the fob(s) and (internally rechargeable) batteries in the alarm siren. When you change the battery in the fob, make sure you check for corrosion and pinch the contacts together before inserting the battery. Spinning the battery after installing while pinching the contacts will ensure a good connection.
    Ferrari says the fob batteries should be changed every 6 months. I do that for the fob I carry in my pocket, but only change them annually on the other two fobs. Good advice on carrying a spare battery in the glove box, but make sure you have a tiny Phillips head screwdriver in there, too, or you will not be able to open the fob.
  14. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
    gobble (Mark) for keys and fobs: Yes!, key fobs again!!
  15. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    Barry,
    Thank you for the help. I sent Mark a PM.
    o/t I have a sister in Westfield and family in NYC.
  16. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
    Westfield is about 10 minutes away.
    להתראות
  17. JohnnyRay
    JohnnyRay F1 Rookie
    3,579
    Central FL/NW WI
    Can you kindly explain "trev360" for (some of) us? ;-)
  18. fatbillybob
    Aug 10, 2002
    28,909
    socal
    Trev360 is the resident 360 modena genius who figured out how to adequately remove the immobilizer among other accomplishments.
  19. JohnnyRay
    JohnnyRay F1 Rookie
    3,579
    Central FL/NW WI
    Tell us more. Is it a hardware or software solution?
  20. puckybadger
    puckybadger Formula Junior
    319
    Milwaukee, WI USA
    I don't get it. I see all these pics with those ugly green Interstate batteries. I don't care what anyone says, a battery is a battery. In fact, I think most are made right here in Milwaukee by a company called Johnson Controls. They did make all the Sears Die-Hards during their peak years. Anyway, 2 years ago I replaced my green Interstate with a beautiful all black NAPA brand battery. Peeled off the NAPA sticker and it looks like it belongs. Most important though, it starts every time.
  21. tazandjan
    39,141
    Now I have battery envy, even though mine has been faultless.
  22. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
    So, Terry, the next time you buy a battery you can get this...
    ...and your battery and car will be color-coordinated. :D
  23. tazandjan
    39,141
    Barry- Oh, no, has to be all black.
    puckybadger likes this.
  24. 308 GTB
    11,713
    New Jersey
    Barry Wolinsky
    I figured the red top would go with the cam covers. :D
  25. root
    root Formula Junior
    487
    Bay Area, Ca
    308 GTB likes this.
