New battery choice | Page 3 | FerrariChat
New battery choice
Discussion in '456/550/575' started by ferraridriver, Jun 1, 2016.
  1. 308 GTB
    308 GTB F1 World Champ
    11,713
    New Jersey
    Barry Wolinsky
    #51 308 GTB, Jun 9, 2016
    Hi Dave,
    That was an old picture of the Braille battery taken in 2010. I replaced the heat shield about a year later which went missing long before I bought the car. My 550's previous owner doesn't remember the car having a heat shield so it disappeared prior to 2001 when he purchased the car from its original owner.
    Early 550s did not come with the shield. Beginning with Assembly Number 24713 they did.
    You can also see that I have a Schumacher SE-1-12S battery tender installed.
    Barry
  2. fatbillybob
    Aug 10, 2002
    28,934
    socal
    Caution on LI batteries. Google thermal runaway. I think this may still be a problem. Racers love light LI batteries. So far I have seen 3 racecar fires or smoldering meltdown caught trackside.
  3. tazandjan
    39,151
    FBB- They are still too expensive just for use on a street Ferrari. Braille's batteries that would work for Ferraris run $1600-2600.
  4. rugby
    rugby Formula Junior
    Apr 10, 2015
    364
    Atlanta
    That’s an interesting response. But why the hostility? Why do you have a feeling going down “that” (?) route would be a waste of time?
    I am really glad you have a degree in chemistry, but frankly I wasn’t looking for academic credentials. Instead, I would have preferred some actual answers to the questions I raised in my post. Perhaps even an adult discussion?
    Since you do have training in a related field, I am disappointed that you are dismissive of my concerns. In my opinion, anyone considering using lithium should be aware of the issues that may arise from such an install. As a service to the community, it would be helpful to refrain from telling people that lithium batteries are OK to use in cars simply because they also happen to be 12 volt.
    However, I get it, there is no real interest in this group to discuss this topic. I understand. You win some, you lose some. It was worth a try. :)
  5. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
    #55 ferraridriver, Jun 11, 2016
    I'm finally finished with my battery installation, Got the proper red Positive terminal protector, factory OEM. ;) Only about $35.00 :eek:
    The new Interstate battery tender junior, which Interstate says is compatible with AGM, is hooked up and ready to charge for longer than 80 hours which now makes me officially a scofflaw in California. :eek:
    As for the header tank, the wire across the heat shield, and that number 6 on what looks like a spark plug lead remember this is a Skunkworks edition 550. :)
    308 GTB and F456M like this.
  6. tazandjan
    39,151
    Rugby- You got it. Maybe some of the V8 guys are interested.
  7. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    Hey Barry, my assembly number starts with 29xxx and I didn't get one with the car, I don't think either of the other two owners would have removed it probably one of the dealers just didn't put it back.
    Both the previous owners were like me.... wouldn't think of working on the car, so they wouldn't notice it was missing probably never even looked under the hood... At least I can say I have :)
  8. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    I like the positive terminal protector Dave.
    Very cool
  9. ferraridriver
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
    I just found out something I never realized before. I actually read the instructions, something I rarely do, for the new Battery Tender and discovered this.
    From Interstate:
    If a 12 Volt, Lead-Acid battery has an output voltage of less than 9 volts when
    it is at rest, when it is neither being charged nor supplying electrical current to
    an external load, there is a good chance that the battery is defective. As a
    frame of reference, a fully charged 12-Volt, Lead-Acid battery will have a rest state,
    no-load voltage of approximately 12.9 volts. A fully discharged 12-Volt,
    Lead-Acid battery will have a rest-state, no-load voltage of approximately 11.4
    volts. That means that a voltage change of only 1.5 volts represents the full
    range of charge 0% to 100% on a 12-Volt, Lead-Acid battery.
    Depending on
    the manufacturer, and the age of the battery, the specific voltages will vary by
    a few tenths of a volt, but the 1.5-volt range will still be a good indicator of the
    battery charge %
  10. tazandjan
    39,151
    Dave- That applies to normal lead-acid batteries, but not to the AGM battery you have. They are still lead-acid, but the liquid is all absorbed in the glass mats. AGM batteries can be much more deeply discharged than a lead-acid battery and still live.
    12 volt batteries are actually 14 volt batteries (you do not get the full 14 volts) and for aviation use a typical system would be a 28 volt system.
  11. ferraridriver
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
    Terry, I'm not sure I agree with that. While the construction is different the chemistry is the same. It's still a lead-acid battery
    My testing of the tender and reading voltages compared to the LED color on the Tender seem to bear out Interstate's statement.
    In any case I have queried Interstate and will let you know their response.
  12. tazandjan
    39,151
    Dave- AGM batteries in blowers, etc can be really deeply discharged, but I am not aware of actual minimum levels. They just stop working, so I will be interested to hear what they say.
  13. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    Hi guys so I'm at the Ferrari dealer in Las Vegas and the consensus of opinion is I should put the AGM in they told me that's all Ferrari is using now!
    The Auto Gallery told me there would be no problem replacing the one they just put in with AGM
    Any opinions from you guys would be greatly appreciated !
    Thank you
    Bill
  14. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    Hey Dave I have a question for you if I do switch to the a AGM will I still be able to use my battery tender plus that I've been using for the past several years
    Thanks Bill
  15. ferraridriver
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
  16. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    Hey Dave I just called Deltran about the battery tender plus using it on a AGM and they said it would be no problem whatsoever so I have the answer to my question thank you buddy
  17. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    Hi Dave I bought this 25 foot extension cord when I bought my battery tender it works great it's made by Deltran
    Battery Tender 081-0148-25 25' Quick Disconnect Extension Cable
    Price: $14
    Ships from and sold by Amazon.com.
  18. moysiuan
    moysiuan F1 Rookie
    4,180
    Canada
    AGM are becoming popular with many new cars having the stop start feature, so the OEM's must have determined the AGM technology has advantage for such an application. They also are sealed and do not corrode the battery area like conventional lead acid batteries tend to. As to absolute performance, regular lead acid is still pretty darn good technology for the actual starting purposes. And all batteries whatever the technology have a failure rate that is fairly high, hence all the warranty emphasis often advertised. Buying AGM does not mean a better or more reliable battery by many measures.
    The Oddyssey batteries with the pure lead internals are probably among the best engineered out there, or other batteries that use pure lead, such as Northstar. There are no doubt others, most US batteries are made by about three main manufacturers and sold under many brands.
    Some battery tenders have a switch to specify AGM verses regular flooded lead acid batteries, so there must be some sort of difference in optimal charging, but I am not sure what the difference would be, perhaps the speed of taking a charge is different with each battery type?
  19. rugby
    Apr 10, 2015
    364
    Atlanta
  20. rugby
    Apr 10, 2015
    364
    Atlanta
    AGM's will charge faster than floodeds (they have lower internal impedance and higher acceptance rate), but that does not make much difference to the charger.
    AGM's do not like to be equalized (or "rejuvenated" as some vendors call it). Equalizing is done by applying a very high voltage to the battery for a limited amount of time. This is supposed to knock off the sulphate crystal off the lead plates. This voltage can be as high as 15.7 volts and is called the "gassing" voltage. Basically, at that voltage the water in the battery electrolyte decomposes and releases hydrogen.
    With a flooded cell, this lost electrolyte water can be replenished, but if an AGM is ever allowed to boil like that, the water loss is permanent and the capacity of the battery is substantially diminished.
    So when buying a charger for an AGM battery, it is good to confirm that the maximum voltage ever applied to the battery will be below this gassing limit. If a charger has the AGM switch, this is most likely what it does.
    F456M likes this.
  21. moysiuan
    moysiuan F1 Rookie
    4,180
    Canada
    Interesting, thanks for the technical information on charging.
  22. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #72 4th_gear, Jun 16, 2016
    Looks like there's quite a bit of interest in AGM battery replacements for the older V12s. Here is a page out of the latest Interstate battery replacement chart as of about a month ago.
  23. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #73 4th_gear, Jun 16, 2016
  24. mxstav@comcast.net
    Nov 24, 2005
    211
    Green Oaks, IL
    Mark Stavropoulos
    I just put one of these in my 456 based on the advice from this august body. The only trouble I have is the clamp won't hold it. It is as if the lip on the bottom of the battery is too thin, the clamp bottoms out before it contacts the battery. Has anyone else had this problem? Any good solutions?
    Thanks!
  25. bill59
    bill59 Karting
    Oct 26, 2010
    228
    bean town
    bill h
    Would someone recommend a tender I can mount in the car. I park in a public garage so, with access to power, I still want my hood closed. Thanks
