New 360 F1 owner. broke down first day. Any help would be great. | FerrariChat
Discussion in 'Technical Q&A' started by Pono1, Dec 22, 2019.
  1. Pono1
    Pono1 Rookie
    Dec 21, 2019
    25
    australia
    Cris Ponoran
    Driving in auto & accelerated. As it dropped gears I went to accelerate again and went limp. Felt like when you run out of fuel. Pulled up low idle and no throttle response.
    Turned off then went to turn back on but check engine and f1 failure light on solid. 1 beep by 4 beeps on immobiliser. Cranks but no fire.
    Checked general troubleshoot:
    Pump works
    Fuses ok
    ATM fluid level good
    New battery
    Boot lid switch good
    Ordered obd2 port reader in the mean time WTF?? Im checking the brakes today then I'm out of ideas. Merry Christmas
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,313
    South East
    Jimmie
    Look for similar in 360 section for starters - one initial thing to try probably after trying to get any codes is a full battery off reset (not just ignition) - also you don't mention if there's definitely gas in tank
  3. greyboxer
    Dec 8, 2004
    12,313
    South East
    Jimmie
    Duplicate thread - merge / delete ?
