new 328 owner..as promised, my first questions and comments | FerrariChat
Discussion in '308/328' started by albert_k, Dec 9, 2019.
  1. albert_k
    albert_k Rookie
    Nov 20, 2019
    36
    Albert Khasky
    well..as we settle in to minus zero temps here in MN, i had a revelation today...not everyone uses 50/50 antifreeze blend! glad i caught that one..
    so..questions and comments..
    we seem to have some variability in gauge placement...here are mine. is this normal? the manual says no...
    also, i have to say..for 60 bucks, the shark steamer pro took ages of dirt off my seats! they were pretty well cared for already but still...the cleaning pad came out black!
    i need my seat to go forward more..there seems to be more “teeth” in the seat rails..any trick to this? i’m stumped for now...
    ggbh8 and Matto like this.
  2. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    378
    PA
    Alex
    Had this issue with my seats too. If they haven't been moved forward in the past couple decades, the rails are gunky and you just have to work them back and forth until they free up. Try kneeling outside the car and pushing the seats forward from the rear of the seat bottom. As a gauge, you should be able to move seats forward enough to see the rear seat rail hex bolts. Once you get them forward, my recommendation is take the seats out (4 bolts) and fully clean and lube the rails.
    mike996, yelcab and Matto like this.
  3. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    A previous owner of my car had installed two clips that hold the floor mat in place (at least I believe they were aftermarket). These clips prevented the seat from moving as forward as it can. Check and see if you have those in your car.
    Matto likes this.
  4. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    I found the same, the hard way.
    Sent from my iPhone using Tapatalk Pro
  5. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Rosey likes this.
  6. Saabguy
    Saabguy Formula 3
    1,753
    Shreveport, LA
  7. 83911SCDrew
    83911SCDrew Karting
    Oct 21, 2018
    92
    Bernardsville
    Andrew K
    It’s a good arrangement until things are running hot!
  8. Saabguy
    Saabguy Formula 3
    1,753
    Shreveport, LA
    That same argument could be made for low oil pressure or high oil temp. The clock in that cluster directs your eye away from the gauges that are important. Add in some bright white thick paint lines and you can tell performance at a glance. Add in the light pod and go rally! ;-0
  9. Saabguy
    Saabguy Formula 3
    1,753
    Shreveport, LA
    Oh yeah, if that is an alarm (red light in gauge cluster) disconnect it now to save you the trouble of diagnosing electrical gremlins later. YMMV.
  10. Rifledriver
    33,736
    Austin TX
    Completely disagree. Gas and clock can be looked at some other time. Pressure and temp belongs right in your field of view.
    mike996 likes this.
  11. Saabguy
    Saabguy Formula 3
    1,753
    Shreveport, LA
    Agree about priority, but being able to take a glance in one direction and get all the info regarding engine condition is very nice. Yes better if all three were in front of driver but that's not an option.
  12. Rifledriver
    33,736
    Austin TX
    Oil temp is a lower priority. It does not change rapidly nor does it require immediate attention. Needing to look away at critical instruments is never done in any thoughtfully designed vehicle.
    The gauges were very well and logically placed by Ferrari.
    mike996 likes this.
  13. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,685
    Mike 996
    IMO...
    Who worries about oil temperature in a street car? ;) How many cars have/had an oil temp gauge from the factory? IMO it could never have been included and no one would have missed it. Sure, it's a useful racing tool, which is probably why Ferrari installed it - to channel some of that racing heritage. But the gauges you need in your line of site are there - oil pressure and coolant temp.
  14. Dr Tommy Cosgrove
    35,287
    Birmingham, AL
    Tommy
    I seem to remember someone here made and marketed those things.
  15. Rifledriver
    33,736
    Austin TX
    Who here can even tell me what maximum oil temp should be?
    BTW. Don't look to the gauge for an answer. It don't go high enough.
  16. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Hmmm...455F?
  17. Rifledriver
    33,736
    Austin TX
    Thanks for proving my point.
  18. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Price is Right rules.... 1201?
    308 milano likes this.
  19. Rifledriver
    33,736
    Austin TX
    Whatever that means.
  20. Dr Tommy Cosgrove
    35,287
    Birmingham, AL
    Tommy
    Whatever is required to boil off water? At least 212?
    When I drive mine I try to not park it and put it away until next time until I hit and hold over that point on the oil temp.
  21. Rifledriver
    33,736
    Austin TX
    212 is a good target to get it up to from time to time but certainly not a maximum. I have never seen a 308 or a 328 get high enough to give it a second thought, even on the track but with stock gauges it's not like you could ever know because the stock gauge doesn't go high enough. It was just great with the garbage oils we had in 1986 but times have changed.
    Anyway point is oil pressure and water temp belong in front of your face.
  22. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,257
    Montana
    Kim
    you didn’t watch the Price is right? Where the person who’s number is closest wins? LOL
    thorn likes this.
  23. Rifledriver
    33,736
    Austin TX
    I have no idea that was. I'd rather eat a bullet that watch a game show. I'm guessing thats what we are talking about.
    No wonder. This place is inhabited by game show watchers. Explains a lot. I am in the wrong place.
  24. 308 milano
    Jan 15, 2007
    5,257
    Montana
    Kim
    When I was growing up we only had 2 TV channels. If I had known that eating a bullet was an option, I would have picked door number three!
  25. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Oh, come on RD... It was a slow day at work here, and just a bit of fun. I thought you might enjoy some randomly stupidly-high temp suggestions. ;)
