Need Help ASAP: Top down, trunk won't latch closed. | FerrariChat
Discussion in 'California/Portofino/Roma' started by jcavalie, Jul 14, 2010.
  1. jcavalie
    jcavalie Formula Junior
    660
    Oakland, CA
    Jim
    F-chatters -
    I'm really hoping one of you can assist me this evening! I'm up in Tahoe with only my California GT, and I just put the top down. The cycle took a hair longer than normal, followed immediately by a warning that my trunk was open. Sure enough, the trunk is unlatched and will not latch closed. So now, I can't put the top up either, as it says the top operation is inhibited by the trunk being open.
    Eegads! What do I do? No laughing - I don't have a garage here and I do have dozens of pine trees now all dropping pollen in my car. I'm not sure if I can even drive it back to the Bay Area with the top open and the trunk unlatched.
    I checked the fuse for the trunk lock, that was fine. Not sure what else to try.
    Any thoughts on whether I should try to manually close the top with the trunk in this bizarre state?
    Thank you all in advance!
    Jim
  2. jenniferq
    jenniferq Formula 3
    Apr 14, 2010
    1,155
    San Diego, CA
    Jennifer
    I had the same thing happen and just pushed harder on the trunk to shut it and was able to raise the roof. Then when I checked in the trunk, something had got in the way and wouldn't let it latch properly. Hope you've tried this by now!
  3. jcavalie
    660
    Oakland, CA
    Jim
    did you hold the trunk down while you raised the roof?
  4. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    I've had this happen a couple of times. Planning on having the dealer fix it. Press the trunk release button, it ought to open and then open and shut it. If it does not open, it means the piston ejectors are faulty. I have problems with those too. There is a manual trunk release pull. try that.
  5. jcavalie
    660
    Oakland, CA
    Jim
    opposite problem. I can't latch the trunk down. I push it down all the way, and it doesn't auto-lock the rest of the way. it is just bouncing open. so...when i try to close the top, it says the trunk is not latched....
  6. forgeahead
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    Oh. I am now speaking off the cuff. I have messed around with the mechanism a bit as you can see from my previous post. Try manually moving the hook latch which captures the lid. Also, tinker with the spring posts on the lid. If they have rotated, they will not depress and prevent the lid from shutting. Good luck.
  7. jcavalie
    660
    Oakland, CA
    Jim
    the hook latch which captures the trunk when you push it down, appears firmly planted at the lower location in its slots. when the trunk is open, should that loop be towards the top of the slot? i can try to bang it a few times and see if it loosens, but it doesn't move when i grab it.
  8. jcavalie
    660
    Oakland, CA
    Jim
    Ok - thanks for everyone's advice. Following forgeahead's idea, I played with the mechanism some more. What I had to do was manually work the mechanism on the hood itself until it snapped into the locked position. Then, I was able to lower the trunk, but the loop at the bottom was also in the closed position - ie, down in the lower position in the slots. With the trunk latched, but not connect closed, I lowered the trunk down and rested it on the catch loop. Then, I was able to use the trunk release button next to the driver's seat. It released the latch I had manually snapped shut and moved the loop to the upper catch position. Now, I am able to open and close the trunk properly, and I successfully closed the roof.
    So...I guess I have to decide whether to open the roof again in the next week, while I'm in Tahoe, or just drive a coupe until I can get thee to a dealer. I wish I knew if what I did would work twice. :)
    Anyways - thank you for the assistance - what a great community! I really didn't relish the thought of driving 250 miles with the trunk unlatched, bouncing up and down, and the instrument panel bleeping at me to close the trunk.
  9. rainforest
    rainforest Formula Junior
    Apr 14, 2010
    419
    Yes I agree. I didn't have this problem before, but if I was in the same position, I would sure be glad to have such a great community at hand!
  10. jenniferq
    jenniferq Formula 3
    Apr 14, 2010
    1,155
    San Diego, CA
    Jennifer
    It seemed forge had some more experience so I stood down. So glad it worked. Did you have anything in the trunk? I did and that was interfering with its closing, but it sounds like forge's might have been a fault with the mechanism. Wondering what yours was because now I'm rethinking my problem and wondering if it really was my fault or the car's.
  11. jcavalie
    660
    Oakland, CA
    Jim
    There was nothing in my trunk, except the manual. And since the trunk was stuck open, I was able to verify that the nothing was blocking anything, that the top had lowered into its correct position, and that nothing appeared to be impeding the mechanism.
    For whatever reason, I think when I put the top down, the last latching of the trunk closing failed to catch the loop, so the loop moved to the lowered position without pulling the trunk closed on it, thus the sensor stating the trunk was open.
    Thanks though - I had a neighbor help me with all sorts of stuff before I figured out snapping the latch and then popping the trunk.
  12. forgeahead
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    I am very glad to have been some assistance. Mine goes in next week. I will post what the issue is.
    Ray
  13. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,805
    Though this might be of some interest. There is a small black plastic flap which covers and hides the trunk loop for purely cosmetic reasons.
    In the early Cali's, the spring used to secure the flap was too flimsy leading to a misalignment of the plastic flap which could jam and prevent the trunk from closing.
    This small spring was updated with a more robust one.
    I had this happen to me and my trunk would not close. I was able re-aligned it myself.
  14. jcavalie
    660
    Oakland, CA
    Jim
    Thx - I have a very early 2010 California (delivered late august 09), so maybe I need the new spring, but the loop under that flap was visibly at the lower part of the slot, where it should be after it grabs and pulls down the trunk. the plastic flap seemed fine. Car needs to go in for a number of things - trunk, airbag light on, suspension SW update, etc. I'm just not around to take it to the dealer. My 430 needs to go in too - ediff light came on then went off last time I drove it, and the engine light is now on. Zeesh - need back2back appointments!!!
  15. not4one
    not4one Formula Junior
    May 23, 2010
    887
    CT, FL
    Mine is also an August 2009 and I had trouble with the two trim plates (silver/metallic) that are on either side of the trunk latch. As you're taking it in to dealer, check to see that these have not come loose and are possibly interfereing with trunk seal. Just had mine replaced this week...both came completely unglued.
  16. MalibuGuy
    Sep 18, 2007
    5,805
    #16 MalibuGuy, Jul 16, 2010
    I think everyone has a problem with those silver trim pieces coming loose. I just used some epoxy and re-glued them. (The plastic flap I was talking about is found between the trim pieces)
  17. Abirb
    Abirb Rookie
    Dec 30, 2012
    2
    London
    Abir
    Had the same issue and was really annoyed after a few minutes of fiddling around I noticed the latch was actualy in the lock position which must of happen if the lock let is pressed while the boot is opened (typical Ferrari design issue).
    All you need to do us open the boot and push a pen or straight and thin object on its side thru the latch at a angle to unlock the latch and hey presto!!
  18. Summerguy
    Summerguy Rookie
    Nov 3, 2011
    3
    West Virginia
    John Denbigh
    I had a problem with the trunk not latching after the battery ran down. After recharging the battery, I couldn't lock the trunk manually because the loop was stuck in the down position. Pressing the trunk button on the key or by the driver's seat got no response. I was beginning to think a fuse may be blown, but before I checked the fuses, I pressed the button on the key to lock the doors and again to unlock. Voila! The loop rose to the correct position and the trunk closed automatically as designed. Makes no sense but it worked.
