Need a New 360 Engine | FerrariChat
Discussion in '360/430' started by TheRarriInMe, May 6, 2018.
  1. TheRarriInMe
    TheRarriInMe Karting
    Jun 14, 2013
    61
    Need a complete engine and was looking for suggestions for a place specializing in engine replacements. Searched the web and found Exotic Auto Recycling and wondered if FChat members had dealt with them and if there were other suggestions.
    Please let me know when you have a chance.
    360Tom likes this.
  2. 24000rpm
    24000rpm F1 Rookie
    i guess replacing the engine is mildly easy for a run-of-the mill mechanic. As long as he/she is careful enough , for example, to take a lot of pictures for every step that was being done.
    so in my opinion, being careful and dedicated is much more important than being a specialist. Or i may say there isn't any "specialist" for replacing a 360 engine, or any engine for that matter.
  3. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    Exotic Auto Recycling is basically a wrecking yard, they part out cars. They are pretty good guys and have a lot of things so a good resource. Having said that, why are you replacing the motor and do you really want a used motor of unknown condition? Why not just rebuild your engine? But, the swap should be (relatively) straightforward.
    KC360 FL likes this.
  4. RedNeck
    RedNeck F1 World Champ
    11,973
    The CSA
    Me
    I hate seeing posts like this...what happened? Brian (@97 Spider Spider) is parting out a low mileage 360 right now, contact him, he typically has really good prices.
  5. vrsurgeon
    vrsurgeon F1 World Champ
    16,438
    Charleston, SC
    Curt
    Exotic Auto Recycling is a good spot to start. As above, what happened?
  6. TheRarriInMe
    Jun 14, 2013
    61
    Hydro-locked a cylinder and have over 70k on existing engine. Independent said he could rebuild as the cheaper option but wasn't sure if piston rod was bent. If bent it would be the same as replacement. With the question about the bent rod and the # of miles, the independent's suggestion is replacement.
  7. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,100
    Calif
    Brett
    i have bought a few parts from those guys and they were great. Otherwise cant say if replacement or rebuild is better or worse but buying a salvage engine is pretty straight forward. Should be fine IMHO. Good luck...In central valley calif I guess?
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    Remember that change of the whole motor (block etc.) may affect resale value as the car no longer is "matching numbers". Rebuilding existing "short block" obviously won't make same effect. Plus building an engine will give you 100% new engine compared to even 10-15k mile used engine - you can't never tell how it was abused.
    SoftwareDrone likes this.
  9. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    Interestingly enough, I drove a 360 where someone had warped the heads slightly so they machined them and put it together again. WOW! It is amazing what a few thousands can do to the power output of our cars. That car was fast and had a lot more power than my car. And yes, I had driven it before so I had a baseline compare.
  10. mello
    mello F1 Veteran
    5,434
    CA Bay Area
    Steve
    No surprise there ... Warped head = blown head gasket = low compression = lower HP. Same formula since Henry Ford came out with his model T.
  11. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    I meant that I drove the car before the blown head gasket and after the repair. A fairly small bump in compression by surfacing the heads resulted in a BIG jump in power (as measured by the butt dyno). And my car didn't have a blown gasket but was obviously lower power.
    I'm 360 Canuck likes this.
  12. azlin75
    azlin75 Formula Junior
    Jul 16, 2017
    785
    Kansas
    Shawn Hicks
    Interestingly all engines manufactured can vary in horsepower quite a bit. Then doing anything to improve on power can have a dramatic effect.
    Back to issue at hand would the OP be keeping the original engine? That could help come resale time or you could purchase parts and rebuild it yourself as a project. None the less I’d not part with the original engine even if you put a used engine in
  13. vrsurgeon
    16,438
    Charleston, SC
    Curt
    An engine with 70k miles on it (presume by the post above) means a car with 70k miles on it. Ain't no worth all "value of the car". Matching engine won't make it a pristine specimen at any point in its history.
    Get a cheap running block, put it in and drive the **** out of it. With high miles nobody is going to care about the matching engine in the next 2o -30 years.
  14. TheRarriInMe
    Jun 14, 2013
    61
    In Atlanta actually.
    Not reselling going to hold and more Cavallinos. Would be fun and a huge learning experience to take it on and rebuild myself, but I don't know my way around an engine of this magnitude.
    Didn't think about getting a block only, hmm I like this idea, will mention to the independent
  15. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,784
    San Jose, California
    I'm the one who had my engine torn down to the bare block and rebuilt. I had 70K miles on the engine when the head gasket pushed out. I had 11 mils shaved off of the heads, a five angle valve job, the cylinders honed, new rings, new main and rod bearings, new chain, new timing belt, etc. CRAZY acceleration compared to the first 70K miles of driving. And the engine is still performing flawlessly after 30K miles on the rebuild. Highly recommended.
    360Tom, one4torque, dbdreams and 4 others like this.
  16. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    more importantly, what'd the rebuild cost you?
    CarbonDan likes this.
  17. mello
    mello F1 Veteran
    5,434
    CA Bay Area
    Steve
    Interesting to see if it passes CA smog. It should though...
  18. TheRarriInMe
    Jun 14, 2013
    61
    As said above I think this would be a fun undertaking and excellent experience to know the car inside out. If I had someone in the Atlanta area willing to assist me that had the skillset necessary to do it I would take it on. I think finding such person would be difficult.
    Did you do this yourself or have help? I'm also curious as to how long it took and how much it cost you?
    I also like Curt's idea of getting a new block and rebuilding from that point.
  19. CarbonDan
    CarbonDan Karting
    190
    PNW
    Also very curious what the price range could be for a full engine rebuild.
    What kinds of numbers do you guys see? It's always nice to be mentally prepared for the worst.
  20. SoftwareDrone
    Jan 19, 2004
    7,784
    I'd like to think that the more important thing was that the engine has performed flawlessly for the last 3X,000 miles, but that's me.
    The rebuild was in the high four digit range (parts and labor) and took two weeks.
    John Heim from San Francisco Motorsports did the work.
  21. RedNeck
    11,973
    The CSA
    Me
    Wow, that's actually much less that I thought it would be . Remember looking at some receipts when I was car shopping, a refurb engine from a Ferrari dealer cost upwards of $26k. No reason to go used if you could get a complete refresh for under 10 grand and still keep your car original.
    I.T. Guy, dbdreams and Ryan... like this.
  22. CarbonDan
    CarbonDan Karting
    190
    PNW
    Agreed. I'd gladly pay a premium to keep the numbers matching, and $10k is far less than what I was expecting as well. I wonder how much 360 challenge engine rebuilds cost. I've ready they generally are rebuilt every year.
  23. vrsurgeon
    16,438
    Charleston, SC
    Curt
    High 4-figure range isn't bad at all... much less than I'd expect quite frankly. Looks like 12-14k for a used engine ask on eBay. Depending on how redneck.. *could* just replace the bent rod and bearing IMHO. Take off the affected cylinder head, undo the rod at the crank and push it and piston up and out then reassemble. Not sure if this is even viable... Easiest way is of course to just throw a used engine/block in and go with it..
  24. G. Pepper
    G. Pepper Three Time F1 World Champ
    37,996
    Texas/Colorado
    George Pepper
    I've bought from Exotic Auto Recyclers and it was a good experience. They ask high, so offer at least 20% less. Also, I would rebuild the engine rather than replacing it.
    Last 360 engine I saw that they had they were asking $14K. A rebuild would be less than that with some indy shops.
  25. timwu12
    Oct 31, 2014
    918
    TX
    if you could rebuild an engine for under 10K, I don't know why anyone would bother buying a used one from ebay or a wrecker for more than that.
    either way, this is good info to know!
