Need 355 Code P1130 | FerrariChat
Need 355 Code P1130
Discussion in '348/355' started by BLAMPEE, Jul 26, 2008.
  1. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    Had my first joy of Ferrari ownership today!!!
    After 2 weeks and 1200 miles the Check Engine light came on while driving. Took her to Gran Prix in Portland to see what it was. This was at 4pm on a Friday so they ran the check and came back with codes P1130 and P1119. I have done searches on both and cannot find anything for P1130 on FChat.
    Gran Prix's tech said he needed 2-3 hours with the car to make sure it wasn't a number of things he mentioned like leaks or seals.
    Anyone know what the P1130 code is and what it means if they both (P1130 and P1119) come on together? The tech did say say that it had to do with air/fuel mixture but was driveable.
    I sincerely appreciate all of you who know more than me about this new obsession I started!
  2. 355NY
    355NY Rookie
    Aug 12, 2007
    34
    Hi. What year 355? If it's a 95, you can pick up the codes yourself from the car. Here is a list of the codes I have. Possibly the mechanic read them wrong?
    Hot wire air flow meter 1111
    Engine coolant temp sensor 1112
    Throttle potentiometer 1113
    Lambda sensor 1114
    RPM sensor 1121
    Battery voltage 1122
    Secondary air solenoid valve 1123
    Purge valve 1124
    Lambda regulation Additive value for self adaptation 1211
    Lambda regulation multiplicative value for self adaptation 1212
    Lambda regulation intake manifold compensation 1212
    Short circuit on idle regulator 1311
    Open circuit on idle regulator 1312
    Electronic control unit 1313
    Injection valve 1 1411
    Injection valve 4 1412
    Injection valve 2 1413
    Injection valve 3 1414
    Malfunction Indicator Lights (MIL) 1444
    Valve 4111
    Stroke sensor 4112
    Power module not used 4113
    TDC control unit recognition 4114
    Catalyzer temp ECU 4121
    Catalyzer temp too high 4122
    Speedometer signal 4123
    Compressor connection signal 4131
    No error detected 4444
  3. 355NY
    355NY Rookie
    Aug 12, 2007
    34
    Cannot find code P1130
    I believe P1119 is 02 Sensor Heater Circuit (Upstream Catalyst) (Bank 2, Sensor1).
    I believe these are the codes for the 360, but most of them apply to 355.
  4. BLAMPEE
    It is a 1999 355, Mike.
    Does anyone disagree with the tech who says that it is still okay to drive over the weekend?
    I just want to have a little bit of info when I do drop her off to get fixed. Thanks for the help!!!
  5. 355NY
    355NY Rookie
    Aug 12, 2007
    34
    Brock,
    Since I'm not familiar with that code, I can't tell you whether I think it's safe of not.
    Sorry I couldn't help more.
  6. BLAMPEE
    Picking her up today.
    All they needed were four hours of labor to fix some leaky hose.
    I'll post the details and the descriptions of the codes tonight.
  7. BLAMPEE
    Well, after 1200 miles I guess it was time for something to go awry, no???
    Took her to Gran Prix and picked her up. here is the diagnosis:
    Codes P1130 and P1119 signified an intake leak according to the tech at Gran Prix Imports, who is the authorized Lamborghini Dealer of Portland, Oregon.
    The tech "tested and found leak at front of manifold and also a broken vacuum line. Replaced line and re-sealed leak."
    Total cost was only 4 hours labor.
    Cost was very reasonable. Customer service was so lacking that I am alsmot considering using Ron Tonkin Ferrari for service. I am writing a letter to the owner of GPI tomorrow.
