My E36 M3 - Ls1/T56 Swap Begins | Page 2 | FerrariChat
Discussion in 'Other German' started by one4torque, Dec 15, 2018.
  1. fatbillybob
    Aug 10, 2002
    26,358
    socal
    How big is your gas tank? LS6 figure 5.5mpg at full tilt! Thirsty!!!!
    LS1 I bet is no better especially if making more than LS1 stock 350hp.
    one4torque likes this.
  2. one4torque
    one4torque F1 Veteran
    5,118
    Houston
    One4torque
    16 gallons
    6mpg———-96 mile range
    20 min session avg 70mph
    23 miles
    Can do 4 20 min sessions
  3. one4torque
    5,118
    Houston
    One4torque
    parts going in .... the fun stage....
    rear end fun...... (SFW type ) :).....
    rogue engineering rear diff cover with massive cooling fins, extra 1.5qt cap, and provisions for oil cooler later.
    waiting for some syn fluid before I bolt her up in home base.....
    here you can see: 1. welded reinforced lcs'a, 2. poly sub bushings, 3. big azz rear diff cover, 4. and rlca brackets..... getting close to finish the back half.... then on to the front subframe.... welding in reinforcements there... THEN time to build up the LSX power. heads, cam, blueprinted oil pump, etc, etc...
    Schatten, HH11, Ak Jim and 1 other person like this.
  4. one4torque
    5,118
    Houston
    One4torque
    more progress.. was sick with flu for 2 weeks..... so back in the game.... want this running by MAY... before texas heat sets in!
    re-installed fuel system with new fuel fuel pumps...... new fuel lines for the LS returnless system.
    pulled the e36 m3 engine harness today to make way for the LS custom wiring spec swap harness!
    there is alot of "while I'm down here stuff"...... which is much easier to replace with engine and susp out..... this is the air con blower motor.... a 70 part that takes hours to replace with engine installed...... new one installed...... super fiddly.
    And new OEM trans tunnel insulation.....
  5. one4torque
    5,118
    Houston
    One4torque
    Jaguar36 likes this.
  6. one4torque
    5,118
    Houston
    One4torque
  7. one4torque
    5,118
    Houston
    One4torque
  8. Ak Jim
    Ak Jim F1 Veteran
    8,489
    North Pole AK
    Great progress!
  9. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,614
    Pittsburgh, PA
    Matt F
    Awesome!!!
    Matt
  10. one4torque
    5,118
    Houston
    One4torque
    Thx guys wasn’t sure if I was typing updates to myself :). Hope you enjoy the build... trying to keep that nice mix of oem build quality and merge the best of bimmer and gm power.
    Makuono and Davesvt2000 like this.
  11. alexion
    alexion Formula 3
    1,310
    New York
    This is awesome
  12. one4torque
    5,118
    Houston
    One4torque
    Update - more progress -
    fab'd a spacer for my shifter out of al stock - much better position.
    custom exhaust begins..... will be as follows:::: DUAL::: long tube headers, 3" collector >>> 3" spin-tech cat >>>> reduce to 2.5" >>>> 2.5" x-core resonator (dual in/out) >>>> 2.5" pipe to Borla muffler 2.5" dual in /out.
    Current status - new lifters, new hardened pushrods, new rr's (tq'd to base of cam), heads tq'd down, intake on, lokar throttle cable cut to length..... with out dog GSD.... 'V'... for Vespa - .
    Greg34 and Nativetroy like this.
  13. Greg34
    Greg34 Formula Junior
    531
    Sunset Beach
    Greg
    Thanks for posting. I really enjoy these DIY projects
    Nice looking dog btw.
  14. one4torque
    5,118
    Houston
    One4torque
    Thx Greg.
    Should do first start this weekend’
    Ordered accusump setup this week to keep oil pressure on long sweepers. No budget for drysump.
  15. one4torque
    5,118
    Houston
    One4torque
    1st START....
  16. Nativetroy
    Nativetroy F1 Veteran
    Nov 29, 2010
    5,944
    central fl
    Troy
    Started to sound good before it shut down. Issues? It looks like it’s coming along nicely. I’ve been a big fan of the Z3 swaps guys are doing as well.
  17. one4torque
    5,118
    Houston
    One4torque
    Since this start was just to confirm it runs no need for long test. Engine is full of assy lube and 30 wgt.
    Still needs exhaust cooling alternator..... fansetc...
  18. Nativetroy
    Nov 29, 2010
    5,944
    central fl
    Troy
    Gotcha. Wasn’t sure if it stalled or you shut it down quick. But I know that’s a major step.
  19. one4torque
    5,118
    Houston
    One4torque
    Native— it was a big deal since I had so many systems apart——. Dual fuel pumps, plumbing, wiring, custom eng harness, rebuilt eBay ls motor myself, etc etc. should just be plug and chug. From here.
    Mbutner likes this.
  20. Nativetroy
    Nov 29, 2010
    5,944
    central fl
    Troy
    That first fire after any engine swap or major tear down is always awesome to hear!
  21. one4torque
    5,118
    Houston
    One4torque
    Native - WERD!
    today doing OCD stuff... that is not fit for TV if this was a show......
    * remove drivers header..... clearance the drivers frame-rail... header was rubbing.
    * run new starter cable.....
    the above sounds simple enough.... but 4 hrs of jostling the complicated assy of header, subframe, stearing shaft, and motor-mount......
  22. one4torque
    5,118
    Houston
    One4torque
    with a streetable exhaust..... mostly m3 stuff....
  23. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,379
    The Cold North
    Tom
  24. one4torque
    5,118
    Houston
    One4torque
    Nativetroy likes this.
  25. Nativetroy
    Nov 29, 2010
    5,944
    central fl
    Troy
    Doesn’t sounds bad at all. Any plans to go to a more muscle like tone?
