My DIY Paint Correction | FerrariChat
Discussion in '360/430' started by Eric C, Apr 17, 2017.
  1. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,947
    St. Louis, MO
    Eric
    #1 Eric C, Apr 17, 2017
    My car had tons of paint swirls and minor scratches. Being the cheap butt that I am, I figured what's the worst that could happen?
    Here is what I bought:
    Paint Correction kit for $200. https://www.chemicalguys.com/TORQ_TORQX_Complete_Detailing_Kit_p/buf_209x.htm
    VSS – 1 stage compound https://www.chemicalguys.com/Scratch_and_Swirl_Remover_16_oz_p/com_129_16.htm
    Jet Seal - https://www.chemicalguys.com/JetSeal_16_oz_p/wac_118_16.htm
    Butter Wet Wax - https://www.chemicalguys.com/Butter_Wet_Wax_16_oz_p/wac_201_16.htm
    Purchased later –
    V36 & V38 Cutting Compounds - https://www.chemicalguys.com/V36_Cutting_Polish_V38_Final_Polish_16_oz_p/gap_vkit_101.htm
    Menzerna Professional Micro Polish - https://www.amazon.com/gp/product/B005JPJK8O/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    I didn’t have any idea what I was doing, so I watched lots of videos on youtube. It seems like there was a good 1 stage product out there called VSS. Well, I tried it with the orange pad and ended up with a hazy/milky mess, so back to the drawing board. Did some more reading and decided to give a 2 step process a try, so I ordered some Chemical Guys V36 and V38 combo. I cut it again (Orange pad) with V36 with 3 slow passes (Wiped the compound off, then hit it with V38 (White pad) for another 3 passes and wiped it off. Now we’ve got shine, but wanted better (Of course). So did some more reading and decided to buy some Menzerno Finish Plus (Highly recommended for that final shine). So, I tried it on the white pad and it really did a nice job. It really brought out a flawless deep shine.
    I don’t have any good before and after pictures (Sorry), just trust that it’s 100% better now. It’s time consuming, that’s for sure, but I’m pretty happy with the results. I’ve only done the Hood, Roof and top half of all the panels. I just do one panel at a time, then rest. I’ll do more this weekend.
    Random pictures to follow.
    **Disclaimer** I have no idea what I'm doing.
  2. aseweepay
    aseweepay Formula Junior
    Feb 1, 2004
    400
    Mid-West
    Wow, looks really good !
  3. GordonF355
    GordonF355 Formula 3
    Aug 13, 2005
    1,017
    Cincinnati, Ohio
    Gordon
    That looks really nice! Be careful about what you're doing though with a black car - if you get too aggressive with your products, you can create a mess for you or a professional to correct. Looks like you know what you're doing though from your end result! Nice work!
  4. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,158
    wow, very impressive
  5. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
  6. ihavearedferrari
    ihavearedferrari F1 Rookie
    Nov 23, 2007
    3,316
    Adam
    You got to have big balls to experiment on a Ferrari!
  7. brian0473
    brian0473 Karting
    Mar 14, 2010
    190
    San Antonio, TX
    Kudos to you for going for it! Looks great.
  8. mkzhang
    mkzhang Formula Junior
    544
    Philadelphia
    Wow you're ballsy!!! Glad the result came out good! But you should check under some intense light and sunlight to be sure you didn't create holograms aka buff marks.
    The risk with experimenting on a car like the Ferrari is that there is only so much paint to work with. Once you burn through the paint, there's only one way to get that paint back on...
  9. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    389
    Covington GA
    Tam V.
    Did you strip all wax and clay it before doing the compound?
    What is the plan of protecting the corrected paint? Sealant or Ceramic Coating?
  10. PVEferrari
    PVEferrari Formula Junior
    Eric,
    Wow, it looks darn good.
    What was the total costs of materials if you don't my asking?
    Cheers!
  11. Ahmed_Z
    Ahmed_Z Karting
    Aug 24, 2010
    215
    Washington DC area
    Ahmed
    Great job. like the others have said, that was def some risk if you've never done it before. I debated doing it myself as I have some swirls/water spots I want removed, but I'm terrified of going through the clear too much and effing it up. I'm dropping my car off to a detailer this weekend instead (paying $450).
  12. Eric C
    Mar 20, 2009
    10,947
    St. Louis, MO
    Eric
    Yes, I went over it with a clay bar first. I sealed it with Jet Seal, then Butter Wet Wax. I'll probably do the ceramic at some point, but I want the paint to be in great shape before I have that done.
  13. Eric C
    Mar 20, 2009
    10,947
    St. Louis, MO
    Eric
    Polishing is a lot safer than it used to be. With a Variable Speed, Random Orbit, Dual-Action Polisher with foam pads, it can be done without causing any damage. Since these buffers are made with a free floating spindle, if too much pressure is applied while polishing, the spinning of the polishing pad will cease to spin and only continue to vibrate
    Where you get into trouble is when you use a Rotary Buffer with old wool pads (Only for experts). Those can eat right through the clear/paint before you know what happened!
  14. Eric C
    Mar 20, 2009
    10,947
    St. Louis, MO
    Eric
    I spent around $350 for everything. That includes the machine, compounds, sealant, wax, clay bar and towels.
  15. Eric C
    Mar 20, 2009
    10,947
    St. Louis, MO
    Eric
    $450 is dirt cheap. I was quoted $900-$1,100 for a full paint correction and seal.
  16. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    Looks awesome. I'll clay-bar and polish my non-exotics as I have zero faith in my abilities and really can't imagine running my polisher over my cars.
    You need to be careful about detailers... you get what you pay for. I paid $2000 for a complete detail on my 16M, but the detailer (well known and recently retired here in the Bay Area) spent over 18 hours as the paint from the factory was so jacked up.
    I've taken my daily drivers to a local place in Los Gatos who charge in the $450-500 range and the work, while decent, is not great.
    I wish I had more time and confidence...
  17. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Eric - nice work :)
    The cost to have this done varies dramatically based on the process, the detailer and location. Mostly the process. some do a very light buff. Others do multi-state corrections.
    I've done this on my cars and I spend about 40 hours doing it. It's very time consuming doing it properly.
  18. tmvatlanta
    Mar 26, 2017
    389
    Covington GA
    Tam V.
    2nd this. I spent about the same time on my daily E39 M5
  19. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,594
    AZ
    Rick
    Ammo NYC has excellent detailing how too videos on YouTube as well as great products. No affiliation...just a customer.
  20. Canuck550
    Canuck550 Formula Junior
    Sep 8, 2015
    462
    Incognito
    RJA
  21. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    Great job Eric! I plan on doing this to my F430 at some point. If I pluck up the courage I'll be doing this myself too.
  22. StickBreitling
    StickBreitling Formula Junior
    Oct 12, 2012
    342
    I had to use my DA machine to polish out what looked like high heel scratches from the front of my F430. I'm guessing some lady (or guy!) in high heels climbed onto the bonnet whilst the car was parked out for a photo. There were small black rubber heel marks on the front bumper as well that needed polishing out.
  23. Eric C
    Mar 20, 2009
    10,947
    St. Louis, MO
    Eric
    #23 Eric C, Apr 18, 2017
    If you have swirl marks and minor scratches to address, you'll want to use a mild cutting compound before using the polish. V36 is mild. If not, the polish will be fine to use.
    Step 1: Clay Bar (If needed)
    Step 2: Polish
    Step 3: Jet Seal
    Step 4: Butter Wax
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'd suggest only using clay if really needed. More damage than good can be done with clay - even when being very careful.
  25. Eric C
    Mar 20, 2009
    10,947
    St. Louis, MO
    Eric
    Yeah, You're probably right. I don't even know if mine needed the clay or not, but since all the videos said to use it, I went and ahead and used the least abrasive clay bar I could find. It's probably only needed for paint that has high contamination.
    And you're right, it takes a lot more time than I imagined. It's a back killer. That's why I've only done the top half so far! Ha. But, I feel pretty good that I did it myself.
